Old 11-09-2004, 12:45 PM   #26
spankaveli
Member#: 42826
1999 Toyota Corolla
Tan
great info
spankaveli is offline   Reply With Quote
Old 11-21-2004, 02:30 AM   #27
Russ77
Member#: 69369
this problem came up for me today, after removing a vf34 and stock injectors. i'm going to try the injector cleaner tomorrow.
Russ77 is online now   Reply With Quote
Old 11-23-2004, 02:37 PM   #28
Hal
Member#: 6133
WR Blue
CirrusWRX, I'd like to thank you again for posting this thread. I looked at the FPR and indeed the little vacuum hose was not attached to the manifold. The CEL went out immediately when the hose was connected.
Hal
Hal is offline   Reply With Quote
Old 11-23-2004, 10:55 PM   #29
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
It makes us happy to give back to the community which has given so much to us!
I know this FAQ isn't a be all end all, silver-bullet for the P0171, and there are bound to be incidents which are going to be solved by doing something not on the list, but hopefully, in most cases, this should solve a majority of them- glad to hear you were one of them!
CirrusWRX is offline   Reply With Quote
Old 11-24-2004, 12:34 AM   #30
Russ77
Member#: 69369
tracking my code down was very very simple. at the time of de-modding my car, we weren't able to reflash it that day, so we adjusted the fuel scaling via DeltaDash to be close to what it should be. apparently, the ecu didn't like that. it was clearly running nice and rich like it should, but the ecu was unhappy for some reason and kept throwing this code.
got it flashed yesterday and it runs like a champ.
Old 11-24-2004, 09:36 AM   #31
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Russ - added your comment as a #9 up top. Somebody else in person told me they had an issue with their UTEC. As it turns out, he self-admittedly didn't know what he was doing, as told by his tuner when he went to go get it professionally tuned. He was just running lean and was legitimately throwing the code.
I'm no tuner and haven't the foggiest about understanding ECU parameters, but seems like it might be yet another way to get this thing to show up. Glad you got yours figured out!
Old 11-24-2004, 01:16 PM   #32
Russ77
Member#: 69369
CirrusWRX, you may want to add to #9 that ecutek users not remove larger injectors and replace them with stockers unless they can immediately get reflashed. what we did was take an ecu that was tuned for the STi pinks and then adjusted via DD live tuning to be scaled for the smaller stockers. this was a band-aid to get me to work (although very slowly) until it could be flashed. i was legitimately running the same AFR's as i otherwise would have, but the ecu was unhappy with something causing the code. i was also triggering MAF sensor failure codes at the same time.
Old 12-19-2004, 05:01 PM   #33
redobs
Member#: 1501
2009 WRX wagon
Dark grey
Great write up! I just went back to stock injectors and was getting this CEL!
redobs is offline   Reply With Quote
Old 12-22-2004, 12:17 PM   #34
samneric
Member#: 52625
Default My P0171 Story
Great guide - real neat idea that we have all these possible causes on one thread.
My P0171 story goes as follows:
Car started idling rough around 25,000 miles. Knew from previous car that air sensors get dirty so I tracked down the IACV solenoid and cleaned it with carb cleaner. I cleaned it when the engine was warm and the IACV gasket did seem mis-shapen.
Anyway, idle problem would come and go - one day fine, next day problems. This situation continued and I didn't have chance to look at it for 3 months.
Thing that brought mine to a conclusion was when my car started overheating! - I was losing coolant.
Turns out that the IACV gasket must have been leaking water into the air intake. I bought a new gasket and haven't had problems with idle since.
Moral of story is - either clean IACV when engine is cold (so gasket doesn't get misshapen) or buy a new IACV gasket ($8) when cleaning the IACV.
Steve
samneric is offline   Reply With Quote
Old 12-22-2004, 01:29 PM   #35
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Thanks Steve - added it as #10 up top!
Glad you got it figured out!
Old 01-22-2005, 12:05 PM   #36
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
ok. i have code P170. fuel trim malfunction. im working on that problem...
but how do you clean the MAF? alot of people say to clean it but no one says how...
t3hWIT is offline   Reply With Quote
Old 01-22-2005, 01:10 PM   #37
tjamz
Member#: 26325
2002 Impreza WRX
electronic parts cleaner, as discussed earlier in the thread, works well.
tjamz is offline   Reply With Quote
Old 01-22-2005, 01:17 PM   #38
t3hWIT
Member#: 58779
95 STi RA (rhd)
would you suggest anything? im a lil fuzzy on the cleaning product stuff.
could it be bought at autozone, or do i have to go somewhere like walmart?
