Old 12-26-2003, 11:11 PM   #1
yamaharyder90
Member#: 51286
Question nos [ curious to know]
whats the difference between a wet and dry shot ?
yamaharyder90 is offline   Reply With Quote
Old 12-27-2003, 12:49 AM   #2
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
One of them (I assume 'wet') injects the nitrous into the fuel mixture, while the other doesn't. I don't pretend to know, so someone feel free to correct me.
gjhsu is offline   Reply With Quote
Old 12-27-2003, 12:59 AM   #3
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
That's what I understand the difference to be - a wet system injects fuel and nitrous, while a dry system is nitrous only. I have no idea which is better, or how much of a difference performance wise there is - not something I have looked into.
Old 12-27-2003, 01:21 AM   #4
CU04BlackWRX
Member#: 50653
2006 STI Steel Gray
Stage 2
A wet shot of NOS is more harmful to your engine then a dry shot. A dry shot would be something like a shot of NOS into the intercooler. Dry shot is "safer" then wet shot.
this link will explain it in more detail of the 3 types of NOS.
http://www.holley.com/HiOctn/TechSer.../NOSTech1.html
CU04BlackWRX is offline   Reply With Quote
Old 12-27-2003, 02:17 AM   #5
STIgeorge
Member#: 22040
12 FJ Cruiser
Rent-a-car White
Whoa there CUO4, maybe you should keep reading about nitrous before you make any other assumptions. For some reason or another, a wet shot is safer for your engine (less of a chance of leaning it out possibly??). Dry shots are used, although I don't know why, cheaper perhaps ( I didn't verify that statement). The previous two are completely different from the third use of nitrous. The type of NOS for the intercooler that you are talking about is not sprayed INTO the intercooler but rather ONTO the intercooler ( to cool down the charge of air that is circulating, much like the STi uses a water sprayer).
Geo
STIgeorge is offline   Reply With Quote
Old 12-27-2003, 02:51 PM   #6
Rancid
Member#: 3272
2016 VW Golf R
Not only are you wrong, but the link you provided proves it too. Generally, wet shots are better. Also, a dry shot is NOT spraying onto an intercooler. A dry shot just doesn't mix into the "wet" fuel.
Rancid is offline   Reply With Quote
Old 12-29-2003, 07:51 PM   #7
§tī
Member#: 51513
hey this is yamaharyder90 i had to get a name ....i think a wet shots better now that i know what it is..common sense alone should tell you that wet isn't and harmful as a dry shot ..the mix would calm it down i would think
§tī is offline   Reply With Quote
Old 12-29-2003, 11:09 PM   #8
CU04BlackWRX
Member#: 50653
2006 STI Steel Gray
Stage 2
Sorry guys I got it reversed, it was past 1 in the morning so what do you expect. next time I'll actually think.
Old 12-30-2003, 10:19 AM   #9
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Wet is the safest.
There are dry shot, wet shot and direct port (which is considered a wet shot).
Dry shot only injects nitrous into the intake. This is a good setup for NA cars.
Boosted cars should run wet kits.
A wet shot injects nitrous and fuel into 1 nozzle which is sprayed into the intake.
A direct port injection is also another version of a wet kit. Same setup as a wet kit but you run individual nozzles for each intake runner where each nozzle still sprays nitrous and fuel.
Then you can go into the dual stage setups....
Need4Boost is offline   Reply With Quote
Old 12-30-2003, 10:52 AM   #10
Snowphun
Member#: 1800
WRX /9-2x/Cooper S
awd/awd/fwd
Which one should I run if I want everything to get blurry when I flip the saftey and hit the big red NOS button, a la 2F2F?
Snowphun is offline   Reply With Quote
Old 12-30-2003, 05:58 PM   #11
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
dont inject, just inhale for the blurry vision deal....
note.. fuel cut + wet shot = BOOM! thunk thunk thunk thunk thunk...
DISCOPOPE is offline   Reply With Quote
Old 12-30-2003, 06:39 PM   #12
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
That is what a fuel pressure safety switch is for. It comes with all nitrous kits (well, it at least came with the NOS kits). As soon as there is fuel pressure drops, it cuts off the nitrous.
Not sure why there would be fuel cut if it is properly tuned. Plus boost should be turned down when running with nitrous.
Old 01-28-2004, 11:48 AM   #13
§tī
Member#: 51513
thanks for all the help i am getting Nos no time soon just for later refrence
curious of the difference between stock 16'' wheels and 17' wheels of equal weight Heather Tire & Wheel 12 07-01-2003 09:14 AM
Difference between Eibach Pro Kit and the SPD Eibach Kit? Arnie Brakes, Steering & Suspension 10 05-08-2001 01:23 PM
Whats the difference between FHI ver5 suspension and STI ver 5 suspension? MY99 2.5GT Brakes, Steering & Suspension 5 05-08-2001 05:20 AM
What's the difference between Sti wagon springs and Sti coupe/sedan springs? Robmat Brakes, Steering & Suspension 2 05-03-2001 09:56 AM
Difference between 22B, Ver.5 and Ver. 6 spoilers. Freeskier Newbies & FAQs 16 04-18-2001 12:52 AM
