Old 12-29-2003, 02:51 AM   #1
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
Default P0171 CEL Thread - Everything you ever wanted to know?
More of an informational post than anything else. PAWRX on the boards here recently went through hell (and $$$) trying to diagnose his P0171 - Fuel trim malfunction (A/F too lean) CEL after de-modding from ~Stage 4 setup. With his permission, I'm going to post what he (and I) went through in addition to the stuff I dug up on NASIOC, i-club, ClubWRX, WRXHackers, ScoobyNet, and Google. I will try and list things in the most appropriate order of "what to check first." I'm probably going to miss some things, so please clarify if you have any experiences that contradict what he/we tried, or if I'm flat out wrong about anything. Without further adieu, the
PAWRX & CirrusWRX guide to troubleshooting a P0171 CEL code on a 2002/2003 WRX
First disclaimer: As with any troubleshooting, if you get this code after tinkering with something on your car, chances are the tinkering caused the code! Always look to what MOST RECENTLY changed (which can mean: installed, uninstalled, modified, etc...) when troubleshooting, no matter how remote the possibility may seem.
1. Cold air intakes. Just as the name of the CEL suggests, the ECU is sensing a lean condition. As anybody with half a search function will find, many CAI's for the WRX will cause a lean condition due in part to either relocation of the MAF, a differently sized diameter of piping, or purely increased flow of air which is not correctly compensated for. Many people who get this code get it shortly (or instantly) after installing a CAI. The CAI would be great first place to start, especially if you recently added one.
2. Stock airbox not sealed. Assuming you have a stock airbox, check the connections and tabs around the airbox itself. Many times, people think they "seal" the airbox, but don't actually have the top and bottom parts aligned correctly resulting in a leak. Check to make sure the air filter (esp. if recently replaced) is sitting in the right spot and the clamps are tight and everything is lined up properly.
3. Hose leaks, generic air leaks. Mostly in and around the intercooler, turbo, BOV, vaccum lines, turbo, etc... There is a vaccum hose coming out of a nipple on the right side of the BOV on the IC; the return/recirc. line runs off of the BOV under neath the IC to the intake. It gets pulled off easily if you remove your IC without disconnecting the BOV. There are some vaccum line connections on the turbo inlet hose. The Samco turbo inlet hose does not fit 100% perfect - there could be a small leak or tear. Check the turbo outlet, and Y connections on the IC. Check for a tear or leak or loose clamp on any replacement hoses. Check all hoses in any area where you were recently working on something. Boost gauge installation or UNinstallation. IC installation, FMIC installation/uninstallation. All those hoses need to be securely connected and routed to the appropriate places! If necessary, find a buddy with a WRX, park them side by side and trace all the lines. Chances are you would would also notice some sort of boost fluctuation/abnormality if there were a leak, but this is not always the case.
4. Fuel pressure regulator. According to the factory service manual and suby techs, the most common problem with the FPR is the vacuum connection to the intake manifold (either cracks in the hose where it makes a sharp bend, or a leaking connection.)
Occasionally, the fuel pressure regulator reference line will pop off or is accidentally left off when working on or around items located near the passenger side fuel rail. (ie. injectors, spark plugs, reaching for something...) This is a serious mess up, but one that is easily corrected.
5. Check all ground connections. While you can certainly verifiy all of them, one person mentioned specifically being able to fix their problem by checking their grounds. They discovered that the ground wire on the drivers side of the intake manifold (the bolt) was loose and was causing the P0171. Make sure that bolt, and all others, for that matter are tight. This one is somewhat random, but it's so easy to check.
6. Injector problems. I came across two people who posted about a P0171 after removing AFTERMARKET injectors and going back to stock injectors. In both cases, the stock injectors had been sitting in a box inside their houses for over a year. It was believed that the fuel had crystalized and caused a blockage of some sort on one or more of the injectors. This could potentially happen with ANY used injector that has sat for a long time. In both cases, the individuals used fuel system cleaner (is it called "heet"?) and the P0171 went away.
