Old 09-01-2013, 04:48 PM   #551
veritasaequitas
Member#: 333964
2005 sti
aspen white
I have this code and its driving me nuts. I smoked the exhaust and found cracked headers so replaced them with no luck. smoked the intake system and performed a boost leak. no problems. cleabed the mass air flow. no luck. is it a chance that my oxygen sensor went bad due to the exhaust leak and cause this code but no oxygen sensor code?
veritasaequitas is offline   Reply With Quote
Old 09-03-2013, 06:23 PM   #552
veritasaequitas
Member#: 333964
2005 sti
aspen white
Forgot to mention it is running rich as a pig due to it trying to fix the "lean" condition. Wideband shows 10.5-10.8 during cruising speeds. mods are tomei expreme headers and up pipe, ap hard turbo inlet, invidia catless bellmouth dp, invidia g200 catback, cobb ots stage 2 map, doubt it matters but car is sitting on tein springs.
Old 09-06-2013, 07:42 PM   #553
Anthonyaa2
Member#: 367657
nice!
Anthonyaa2 is offline   Reply With Quote
Old 10-05-2013, 11:52 PM   #554
ImprezaRSti
Member#: 222677
2016 Wrx
World Rally Blue Pearl
Got this code today and i have no idea why. Idle is normal, boost is normal. I washed my car today at work through our drive thru car wash. Driving home light came on cleared light via access port. Drove 20 miles and its pending but hasnt set. Went back to work cleaned the MAF Sensor.Cleared it again and now pending. Have been looking for vacuum leaks none found.
Current mods:
gfb bov set to 50/50
Turbo back exhaust
Deastchwerks fuel pump
Tune
Aem Cai
2009 sti w/ 36k miles
ImprezaRSti is offline   Reply With Quote
Old 10-08-2013, 01:20 PM   #555
Timmy_M2000
Member#: 289514
2003 WRX Sedan
Ralley Blue
The cai can cause it, as well as exhaust leaks.
Timmy_M2000 is offline   Reply With Quote
Old 10-14-2013, 02:01 AM   #556
SnowDuner02
Member#: 360519
2002 Impreza wrx
Midnight black pearl
My P0171 goes on and stays off for about 200 miles sometimes more than comes back on.
SnowDuner02 is offline   Reply With Quote
Old 12-05-2013, 11:30 PM   #557
turbomacharged
Member#: 375426
2005 Legacy GT
Default Thanks a bunch
I created a profile on this site so I could say thanks. I appreciate the time you took to share your learning for the benefit of others.
In case anybody was wondering all the same goes for the Legacy GT. Here's my P0171 story. About three weeks ago I got a P0171 and checked all the easy culprits. Vacuum Hoses, filter box, visual checked the MAF sensor. The next day my radiator exploded on the freeway (completely unrelated, I assume), and while I had things apart I again checked all the hoses I could find, and even bought some MAF cleaner and drowned the sensor.
After changing the radiator out the CEL went away for a couple of weeks. Then, the day after Thanksgiving I was headed down the freeway and noticed that my instantaneous MPG reading was 4 to 6 MPG low. I went for about 40 or 50 miles that way before the CEL came back. I racked my brain and nearly exhausted my google searching ability before I came across this thread.
After checking most all the other options I concluded that it must be the O2 sensor. I don't have a Subaru buddy that I can swap parts out with (My little brother with a Leggy GT lives in Cali) so I took a chance and bought the part on Amazon. As of a few days later all seems to be normal, fuel economy has returned to normal, and I'm happy.
Thanks again for your thread. Much appreciated.
Ian
turbomacharged is offline   Reply With Quote
Old 02-21-2014, 05:21 PM   #558
qtr_wrx
Member#: 109567
So I have a cel on my 07 sti about 2 days ago.
I left home to work and it was perfectly fine. Then when I started my car again to get back home, I just noticed that the way my engine sounded is not as before and somehow my afr gauge showing 16~16.5 !!! drove the car slowly and when cruising my afr is perfect (14.5 to 14.9) yet no cel.
