Old 12-29-2003, 01:59 AM   #1
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Default Integrated Module
For those who have done a USDM swap, what exactly is the integrated module used for? Is it only necessary for the security system or must it be retained for some other function? I accidentally clipped the backup light wire that goes to the integrated module from the transmission cord and I'm trying to find out if I can just tap that wire into my existing car's wires or if i need to push it down to the integrated module like it was before.
-Jon
Old 12-29-2003, 02:15 PM   #2
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Its for the rear defrost, dash lights, etc. Its like a mini-ecu to control misc functions.
I'm not sure how much of the Wrx harness you are using back, but the the majority of the wiring used should be just for the engine only.
Ver.III is offline   Reply With Quote
Old 12-29-2003, 03:03 PM   #3
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
All functions unrelated to the engine are being handled by my existing wiring. I would imagine I can bypass the integrated module then and use the older technology for running things? Rear defrost, for instance, should have its own little circuit that is already bypassing the integrated module. Dash lights the same. Backup lights are also the case, however I just need to merge my WRX stuff into the older wiring and that should work.
-Jon
Old 12-29-2003, 07:23 PM   #4
AKGC8
Member#: 1305
2000 Impreza
Yea, just check out the L's wiring diagram for where the signal wire for the backup lights was and tap the WRX's wire into that. Make sure to check the grounds too when you're integrating the harnesses. I remember there were a few that I had to reground because the L's wiring was nolonger connected to the ECU.
AKGC8 is offline   Reply With Quote
Old 01-06-2004, 01:33 AM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I will guarantee that the Integrated Module is not needed on an L
-Jon
WTB: 2002 WRX Integrated Module petridish38 Private 'Wanted' Classifieds 7 12-14-2009 10:21 AM
The Mysterious Integrated Module... WRXRgr Electrical & Lighting 2 05-20-2005 11:45 PM
WTB in CO: 02' Impreza integrated module bennettsweb Private 'Wanted' Classifieds 0 07-03-2004 06:01 PM
Integrated Module plug jumbo Private 'Wanted' Classifieds 0 12-07-2003 11:55 AM
WTB: Body Integrated Module for 2004 WRX LYHTSPD Private 'Wanted' Classifieds 0 11-19-2003 12:36 AM
Message Board Statistics All times are GMT -4. The time now is 03:10 PM.