7. MAF sensor gone bad/dirty. This is an easy one to check if you can find somebody willing to swap MAF's for a day or two. The MAF looked good on PAWRX's car, but we decided to swap it with mine just for gits and shiggles. The process to do this is so simple, requiring a single clip and two screws. Swap MAF's with a local (and friendly) WRX buddy, reset your ECU and drive for a day or two. If you get your P0171 again, the MAF was not it. If you go CEL free, and even better, if the OTHER person gets a P0171, then you found your culprit. Either clean the old MAF or shell out the cash for a new one. In our case, PAWRX got his CEL the same way as always after we swapped MAF sensors.
8. Front oxygen (o2) sensor, located in passenger side exh. manifold gone bad. This was the final solution to PAWRX's problem. Again, we "swapped" (I didn't actually install his o2 in my car) and his problem disappeared. His o2 looked "worn" but not bad by any means. His experience with the P0171 basically had the car run fine for the first 10-15 miles until N.O.T. Then, after power cycling (shut off car for a minute, turn it back on) and driving at a constant highway cruise for a few minutes, the CEL would come back on. After checking #1-#7 above, we were left with swapping the oxygen sensor, and that was the ticket in our case. After trying a few cruises and power cycles with no CEL, he ordered a new sensor from Subaru. While waiting for the nwe sensor to arrive, he reinstalled the "bad" o2 sensor in his car and drove home. Upon starting up the next time, he got the CEL. Since installing the NEW o2 sensor 3 days ago, no CEL.
In his case, with the "bad" o2 sensor, the CEL would disappear after resetting the ECU, but would come back on after shutting the car off and cruising on the highway for a few minutes. When the CEL was on, the car would run extremely rich and dump fuel like crazy. I think he said he would see anywhere from 325-350 miles to a tank with conservative driving, and he was seeing something like 200-250 miles to the tank when the CEL was on.
9. You are truly running rich/lean and the ECU is not happy, thus the code is legitimate
There have been a few cases, noted below, when doing some type of tuning either via UTEC or a tuner with ECUTEK that results in the parameters being off scale and thus throwing the P0171. Perhaps you are truly running a bit too lean for the ECU's tastes and either the parameters for detecting the P0171 are not wide enough or your tuning is off. In the case of ECUTEK, it seems some people with DeltaDash can make some small adjustments in some cases, other cases might result in needing a professional retune (UTEC) or reflash (ECUTEK).
10. Dirty Idle Air Control Valve (IACV) - clean it out with carb cleaner or equivalent, however be sure to do this when the engine is cold so as to not cause deformation of the gasket. If you do happen to cause it to deform, a new one is about $8 from a Subaru dealership. Thanks samneric!
This is not meant to be an all-inclusive, be-all-end-all guide to the P0171, but it should be a good help for those experiencing it and banging their heads against the wall. Obviously, use your wits about you. If you have a CEL and get the code pulled, and you have 6 other codes thrown along with the P0171, you have OTHER problems that need serious attention. This is meant more for the people who randomly get a P0171 and can't figure out what they should do. PAWRX went through a lot of hell, money and effort to troubleshoot his car, and I have to be honest and say that I never thought the o2 sensor could cause something like this. Upon my research of the code, it appeared that #1-#6 were the most common reasons for getting it, but we both felt it would be worthwhile to post our experience in this matter for the good of the community. Again, any additions/corrections, please let me know and I'll edit anything ASAP.
Thanks - CirrusWRX & PAWRX
CirrusWRX is offline   Reply With Quote
Old 12-29-2003, 09:16 AM   #2
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Thumbs up
Great write up!!!
Hank3 is offline   Reply With Quote
Old 12-29-2003, 09:24 AM   #3
mixup52
Member#: 39691
2002 WRX Wagon
Here is a link to another thread about the P0171 code and the frount mount. If you go about half way down to where Phil from turboxs starts in you will see how you can throw this code as well
http://forums.nasioc.com/forums/show...hreadid=463660
mixup52 is offline   Reply With Quote
Old 12-29-2003, 12:57 PM   #4
PAWRX
Member#: 9008
2002 slvr wrx sedan
07 CBR 600RR
Just a little clarification. Excellent job Kyle, and thanks for swapping parts with me. You actually saved me a ton of money from what the dealer would have charged me in diagnostics fees. To clarify, my car actually ran fine. It wouldn't buck or stall or anything like that. It just went through gas. I was getting 200 miles per tank. That's why I really didn't think it could be the O2 sensor. All the threads i've seen in regards to O2 sensors going bad, the car would barely run. But mine ran fine. So if there is anyone out there racking thier brains over this. Do not overlook the front O2 sensor.