Then when I reached home cel came on, and my car idel is hunting a little bit! afr were 16~16.5 and when I blip the throttle it pick up rpm normally, but then gose all the way down to 300~200 rpm for 1 sec then back to 900 rpm.
so bad o2 sensor is ruled out as what I think its functioning correctly, because I have external arf gauge.
vaccum reading at idel fluctuatuing between 18.75~18.9 inHG
fuel pump, spark plugs, injectors (denso 1000cc) are new with less than 1500 miles
one thing before this P0171 cel, that I was trying to solve rich afr reading at wot I do hit target boost (too slow at ~ 5000 rpm) and my afr become rich past 4500 rpm giving reading of 9.5~9.6
its boost leak issue but just want to share the history
anyway what to look for solving P0171?
qtr_wrx is offline   Reply With Quote
Old 06-06-2014, 09:53 AM   #559
jzengotita90
Member#: 352421
2006 wrx tr
obsydian black bedliner
Ive done everything, tried new pumps checked for exhausts and intake leaks changed my fuel pump and filter changed both my afr and 02 sensor and maf sensor and still nothing. l cant log my wideband because a pin broke out so i have to fix that. But narrow band reads rich when cruising and lean when accelerating and the car pops and bucks really bad. Car has vf48, full catless turbo back and 2 in up pipe, 825cc modded stock injectors, perrin turbo intake pipe with hks filter, hks ssqv bov, and tgvs deleted. It was tuned in texas 3 years ago and ive had it in italy for a year and the code just started this past sunday after a 3 hour drive.
jzengotita90 is offline   Reply With Quote
Old 06-06-2014, 09:58 AM   #560
wrxthomas
Member#: 388099
2005 WRX
I've been fighting with this code for about a month now. I thought it may have been an o2 sensor and I get that replaced but the CEL still came back. I suspect it could be my short ram intake could be causing it since I haven't gotten a tune for it.
The only mods I have for it are catback exhaust, the short ram, and an up pipe. Any suggestions on what it could be? I'm going to try to remove the short ram this weekend and replace it with a stock airbox to see if that makes it go away.
wrxthomas is offline   Reply With Quote
Old 06-06-2014, 10:00 AM   #561
1 sic 04wagon
Member#: 359712
04 Wrx wagon
Metallic Silver
Boost leak , bov not seating. , there r two wires deep inside the mag that require attention sparky cleaner in there and let sit. Do not emerge sensor in fluid that's a quick way to kill it
1 sic 04wagon is offline   Reply With Quote
Old 08-21-2014, 02:47 AM   #562
802coma
Member#: 399510
So I am having this problem on my mothers 06 legacy gt. Ive checked the vacuum hoses, sprayed the intake manifold down with carb choke cleaner to find any leaks and nothing. Also cleaned the MAF and my parents have ran 2 tanks of injector cleaner and still having issues. Car will buck on light acceleration between 2500 and 3000 rpms...I threw it on a snap on diag tool. What are the o2 readings supposed to be? Im getting 2.7ish volts on one and .8 on the other...any help would be much appreciated.
802coma is offline   Reply With Quote
Old 08-24-2014, 05:08 PM   #563
rglap92x
Member#: 398998
05 92x aero
black
The fix for my PO171 cel, was replacing the maf meter. I checked everything, also cleaned the old maf meter a couple of times. Code always came back, But replacing it,
did it.
rglap92x is offline   Reply With Quote
Old 09-30-2014, 08:05 PM   #564
adm5151
Member#: 364543
'08 WRX Sedan
Great post! I removed my CAI and connected a PVC pipe with an industrial air fitting. I then hooked it up an air compressor with 20 psi and instantly heard a leak by my innercooler. Ended up being the coupler between the innercooler and intake manifold. I bought a perrin silicon coupler to fix it.
adm5151 is offline   Reply With Quote
Old 10-15-2014, 12:09 PM   #565
imaginbaru
Member#: 397216
Default ECU too
Had a p0171 code with PFFFE for multiple misfires recently. Turned out that the ECU had gone bad, causing a misfiring issue.
imaginbaru is offline   Reply With Quote
Old 10-30-2014, 10:32 AM   #566
wrxthomas
Member#: 388099
2005 WRX
Still have this code driving me crazy. I've replaced my up pipe, switched back to my stock intake, cleaned my MAF sensor, and replaced my front o2 sensor to try to resolve. The code comes on when I'm crusing at highway speed and sometimes it even disappears but always comes back. The car bucks under boost at like 2500-3000 rpms sometimes.