Old 01-22-2005, 01:27 PM   #39
tjamz
Member#: 26325
2002 Impreza WRX
think I bought mine at autozone or someplace like that
Old 01-22-2005, 02:06 PM   #40
t3hWIT
Member#: 58779
95 STi RA (rhd)
sweet. thanks dude. i think ill be called in there tomorro(to work for someone(snow)) so ill pick some up then.
i appreciate the help
Old 05-09-2005, 04:27 PM   #41
crank0r
Member#: 73983
2002 Impreza WRX Wag
got this code during a track day on sunday, just about to go out and try to diagnos it using this write up, thanks in advance for the info and ill let u know what it turned out to be...
crank0r is offline   Reply With Quote
Old 05-09-2005, 06:11 PM   #42
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Good luck, let us know!
Old 05-09-2005, 08:58 PM   #43
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
i am surprised that this thread is not a sticky?? So many people get the code, and if not for this thread, would still be pissing in the wind....
jigga is offline   Reply With Quote
Old 05-10-2005, 05:29 AM   #44
crank0r
Member#: 73983
ok well first i cleaned the maf, then i went to look for leaks and noticed the vacuum hose from the bov to the intake had blown off on the intake side. It didnt seem to fit very well so i went and got a new longer hose, cleared cell and so far after 50 miles or so still isnt back on, the previous time i cleared it, it reapeared after only a mile so i think i fixed the problem with the hose. If for some reason it comes back on ill let u know, thanks again for the write up...
Old 05-10-2005, 09:36 AM   #45
vile
Member#: 32371
'02 t-rex wagon
platinum
i briefly got this code after an install of pnp manifold......cleared the code and never came back since
i think the motor was just getting use to the higher effeciency of the pnp mani
vile is offline   Reply With Quote
Old 05-10-2005, 10:06 AM   #46
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Totally- something like that, OR might have gotten a little bit of gunk of the o2 sensor when you unplugged it, plugged it back in, and it just burned off after a session.
crank0r:
Sounds like you got that one nailed down. I'd be 99% certain that you found and fixed your issue. Be honest now, how long did it take? Finding a disconnected hose usually takes 30.6 seconds or about 5 hours... which one was it?
Old 05-25-2005, 01:21 AM   #47
RRRR1
Member#: 51329
2002 WRX SEDAN
WHITE
Dude you put some time into that
This is now an issue with myself.
When I figure it out I'll drop back in and tell you all about it>
RRRR1 is offline   Reply With Quote
Old 05-25-2005, 10:47 PM   #48
Lowball
Member#: 24198
02 WRX Sport Wag
Black to reality.
I got the same code after getting re-tuned for 95 oct. I kept getting P0171. I'm planning on replacing the A/F sensor in the passengers side exhaust header. My tuner spoke with Ecutek and they said that that code seems to come up when that sensor starts going bad...
You guys know if that is true or not???
Update:
I replace the sensor and still got the code. Not sure what else it could be
Lowball is offline   Reply With Quote
Old 05-26-2005, 04:29 AM   #49
PAWRX
Member#: 9008
2002 slvr wrx sedan
07 CBR 600RR
True for me
PAWRX is offline   Reply With Quote
Old 06-23-2005, 12:31 PM   #50
PharmCo
Member#: 11443
Midnight Black
I've gotten this code after going from Stage 4 back to stock. Using Delta Dash I'm seeing very high AFR on boost like 20-25 when I'm at 10psi. Idle AFR seems about right at 14-15. Does this sound like the 02 or something else? I've tried fuel cleaner and I've checked all my hoses. Thanks!
~PC
PharmCo is offline   Reply With Quote
Everything you ever wanted to know about anything ever made......ever Hester Prynne Off-Topic 12 11-05-2008 05:57 PM
OT Non-Gun Nuts: Everything you ever wanted to know but were afraid to ask (or try) Janq Off-Topic 47 12-29-2006 01:23 PM
Everything you ever wanted to know about exaust systems Back Road Runner Normally Aspirated Powertrain 9 10-24-2006 09:59 PM
('93-'01) Everything you ever wanted to know about Subarus... Porsche914boxer4 Impreza Forum 15 07-23-2001 09:17 PM
Everything you ever wanted to know about WRX exhauasts (old model) --> rao Normally Aspirated Powertrain 5 02-12-2001 08:56 PM