Ian
PAWRX is offline   Reply With Quote
Old 12-29-2003, 01:15 PM   #5
vile
Member#: 32371
'02 t-rex wagon
platinum
i'm shock about the suby service manuel, as they do not even mention the possibility of the front o2 being a culprit
they're trouble shooting steps are for coolant temp sensor, iat sensor, and maf.......
i would've thought for sure, you would include the front o2, as that is what is reporting the a/f ratio
vile is offline   Reply With Quote
Old 12-30-2003, 04:26 AM   #6
PAWRX
Member#: 9008
2002 slvr wrx sedan
07 CBR 600RR
vile- knowing what I know now I would agree. But probably 99% of the time when the O2 sensor goes bad, the car will start running really rough and crappy. Not the case here.
Old 12-30-2003, 11:44 AM   #7
dman918
Member#: 11202
2009 Infiniti G37X
Prev: 2006 STi with stuff
Any ideas on my situation? I have a P0171 that has come on ever since my fuel pump, turbo, injector, ground mod install. I have swapped the injectors, and it is still there. It comes on after about a week or two and stays on until I clear it. The car runs fine; I have not had any running issues or anything. It tends to also come on while idling at a stoplight.
I have a FMIC and a perrin short ram, and the clamps have been checked on those pieces.
Any thoughts that jump at you?
Thanks.
Mike
dman918 is offline   Reply With Quote
Old 12-30-2003, 03:00 PM   #8
PAWRX
Member#: 9008
2002 slvr wrx sedan
07 CBR 600RR
The only advise I can give is to go to the top of this thread and and start going down the list that CirrusWRX posted up. That's kinda why he posted it. to get all of the causes for this CEL into 1 thread. With my car it didn't take long to get the CEL. Just 2 driving cycles. Never got it at idle though. From your mods list I would say it could be any number of things - all of which were mentioned above. If you happen upon a new cause not listed here. Please add it.
Ian
Old 12-30-2003, 03:05 PM   #9
Full_Clip
Member#: 22218
Sticky this
Full_Clip bumps for mod notice.
Full_Clip is offline   Reply With Quote
Old 03-16-2004, 02:03 PM   #10
UURRXX_Ash
Member#: 39335
2002 WRX wagon
white
Thumbs up
wow... great post you guys... I had the code a little before I was going to put my car back to stock from stage 4 for the ref. I figured it probly wouldn't come back and 42 miles later normal cruising and the sucker popped up. Car runs fine. Slow by comparison of coarse
I will go down the list and post results. sounds like vacume lines and injector cleaner is a solid fist step. Thank you very much for all this info... There's so many possibilities I had no idea where to start.
Ash
UURRXX_Ash is offline   Reply With Quote
Old 09-27-2004, 03:52 PM   #11
wrx_snobordr
Member#: 49343
02 wrx
This is an excellent write up, thank you very much. I have a p0171 right now and took it to subaru and they told me it was because of my aftermarket cat-back. I didnt believe them seeing how ive had it on for about a year with no problems. I put my stock exhaust back on and the same code popped back up. I called them and there next excuse was it is because i have silencer removed, could be true i dont know. But upon reading this thread and checking the parts i feel i can without causing more damage i found that THEY not I, when doing my 30k overhaul just placed my stock airbox back on and ditn bother to slide to two tabs in the back under. So now i have the battery unhooked cause i was told that will clear the cel and i hope it doesnt pop back on. But is it possible that my cat back can cause my front o2 sensor to go bad?? thanks again for this write up, matt
wrx_snobordr is offline   Reply With Quote
Old 09-28-2004, 04:27 AM   #12
PAWRX
Member#: 9008
2002 slvr wrx sedan
07 CBR 600RR
I have NEVER seen a catback cause a CEL.