Possible its a bad MAF since the code is on and off? Could it be a tear in the turbo inlet?
So frustrated lol
Old 10-30-2014, 03:48 PM   #567
AlexWRXbruh
Member#: 373710
2002 Subaru WRX
Porsche White
You can nearly bet on it, i replaced mine, no more code. Happy boosting!
AlexWRXbruh is offline   Reply With Quote
Old 10-31-2014, 10:30 AM   #568
wrxthomas
Member#: 388099
2005 WRX
Are you refering to the replacing MAF sensor or inlet??
Old 10-31-2014, 10:39 AM   #569
AlexWRXbruh
Member#: 373710
2002 Subaru WRX
Porsche White
Default P0171 CEL Thread - Everything you ever wanted to know?
The maf, sorry. If ur inlet has leaks you MUST replace it...apparently the vacuum of the turbo will bring in crazy amounts of "unmetered" making you run lean.
If your AFR's are crazy high revving at idle, but the car idles around 14.7:1, suspect the maf first. According to Brendan at Bren Tuning, the only accurate way to be sure the maf is faulty is by swapping a known good one into the car...this is because the maf will read the exact way that it should, voltage will be good, and the CEL will rarely come up based on both of those facts...this is the case for a maf that simply got old and died. Most ppl eff up the maf by touching it, cleaning it incorrectly or dropping it and thinking "its okay"...
Old 10-31-2014, 10:53 AM   #570
wrxthomas
Member#: 388099
2005 WRX
My car sits and revs at idle pretty normally and really has no problems with drivability or anything just the bucking under boost issue. I'm gonna see if I could use my buddy's MAF sensor off his bugeye before I replace it. I noticed a tear on my inlet where the clamp goes and tried to seal it so eventually I am planning on replacing it, I just want to get rid of this pesky light first.
I appreciate your help my friend I'll post up my results when I replace the sensor.
Old 10-31-2014, 11:42 AM   #571
AlexWRXbruh
Member#: 373710
2002 Subaru WRX
Porsche White
Happy to help. Jus so you know, Your still gonna have a CEL...huge vacuum leaks by ur turbo will throw a p0171 just as easily
Old 12-03-2014, 02:57 PM   #572
MSo
Member#: 5008
2002 /06 STi GGA
SRP
good tread, informative!!!!
MSo is offline   Reply With Quote
Old 12-22-2014, 11:11 AM   #573
MSo
Member#: 5008
2002 /06 STi GGA
SRP
good tread!
Old 01-18-2015, 06:28 PM   #574
daywalk3r
Member#: 411228
2005 wrx sti
Obsidian black
Stock 05 sti p0171 and p0301-p0303..? Maf cleaned and plugs changed. Code still came back. Warranty doesn't cover any sensors or diagnostic fees. And I found out that before I bought it they put a short block in it from it running lean. Any help would be great...
Sent from my SM-N900V using NASIOC mobile app
daywalk3r is offline   Reply With Quote
Old 02-09-2015, 08:41 PM   #575
cam2708
Member#: 409726
Default got the same problem
my 06 WRX has a CEL with Multiple codes.. sometimes it has just P0301 and P0171.. but then when i clear it and it comes back its different cylinder that misfire 2 3 & 4 then it says full pressure also.. idk if it could be my ECU or something is really wrong with my car lol
cam2708 is offline   Reply With Quote
Everything you ever wanted to know about anything ever made......ever Hester Prynne Off-Topic 12 11-05-2008 05:57 PM
OT Non-Gun Nuts: Everything you ever wanted to know but were afraid to ask (or try) Janq Off-Topic 47 12-29-2006 01:23 PM
Everything you ever wanted to know about exaust systems Back Road Runner Normally Aspirated Powertrain 9 10-24-2006 09:59 PM
('93-'01) Everything you ever wanted to know about Subarus... Porsche914boxer4 Impreza Forum 15 07-23-2001 09:17 PM
Everything you ever wanted to know about WRX exhauasts (old model) --> rao Normally Aspirated Powertrain 5 02-12-2001 08:56 PM
