Old 08-03-2011, 06:49 PM   #426
ganzhimself
Member#: 252648
2010 Mini Cooper
Pepper White
Originally Posted by corzy666 View Post
Well, turns out my driver side IM gasket is blown... sprayed some carb cleaner there and rpms dipped and AFR went from ~17 to ~13 to try and save it from stalling.
Looks like I know what I'll be doing tomorrow.
That sucks. At least you found your problem. Remember to clean all the mating surfaces really well or you'll be doing them again in short order.
ganzhimself is offline   Reply With Quote
Old 08-03-2011, 07:51 PM   #427
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
It took me more than an hour to thoroughly clean all surfaces when I had IM gaskets replaced. Take time.
Old 08-04-2011, 05:37 PM   #428
corzy666
Member#: 177840
2000 swapped RS
White 330whp
Valuable lesson learned today... I thought my IM upper gaskets were shot, so I tried only taking the intake manifold off without the TGVs and well.... it's pretty much impossible.
I also found out a good thing by taking the whole assembly off too, my upper gaskets are fine, but my TGV -> block gaskets are shot on the driver side.
Now I have to pick up those gaskets from the dealer tomorrow.
corzy666 is offline   Reply With Quote
Old 08-04-2011, 06:08 PM   #429
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
CEL is back even after all these.....
New O2 and coolant temperature sensors
MAF sensor from 07 STI
Low mile FPR, MAP sensor.
Last thing I am going to try is installing flow tested / cleaned pink injectors before bringing my car in to the dealer.
Old 08-05-2011, 06:18 PM   #430
corzy666
Member#: 177840
2000 swapped RS
White 330whp
Everything back together, and it runs great. AFR and psi at idle is perfect.
Just went out for a test drive and nothing went wrong, and no CELs.
Old 08-07-2011, 12:38 PM   #431
vien
Member#: 221538
2003 wrx/ylw wheels
darkness.................
i keep getting this code and so far all my connections are clammped down, the o2 is new, and i get rough bouncing idle at start up but its perfect after its warmed up. and the code only pops up after driving a long way after i reset the ecu with my cobb ap
vien is offline   Reply With Quote
Old 08-07-2011, 03:31 PM   #432
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
updated......
Old 08-09-2011, 05:03 PM   #433
vien
Member#: 221538
2003 wrx/ylw wheels
Originally Posted by txl146 View Post
im confused what you are inplying?
Old 08-09-2011, 05:33 PM   #434
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
List of actions I have done on my car to eliminate P0171. So far no luck.
Old 08-09-2011, 07:12 PM   #435
pDubs
Member#: 149317
'95 BMW M3 (E36)
'05 Kawi ZX6R, '73 CB350F
Car throws cel when cruising on highway is the same situation I'm in.
pDubs is offline   Reply With Quote
Old 08-10-2011, 06:44 PM   #436
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Guys, here is an update.
Before throwing on a set of flow tested injectors, I decided to give one more try by installing another 07 STI MAF sensor.
Amazingly, car did not throw CEL and my OBDII reader is showing all as being "READY", which has never happened before. Always had 2 or 3 showing up as not being ready.
Probably too early to tell, but it's certainly encouraging news.
Old 08-11-2011, 02:46 PM   #437
vien
Member#: 221538
2003 wrx/ylw wheels
good stuff, i figured what my problem was it wasnt getting solid ground on my intake manifold since it was powder coated so i sanded down the powdercoat and hasnt come on so far and plus i realized my start up issues is because of my tune i have the ap stage 3 map but i dont have tgv anymore but i left the rods in there to make believe its still there so i only have a weird iddle at start up but so far no cel
Old 08-11-2011, 09:49 PM   #438
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Drove on highway again today and incredibly CEL didn't come on again!!!
Turned out that I had 2 bad MAF sensors: 1) 02 WRX and 2) 07 STI.
Old 08-12-2011, 05:46 AM   #439
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
I'm glad you fixed it. There is something depressing about the way this code keeps coming back.
Old 08-12-2011, 12:44 PM   #440
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Thanks - you must wake up early as your post was from 5:46AM.
Glad I got one issue resolved; next is fixing thumping noise from rear suspension, which has been another 6+ months problem.
Old 08-15-2011, 02:29 PM   #441
vien
Member#: 221538
2003 wrx/ylw wheels
i got the codes again i dont know why but i either get p0171 code or i get the p0133 which is bank one slow response idunno what to do my o2 is fairly new 25k on it and my maf works perfect
Old 08-15-2011, 03:25 PM   #442
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
There are at least 5-6 other things besides MAF or O2 you should check. Did you read the first page or review process diagram I posted?
Old 08-15-2011, 03:27 PM   #443
vien
Member#: 221538
2003 wrx/ylw wheels
yeah i basically did everything you did lol exept for the new maf part cuz mine is still working properly
Old 08-15-2011, 03:28 PM   #444
vien
Member#: 221538
2003 wrx/ylw wheels
yeah i basically did everything you did lol exept for the new maf part cuz mine is still working properly, its weird to because the car drives perfectly fine boosts normal drives normal and all its just annoying though those codes
Old 08-15-2011, 03:32 PM   #445
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Don't just assume your MAF sensor is good - I've had 2 bad MAF sensors.
Old 08-15-2011, 06:43 PM   #446
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Easiest method in my opinion is to use tactrix cable to check all sensors. You can buy a basic cable from eBay for $50, which is what I have.
Old 08-15-2011, 08:54 PM   #447
vien
Member#: 221538
2003 wrx/ylw wheels
yeah but i have the cobb ap, but can i use the tactrix cable?
Old 08-15-2011, 10:14 PM   #448
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
yes you can.... just use enginuity or ECUexplorer to do data logging.
Old 08-15-2011, 10:35 PM   #449
vien
Member#: 221538
2003 wrx/ylw wheels
cobb ap has that data logging option aswell should i just try that first?
Old 08-24-2011, 05:06 PM   #450
jeffwhite07
Member#: 292414
2004 wrx 2.0 turbo
wrb
Default some one please help me p0171 problem
i got my 2.0 turbo wrx a few weeks ago i started off with putting on a brand new injen short ram intake and everything ran great later a week later i bought a perrin inlet turbo hose for it and got in on my car ran great for a few day then the p0171 ce light came on is this due to the inlet pipe? what could be my problem my wrx is a 04 and has less then 60k some one please help me!! oh and i have no loss in power and the code said sytem lean bank 1 help me please
jeffwhite07 is offline   Reply With Quote
Everything you ever wanted to know about anything ever made......ever Hester Prynne Off-Topic 12 11-05-2008 05:57 PM
OT Non-Gun Nuts: Everything you ever wanted to know but were afraid to ask (or try) Janq Off-Topic 47 12-29-2006 01:23 PM
Everything you ever wanted to know about exaust systems Back Road Runner Normally Aspirated Powertrain 9 10-24-2006 09:59 PM
('93-'01) Everything you ever wanted to know about Subarus... Porsche914boxer4 Impreza Forum 15 07-23-2001 09:17 PM
Everything you ever wanted to know about WRX exhauasts (old model) --> rao Normally Aspirated Powertrain 5 02-12-2001 08:56 PM