Old 09-28-2004, 09:18 AM   #13
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Nope - this should be it. End of story
Smack the "service manager" upside the head next time you see him/her! And I agree with PAWRX - never heard of a catback causing a CEL, nor can I imagine it causing a front o2 sensor to go bad- the only thing I can think of is if you shoved banana's or melon's in there to block it off, but that's just retarded. Otherwise, you can run without a catback if you want to... of course, the floor might get a little warm... and the car might be a little loud... but doing any of that shouldn't cause your front o2 sensor to do anything differently.
Sounds like you're right on the money with disconnecting the battery for a little bit. That should clear your code, and you'll know within a few driving cycles whether or not you "fixed" (their) your problem!
Old 09-28-2004, 07:55 PM   #14
wrx_snobordr
Member#: 49343
02 wrx
So its been 24 hours, some city driving, 2 highway trips and a short trip up to best buy. No CEL light and i appear to get better gas milage. When i had the light it was sucking up a quarter tank on one trip up and back to the city, roughly 50 miles. Thanks again for those who wrote the thread, and all others who put in info.
matt
Old 11-01-2004, 08:08 PM   #15
tjamz
Member#: 26325
2002 Impreza WRX
I first got this CEL shortly after a trip to the dyno. During the dyno runs they hooked up the WB O2 sensor in the front stock O2 sensors location. Is it possible that I am getting this code due to a leak? I have tried resetting the ECU, deleting the code, etc... but it always comes back, usually at idle. Any thoughts on this?
tjamz is offline   Reply With Quote
Old 11-02-2004, 08:50 AM   #16
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Was ANYTHING else done on the dyno AT ALL? When it comes back, is it at idle right after you turn the car on? Do you drive for a bit and THEN does it come on? Give a little more detail. Likewise, who tuned your car? Is there a chance your car is running way too lean and the code is truly telling you something that's "accurate"?
It's also possible the uninstall/reinstall damaged the o2 sensor. LOTS of possibilities, but you are on the right track focusing FIRST on "OK - what changed most recently?" And go from there. Did they mess with your airbox when on the dyno? Possibly bumped something or a clip? etc...
Old 11-02-2004, 12:29 PM   #17
Raslian
Member#: 18801
1994 Toyota Supra
Red
After my Stage 4 install, the car was only running rough at idle, and seemed to be running normally otherwise. I threw the P0171 CEL, and had everything checked over. Turns out I had the FPR disconnected and/or leaking as said above. So to anybody that has a rough idle make sure to double check the fuel pressure regulator.
Raslian is offline   Reply With Quote
Old 11-02-2004, 12:50 PM   #18
tjamz
Member#: 26325
2002 Impreza WRX
I was tuned at the dyno, that is it, no parts added/removed. AFR @ idle is 14.5 to 15.0 according to my UTEC. If I let the car sit for 3 minutes idling it will come on, if I drive it I can get a few miles on before it comes on. I will give my full list of mods:
UTEC
TXS BOV
APS DR650
APS CAI
Walbro Fuel Pump
Perrin Up-pipe
PDE Downpipe
3" Catback to Apexi N1
Modded injectors
Grounding Mod
FP 18G
Blitz SBC-ID Boost Controller
I am going to pop out the O2 sensor today and check it out. Also, I'm going to try cleaning the MAF
Old 11-02-2004, 04:13 PM   #19
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
or you can swap MAF's with somebody in your area for an hour or two
But either way, I'd still look at the o2 first because THAT is what was touched, not the MAF.
Old 11-02-2004, 04:28 PM   #20
linkbeat
Member#: 6095
2008 WRX STI
Great writeup! This also applies to other OBD2 vehicles. I got this error on my old '99 Tacoma 4x4. The solution was simple.
I had used a K&N drop in filter in the stock Tacoma intake, and after about 15k miles I got this CEL. I was worried I needed a new O2 sensor (not cheap.) But after doing some searching I found info that suggested that K&N filters have a tendency to dirty up MAF sensors. I bought a cheap can of auto electronics cleaner and cleaned up the MAF sensor. Voila, no more CEL.
