Old 12-27-2003, 05:43 PM   #1
atchernyshev
Member#: 51140
2001 Outback
Default EG33 swap to Legacy B4
Dear Guru,
please help me investigate possibility for swap EG33 engine from SVX to Legacy B4 (automatic)
possible or not ???
thank you for help ..
atchernyshev is offline   Reply With Quote
Old 12-27-2003, 07:00 PM   #2
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
FAQ at the top of this form.
also try the nice little search button.
subiekid is offline   Reply With Quote
Old 12-28-2003, 05:50 PM   #3
tbd
Member#: 15322
1995 gf wagon
Blue Green Metallic 340
Default you're asking about a rare swap
Few here would likely have experience w/ the swap that you have inquired about.
1) most of the conversions here seem to center around the smaller impreza engine bay,
2) we don't have legacy b-4's here, our legacies are NA and of different wiring.
I've only heard of one case where someone put an svx engine into a usdm legacy, I believe it was abandoned later. Others have asked about the possiblility though. If you search you may find a blurb about it.
You may want to try on the UK boards as they'd be more likely to get a b4 than we would.
good luck
tbd is offline   Reply With Quote
Old 12-28-2003, 07:51 PM   #4
JC
Member#: 692
2011 Grand Cherokee
Triumph Speed Triple R
Default Re: you're asking about a rare swap
good luck
The now defunct JC Sports had a 1st gen legacy with a supercharged EG33. The real question is why?
JC
JC is offline   Reply With Quote
Old 12-28-2003, 09:23 PM   #5
subiekid
Member#: 25516
B4 = turbo
upgrade turbo and its better then the 6.
Old 12-29-2003, 11:11 AM   #6
atchernyshev
Member#: 51140
2001 Outback
Default Very important
..EG33 possible to install to BE5 and BE9 ... ????
P.S. i uderstand about re-wiringddd
Old 12-29-2003, 12:09 PM   #7
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
any thing is possible, how much time and money do you want to spend.
i would assume you can though because another member on here put the newer H6 3 liter in his 95 impreza L search for "Anders8" i think for a username.
Ben
Old 12-29-2003, 03:12 PM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
motor mounts
maybe ...??
tranny mount
yes
Old 12-29-2003, 05:35 PM   #9
subiekid
Member#: 25516
yea, you can do it. it will be a pain. but that body style did come with the H6. so using the newer motor might make it easier.
Old 01-06-2004, 12:23 PM   #10
atchernyshev
Member#: 51140
2001 Outback
thank all for info ...
Best Regards,
Andrew
Legacy B4 Motor Swap CatchMyDrift Subaru Conversions 2 11-07-2004 03:30 PM
Another wiring ? on sti swap to legacy harness serious Subaru Conversions 2 06-30-2004 01:53 PM
Wire ? on wrx swap to legacy- rear defogger serious Subaru Conversions 6 06-25-2004 12:28 AM
V8 twin scroll ?'s on swap to legacy serious Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-31-2003 02:20 PM
Thoughts on a legacy b4 swap into the gc8? jdmimpreza Normally Aspirated with bolt-on Forced Induction Powertrain 11 09-05-2002 11:15 AM
