Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 12-28-2003, 11:58 PM   #1
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Default Tumble generator valve CEL
I replaced my injectors this weekend, everything went fine except for one thing, now that everything is back together I get a "P1086 Tumble generator valve #2 (LH) position sensor circuit low input" check engine light.
I checked all the tumbler valve sensors and they are all connected. I fear it may have something to do with the fact that I removed the sensor by cyl#2 to get a better angle at the fuel rail. Is there anything special about putting the sensor back on? I checked the service manual and there doesn't appear to be anything too complicated about it. Is there something I am missing?
Matt
TyranosaurusWRX is offline   Reply With Quote
Old 12-29-2003, 01:04 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
The spring sprang when ya took it apart...ya gotta rewind teh spring...if ya look at it when ya take it apart again...it should be fairly obvious what needs to be done...
If ya do a search, this is a really common thing that happens when doing injectors...
Old 12-29-2003, 01:23 AM   #3
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Thanks. yeah, I did a search, but may not have used the right search words. Anyways, can it just be rewound then? Well, I will take a look at it.
Old 12-29-2003, 02:25 AM   #4
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Hell, that was easy enough!
What would I do without these forums.
Old 12-29-2003, 04:00 AM   #5
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
set your car on fire?
subiekid is offline   Reply With Quote
Old 12-29-2003, 08:01 PM   #6
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Aaaaaamen
Old 08-08-2010, 10:54 PM   #7
emjayem
Member#: 225167
2009 wrx sdn dgm e85
332whp 370wtq
how about this^^^^^^^^^ for an 09 wrx? I took the servo motor off to get to a bolt when installing injectors. There does not appear to be a sprung gear on it. From what I have gathered, it is a completely different actuator than the older style. Will it just recalibrate itself?
emjayem is offline   Reply With Quote
Old 08-09-2010, 01:20 AM   #8
SleepyWeasel
Member#: 192060
2004 WRX
Holy old thread batman. It's a hilarious and high quality one though. I love seeing people fix simple problems w/ someone elses input. What WOULD we do without these forums?
You would probably have better luck starting your own thread in either the 2.5L turbo powertrain or newbie forums. GL though!
SleepyWeasel is offline   Reply With Quote
Old 08-09-2010, 09:28 AM   #9
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Lol wow, 7 yrs and 10 motors ago
Old 08-09-2010, 01:48 PM   #10
emjayem
Member#: 225167
332whp 370wtq
I figured people would like that! I have just been searching like crazy and thought this was pretty relevant to my issue. I did also post a new thread too, not much input on it tho. This had some good info
Old 08-09-2010, 05:53 PM   #11
SleepyWeasel
Member#: 192060
2004 WRX
I know some subaru guys are crazy, but you CAN'T be serious about 10 motors......right?
Old 08-09-2010, 09:46 PM   #12
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
A slight exaggeration but seriously, over 5. My car has been an electrical nightmare since the get go (and still is), not to mention steep learning curve in building/swapping and tuning your own engines, lol.
Got to thinking about it...
orginal ej20 broke a ring land sooo:
swapped in ej22(t) w/forged rods and pistons
pulled that put in backup ej20
ej22t gets new pistons and honed walls
ej22t stroker w/cams from Ron@Axis (raw performance)
backup ej20
stock ej22e w/stock wrx heads
rebuild ej22 stroker using ej22e pinned block and new internals
rebuild stock ej20 block and stock heads (current)
wish for death
lots of sad stories behind them all, lol.
CEL Code: P1090 Tumble generator valve #1 (RH) malfunction (stuck open) 4sworks Newbies & FAQs 6 08-14-2009 02:23 PM
P2009 CEL Tumble Generator Valve 97OBWagon Service & Maintenance 4 12-29-2008 07:31 PM
Help ... CEL 1086 re: Tumble Generator Valve Actuator lupohki Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 05-20-2005 08:14 AM
Tumble Generation Valve Info Imprezer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-21-2002 04:24 AM
Check engine. Tumble generator valve EPD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-12-2001 12:47 PM