So if you're using an aftermarket (especially oil based) air filter, you might try looking at the MAF sensor first.
linkbeat is offline   Reply With Quote
Old 11-02-2004, 04:45 PM   #21
Jasvboost
Member#: 37160
RIP 04 Stg2 JBP WRX
07 SWP WRX 335/350 HTA68!
Have a Nice Day?
When I got the P0171 code I had a K&N drop-in and a Borla Hush CB on. Before taking the mods off I got the A/F sensor replaced under warranty. The car still wasn't running 100%. I took the mods off at the insistence of the dealer. It wasn't till I did remove them and went back, with the CEL still on, that they discovered it was now throwing the MAF code P0101. I found it strange that both needed to be replaced but the car's been running fine since.
Jasvboost is offline   Reply With Quote
Old 11-03-2004, 11:58 AM   #22
Hal
Member#: 6133
WR Blue
CirrusWRX, thanks for posting this. I've had this problem intermittently for about a year. I've cleaned the maf and replaced my ScoobySport catback with OEM. At one point it actually went away (CEL went off while driving), but now it's back. I'll reset the code and it'll return a few days to week I'll go through the steps above and report back. What's interesting is that it seemed to happen after Subaru put in a new fuel line (for the infamous gas smell problem). I'll be looking at the FPR item first.
Hal
Hal is offline   Reply With Quote
Old 11-07-2004, 10:41 PM   #23
tjamz
Member#: 26325
2002 Impreza WRX
Ok, update on my situation. I double checked my logs and found that I was in fact running a little lean at idle. I feel sorta embarrassed but I still think this is a great thread and I hope it can help others out there. I did clean my MAF as well, it was a tiny bit dirty, but not too bad.
Old 11-08-2004, 10:50 AM   #24
Noogin
Member#: 67290
02 WRX Sdan w/mods
Thank you, Thank you, Thank you, Thank you, Thank you,Thank you,Thank you,Thank you,Thank you. I can't say thanks enough for this thread because i have had a p0171 for a while and i never knew how to fix it. I do have a couple of questions when troubleshooting this problem. 1.) Are 02 and 04 maf and front 02 the same?(meaning that i can swap them to see if they are bad). 2.)and when you clean the maf, what do you use to clean it?
Thanks again
Noogin
Noogin is offline   Reply With Quote
Old 11-09-2004, 10:37 AM   #25
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Nothing embarassing! Hell, I remember freaking out because my parking lights wouldn't turn off... damned that little switch on top of the steering column! It's actually somewhat unique that an error code is actually REPORTING the error it was meant to report! So often, a code gets thrown that is related to something entirely different, but in your case, sounds like you might have just been running a bit too lean?
noogin - not sure if they are identical, but I am willing to bet they are. I think it would be safe to compare them side by side and if they look the same, they are the same. You could try doing some more searching on NASIOC, or just pick up the phone and cal a local subie dealership, ask to speak to the parts department, and get them to look up the part # for an 02 MAF and an 04 MAF. The guy may just say, "Oh - they're the same" or he'll look them up, and if they're the same part number, you're golden. I'd bet they are though, but I am only one small mind.
To clean it, you can use carb & injector cleaner from any auto parts store. Be careful as they are fragile little creatures. Here is a somewhat funny page about general MAF cleaning on a Ford Scorpio - the principal is the same though. Good luck! Remember, it could be ANYTHING, but the MAF is a good easy one to start with.
Everything you ever wanted to know about anything ever made......ever Hester Prynne Off-Topic 12 11-05-2008 05:57 PM
OT Non-Gun Nuts: Everything you ever wanted to know but were afraid to ask (or try) Janq Off-Topic 47 12-29-2006 01:23 PM
Everything you ever wanted to know about exaust systems Back Road Runner Normally Aspirated Powertrain 9 10-24-2006 09:59 PM
('93-'01) Everything you ever wanted to know about Subarus... Porsche914boxer4 Impreza Forum 15 07-23-2001 09:17 PM
Everything you ever wanted to know about WRX exhauasts (old model) --> rao Normally Aspirated Powertrain 5 02-12-2001 08:56 PM
Message Board Statistics All times are GMT -4. The time now is 10:49 PM.
