Old 12-28-2003, 12:31 AM   #1
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
Impreza GC8 list of engine components needed for 2.2 into 1.8, help and many other questions
i bought a 95 impreza with a 2.2 turbo out of a 91' legacy, he swapped just the block and heads and couple other parts, the car runs and drives but it bogs down under load and bogs when it's cold . i've searched all over for the answer but i haven't found anything
so far it has fuel pump. regulator and maybe the TP sensor and the turbo(has crimp connectors) from the legacy i don't know if it has anything else yet
it runs on the 1.8 computer, but i have the 2.2 comp and intake and all, and was wondering how much difference there is between the 2.2 and 1.8 wiring, he said that the legacy comp has one more plug, does anyone know what it is ??
would the motor need the 2.2 injectors? aand will they work with the 1.8 manifold?
also i noticed that the vacuum line to the egr fell off when i bought it, ( i thought he bypassed it but found out later the hose ripped off) and when i hooked it up it seemed to run a lot worse
it has a air/ fuel meter gauge and when i'm cruising it jumps between normal to lean and under load it seems to jump off to the so lean it's off the gauge side
you can't floor it before 4 k or it will bog, 1/2 to half ,but when it gets past 4k it doesn't matter if your a wot or 3/4
i'll probably get a management system when i sell my 93 L or even swap the 2.2 intake and computer in, but for now i just want it to run decent
bobturismo is offline   Reply With Quote
Old 12-28-2003, 07:24 PM   #2
bobturismo
Member#: 42145
6-4 jockin da bish-
with the egr vacuum line disconnected and the line left to open air, the car runs at 85% just a little bit of bog versus 65% with the egr connected, but when i turn on the blower motor for the heater the air fuel gauge goes of the scale to the lean side at idle but when i accelerate a decent amount it jumps to the same side so i wonder does that mean it's rally rich?
when i get the chance i'm going to put the legacy injectors in and attach the speedo cable to the tranny ( i need some sort of connector nut for the tranny side) and replace the power wires with custom ones
should this make it run 90% or more?
Lists of things i need for my 99rs 99subaLYrs NESIC Private Classifieds 1 09-21-2009 07:07 AM
Lists of things i need for my 99rs 99subaLYrs Private 'Wanted' Classifieds 0 09-20-2009 08:39 PM
Whole list of Things I need for 20g setup drewwrxrogers Private 'Wanted' Classifieds 7 07-14-2007 03:14 PM
2.5 into 1.8 question Dangerdave Subaru Conversions 1 07-28-2005 07:26 PM
2.0 Block For Dirt Cheap And Many Other Parts chia Private 'For Sale' Classifieds 0 07-28-2004 10:39 AM
