Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 12-25-2003, 06:06 PM   #1
smacksube
Member#: 4067
01 2.5 rs
Default troubleshoot the EJ20G win cool stuff!!
ok....so since my last ecu code throwing post, i've managed to get rid of all the codes except Coolant Temp sensor, which i wired into the stock RS ecu loom so it'll show up on the dashboard whether it's overheating or not. ignitor is wired up, injectors are wired up and grounded, but i can't figure out why the car won't turn on....it turns over just not on. please help! not really for me, but for the poor ass guy i've been doing this swap for! he needs his jdm powered impreza back... lol...nah, but please help! thanks
and Merry Christmas
-eric
smacksube is offline   Reply With Quote
Old 12-25-2003, 06:42 PM   #2
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Default Re: troubleshoot the EJ20G win cool stuff!!
and Merry Christmas
-eric
Notes:
- There are 2 coolant temp inputs, one for the engine and one for the gauge. One for the engine should NOT go/split to anywhere else, only directly to the ecu (2 wires) . Gauge has a signal wire that is not on the same engine connector as the one going to the ecu.
- Injectors are wired up (12volts) other side is grounded by the ecu injector drivers. (DO NOT ground these wires manually)
- Sounds like the ecu is not powered up or grounded properly. Check ecu power wires (usually paired together on input connector) early JDM models are yellow/blue.
- Is the fuel pump running?
- Which ignitor do you have ? Is it the coil pack on each cylinder?
Ver.III is offline   Reply With Quote
Old 12-25-2003, 07:00 PM   #3
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
If you need a coolant temp sensor, I have a good one from the engine that I just took out of my car. I know it's good because I was getting the same CEL as you and the car was really hard to start, so I got another coolant temp sensor.
Brent
scoobyimprza is offline   Reply With Quote
Old 12-25-2003, 10:00 PM   #4
smacksube
Member#: 4067
01 2.5 rs
ahh, i was wondering about the coolant temp sensor. lemme reground the injectors and spark plug wires.
the fuel pump is running, and the ignitor pack sits on the passenger side of the car with individual wires going to each cylinder.
Old 12-29-2003, 09:16 AM   #5
Structure828
Member#: 50488
1999 GC8 ej20g!
Structure828 is offline   Reply With Quote
WTT: my cool stuff for wheels w/tires and or your cool stuff tucker2.0 RMIC Private Classifieds 7 02-27-2009 09:37 PM
The thread about all the cool stuff mankind has built beachbum Off-Topic 36 07-25-2006 05:18 PM
If you won the lotto - what cool stuff would you buy? GodWhomIsMike Off-Topic 33 04-05-2006 02:16 PM
The Angels win the series! The Angels win the series! The Angel win the series! Habu Southern California Impreza Club Forum -- SCIC 13 10-28-2002 08:13 PM
Some cool stuff from the latest REVspeed Tomnel Brakes, Steering & Suspension 3 07-21-2002 03:03 AM
