Old 12-26-2003, 10:46 AM   #1
ehabs
Member#: 16186
2002 Impreza WRX
WR Blue
Default Camshaft Position Sensor
I have a 2002 Wrx with 36,000 miles. I have had the camshaft position sensor cause CELs constantly since the first day I owned it. It only happens on hard launch in 1st gear. Dealer has said it is nothing but after 6 CELs he replaced the sensor twice, but it still occurs. If left alone, error code clears after a few days. Any ideas why this is happening. I have ignored the problem since it clears all the time, but now it is happening more often.
ehabs is offline   Reply With Quote
Old 12-30-2003, 12:57 PM   #2
ehabs
Member#: 16186
2002 Impreza WRX
WR Blue
Anybody has any ideas!!!?
Old 12-30-2003, 01:33 PM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
According to the guys at Cobb occasionally an aftermarket pulley will create this issue. If you have one, you will have to live with the CEL issue or go back to your stocker. If you haven't swapped out your pulley, and the sensor has been replaced, I have no clue.
Old 12-30-2003, 02:28 PM   #4
ehabs
Member#: 16186
2002 Impreza WRX
WR Blue
I don't have any mods except silencer removal and K&N Filter, which have no effect. The dealer says he will contact subaru to seek help with this problem.
Old 12-31-2003, 11:44 AM   #5
gotsol
Member#: 17346
08 Cayman S
is your crank moving and pushing into the sensor?
aka "crank walk"
gotsol is offline   Reply With Quote
Old 12-31-2003, 01:30 PM   #6
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Wasn't this a reflash issue?
Old 12-31-2003, 03:06 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
the cam sensor not crank sensor
could be bad wireing
would be intersting to do an impediance check on the wires back to the ecu...
Camshaft Position Sensor Issue (Car won't start) Hola Service & Maintenance 2 02-06-2005 12:12 AM
Camshaft position sensor shaneswrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-14-2004 04:39 AM
Camshaft position sensor dead AntonioS Normally Aspirated with bolt-on Forced Induction Powertrain 3 01-16-2004 05:30 AM
Camshaft Position Sensor zsurfrin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-16-2002 10:00 PM
CEL code: 0340 / Camshaft position sensor BluJay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-06-2001 05:07 PM
