Old 12-27-2003, 11:54 PM   #1
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Arrow Rebuilding Engine Heads - Tips? (and some other things)
Ok, I just picked up those EJ20 engine heads ive been waiting oh so long to get... They are rather dirty, and its completely in pieces, the first thing i'd like to do is clean them up a bit. Any tips for that? And is there anything else I should do while its all apart? What about like gaskets and stuff that I should replace?
Still hopefull that these will bolt up to the ej18 block, ill find out soon enough I guess. Although the camshafts for the EJ20 head are missing (not on purpose, they were supposed to be with it but they are elsewhere aparently) Im not entirely sure if that will be a problem to tell if the valves will clear the ej18 pistons... That seems to be my biggest concern right now.
Old 12-28-2003, 10:47 PM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Hmm, no responce due to sunday? Or does nobody actually know anything about this?
Old 12-29-2003, 12:21 AM   #3
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
steam clean? i always like to clean stuff up, but it never seems to work as well once i do.
subiekid is offline   Reply With Quote
Old 12-29-2003, 02:02 AM   #4
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Steam clean the internals? That doesnt sound like what I meant, lol
Old 12-29-2003, 02:12 AM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Gasoline and a toothbrush?
-Jon
Old 12-29-2003, 02:35 AM   #6
subiekid
Member#: 25516
ahha, the mod does not even know. screw it, just throw them on and have fun.
Old 12-29-2003, 08:25 AM   #7
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
-Jon
Yeah, I was thinking maybe kerosene(sp?)
scoobyimprza is offline   Reply With Quote
Old 12-29-2003, 10:51 AM   #8
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Clean and adjust
Maybe use some carb cleaner on the piston side? I know that's what I used to get off a lot of the deposits. Also I would check the vavle adjustment and such once you get the cams.
Joshua
yebokmj is offline   Reply With Quote
Old 12-29-2003, 02:20 PM   #9
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Maybe its worth just bringing them to a local machine shop. That way they can resurface the heads since you don't know what they been through. And re-grind the valves and valve seats, check the valve guides, put new guide seals, check for cracks....etc. Well worth the money in the long run.
Ver.III is offline   Reply With Quote
Old 12-29-2003, 03:24 PM   #10
madmanslegacy
Member#: 25911
89 R32 GTS-T
i agree, send them to a machine shop get the resurfaced ect... they should also have a solvent bath there to soak them in to take off all that gunk
or you can buy a can of engine or carb cleaner and a small wire brush
madmanslegacy is offline   Reply With Quote
Old 12-29-2003, 11:44 PM   #11
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Thats what I was looking for. Im really not out there to completely clean the whole thing perfectly, just get it to a point where I can work with it, and without damaging it. I was thinking simple green for the coolant channels, but I worry about how strong it is (good idea or no?)
As for taking it to a third party for operating, thats not within my budget. If I could afford that, i'd just have the them port and polished (which I would do myself if I could get some personal help with it, but probably wont so I wont) but for right now its just a simple cleaning so I can fiddle around with installing them on a EJ18 block to see how if it will work
Old 12-30-2003, 04:28 PM   #12
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Ok, picked up some carb cleaner and some metal brushes
Old 12-31-2003, 02:57 PM   #13
wawazat
Member#: 13793
2007 specB, 03 Ram
'92 SVX-5 speed
Simple Green works ok, but it doesn't cut as well as a solvent cleaner.
wawazat is offline   Reply With Quote
Old 12-31-2003, 08:31 PM   #14
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
ok, ill see how it goes.
Old 01-03-2004, 12:14 PM   #15
Storm
Member#: 5218
96L Most Over-
Developed Beater
Be careful with the metal brushes on that soft aluminum. If the bristles are super stiff, you might do some accidental porting!
Just an observation....
By the way, I still want your 1.8 ECU!!!
Jay Storm
Old 01-03-2004, 05:08 PM   #16
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Hmm, ill check and see if my buddy with the 1.8 has the ECU out of the car. He might be willing to sell it.
Old 01-04-2004, 03:02 AM   #17
Storm
Member#: 5218
96L Most Over-
Developed Beater
I had you mixed up with supermoose. I want his modded ECU.
Thanks though,
Jay Storm
Old 01-04-2004, 05:11 PM   #18
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Oh ok
Old 01-06-2004, 10:48 PM   #19
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Yes, I keep them in my closet, LOL!
Some pretty neat S2000 content and some other rando's seventhsign Member's Car Gallery 51 05-06-2010 02:27 AM
I need some insight on Intercoolers and some other thoughts. Nivekk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 08-24-2007 06:07 PM
FS: WRX rear diff, half shafts, crossmember, 2.2L NA engine and some other stuff speedyHAM Private 'For Sale' Classifieds 28 02-19-2005 11:06 AM
Please tell me what my hp, 1/4, and 0 to 60 is and some other questions? bruce cohen Proven Power Bragging 1 04-13-2003 02:14 AM
Pics from Nikis birthday and some others and some queens.... mcu81 Tri-State Area Forum 3 01-23-2002 01:01 PM
