Old 12-28-2003, 03:24 AM   #1
Paisan
Tri-State Track Instructor
Member#: 197
'14 Touareg TDI '14
BRZ http://48hrs.info
Default Impreza L AT 2.2 -> WRX Tranny/rear
Question I have is does anyone know for sure which flywheel woudl be used (WRX or 2.2L MT) and which clutch would be used.
Basically we will be converting my L over from AT to MT using a WRX tranny and rear end. Eventually it will also get turboed as well. But that's a different story.
Thanks for any input.
-mike
Paisan is offline   Reply With Quote
Old 12-28-2003, 01:50 PM   #2
Kha0S
Member#: 8808
2011 WRX
DGM 5D
The clutch and pressure plate need to match the transmission. You need a pull-type (subaru turbo style) pressure plate and matching clutch disk, and I'd reccomend the WRX flywheel.
/Andrew
Kha0S is offline   Reply With Quote
Old 12-28-2003, 07:45 PM   #3
Paisan
Member#: 197
'14 Touareg TDI '14
Yeah we have the clutch, just was curious on the flywheel. So a WRX flywheel will work on the EJ22?
Thanks in advance for the help.
-mike
Old 12-29-2003, 12:54 PM   #4
Kha0S
Member#: 8808
2011 WRX
DGM 5D
It should be the right bolt pattern, etc. The turbo-type pressure plate won't bolt to an N/A flywheel, as far as I know (but I might be off-base on that).
/Andrew
Old 12-29-2003, 07:14 PM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Yes, it bolts up to the EJ22. Trust me on this . My car wouldn't have driven after I swapped in my WRX transmission if it didn't. But you do have to match the clutch and flywheel to the transmission type.
-Jon
Old 12-30-2003, 08:28 PM   #6
quig
Member#: 31079
2000 WRX STI open
white
that is the exact swap I did in my rally impreza using the WRX trannie drive shafts and rear diff... the only complaint I have is the change in final drive ratio... the auto is 4:11 and the WRX is 3:90 so the 2.2 L kinda "lacks" but we raced to Pro races with the combo and it worked just fine... however we are changing to the Legacy / Impreza RS 4:11 mt for quicker response with the 2.2...
my .02's worth ...
steve
quig is offline   Reply With Quote
Old 12-30-2003, 08:42 PM   #7
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Steve good points but once the turbo goes on the 2.2 the gearing should be good to go I would think, right?
turboICE is offline   Reply With Quote
Old 01-09-2004, 11:52 AM   #8
quig
Member#: 31079
2000 WRX STI open
white
with the turbo, that should put your ratio on the ground just right. So (although not bad) if you can "suffer" the drive without the turbo until the swap time, thats a great combo to go with
Steve
Old 01-09-2004, 12:56 PM   #9
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Having the 4.111s on my WRX swap would be nuts. It whips through the existing 3.90 setup way fast as it is. For the anemic power plants it may be much better to have that 4.111 or 4.444 though.
-Jon
98 RSTi 2.5USDM engine and tranny rear links/trailing arms OneArmedScissor Brakes, Steering & Suspension 3 08-01-2007 09:19 AM
'97 Legacy 2.5GT -> WRX 2.0 Bud Brown Subaru Conversions 1 08-05-2005 06:25 PM
WTB: WRX tranny, rear diff, rear SEDAN axles DeusExMachina Private 'Wanted' Classifieds 4 12-10-2004 11:59 AM
2.5RS ---> WRX brakes swap. RyansJDMgc8 Brakes, Steering & Suspension 2 10-10-2004 06:47 PM
Thinking about selling: '00 2.5RS -> WRX conversion dissolved_girl Private Vehicle 'For Sale' Classifieds 1 11-06-2003 11:40 AM
