Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 01-23-2007, 01:41 PM   #76
thejean
Member#: 17763
Check the intake manifold... I had a blown hose on my EGR valve. Got the CEL under vacuum.
thejean is offline   Reply With Quote
Old 01-23-2007, 02:29 PM   #77
MidRex
Member#: 32841
2007 STI (Sold)
03 WRX FP Green PPG (RIP)
I'm wondering if the front O2 could possibly throw P0172 also. I've checked everything else and still get it.
MidRex is offline   Reply With Quote
Old 01-23-2007, 02:57 PM   #78
thejean
Member#: 17763
Yes it can.
Old 01-23-2007, 03:14 PM   #79
MidRex
Member#: 32841
2007 STI (Sold)
I was wondering because it doesn't seem to matter what I do with my tune (UTEC). Even if I leave the ECU in control up to 50% TPS, I still get the code. I guess you get it when you max out your trims to LTFT -25%.
Old 03-22-2007, 06:21 PM   #80
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
bump for more info!
anthonyrb98 is offline   Reply With Quote
Old 05-17-2007, 09:08 PM   #81
probot757
Member#: 148940
2016 WRX STI
Thanks for the excellant write up. I just got my scooby wagon and it is already throwing this code. I was about to smash my head into a brick wall, but now I have a general direction to work with. Thanks again..
probot757 is offline   Reply With Quote
Old 05-18-2007, 10:11 AM   #82
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
Yeah unfortunately there are a LOT of general directions and it can be a royal PITA tracking these buggers down, but at least a majority of them don't cost much money if anything at all, but they do cost time.
Good luck! As always, please post up your results if you find anything in the list or anything not already in the list.
CirrusWRX is offline   Reply With Quote
Old 07-02-2007, 12:04 PM   #83
Vinnyzwrx
Member#: 143616
2014 STI
WR Blue
nice thread
Vinnyzwrx is offline   Reply With Quote
Old 07-05-2007, 01:27 PM   #84
scoob-noob
Member#: 151603
Thumbs up Thank You, Thank You, Thank You!!!
First want to thank everybody in this community, it really feels like Subaru owners very genuine people.
If you don't want to read my ranting just skip to the last paragraph.
Thanks PAWRX & CirrusWRX, i've been wrestling with the P0171 issue for almost a year now. Before the CEL P0171 first came on I brought my 03' WRX in to the Subaru shop to get another CEL resolved. My Subaru mechanic replaced a fuel sensor on top of my fuel tank. About a month later I get a CEL and my car was driving real sluggish with very choppy acceleration above 3500 rpm. I brought my car back in and they told me I needed a new fuel pump which will run me $600 for them to do it - they diagnosed low fuel pressure. So I decided to replace it myself. I replace my fuel pump with a Walbro 255 - same price as factory replacement, oh and by the way, very very easy. First time doing anything really mechanical to my car. 30 miles later the CEL comes back on. I was confused because my car felt normal. Extremely pissed because it felt like my Mech sabotaged my car. I've drove my car with the CEL on for a while because I had no time, I was very busy at work. I search the web on P0171 CEL and came across this thread. Found it on pure dumb luck reading various other miss-informed threads which had me change my fuel filter (which I know is part of regular maintenance). For real I agree this Thread should be a Sticky.
To Shorten my story, reading the 2nd billet of PAWRX & CirrusWRX check list, I checked my factory intake box and noticed one of the insert lip on my bottom part of the box (the part where you slip in the top part of the box where there are no clips) had broken off. Luckily there was an '07 factory intake box for sale on ebay for $45. The Subaru parts guy will tell you he doesn't know if the '07 will fit the '03, but for $45 compared to $275 I just bought it. It fits just fine, one small issue. The screw holes for the MAF sensor on the '07 Intake are just drilled holes. I stripped the threading because the '03 had metal nuts molded into the mounting and so I was twisting for a firm screw-in. With a new intake system I've been driving CEL free for over 400 miles.
scoob-noob is offline   Reply With Quote
Old 11-09-2007, 08:23 PM   #85
ddub22
Member#: 156727
Just threw code P0171 after cleaning my MAF sensor. I had the code come on before and I thought it was because of my Oil filter, so I cleaned the MAF. Now the car idles rough, as if it is misfiring or bogging down.
- checked all connections, even took off the IC to make sure hoses are tight. Put a extra hose clamp on the BOV recirc into intake
- checked all vacuum lines
- put silicone around the MAF to make sure it wasn't a seal leak
- cleaned the O2 sensor
- Bought a new MAF sensor
Still idleing rough and throwing the code. The car does drive fine, just idles like crap then throws the code. I reset the ecu a bunch of times already and checked to make sure its running the correct base map.
I didn't check the IACV, what would have changed by cleaning the MAF sensor??? Any suggestions???
Car is 2004 wrx, stg 2 AP, short ram intake, cated dp, gruppe-s headers, hoses.
ddub22 is offline   Reply With Quote
Old 11-09-2007, 09:25 PM   #86
Vinnyzwrx
Member#: 143616
2014 STI
WR Blue
try turning the maf around 180 degrees, sometimes its easy to put the maf in backwards if you have an aftermarket intake that looks ths same backwards.
if the maf is in backwards it would do everything that your saying that its doing.
Old 11-09-2007, 11:15 PM   #87
ddub22
Member#: 156727
Just checked, the MAF is in the right direction. Just had my buddy who is a mechanic check the hoses, everything seems normal. All the conditions point to a vacuum leak, but can't find any leaks. Any other suggestions??
Old 11-10-2007, 06:20 PM   #88
blahhblahh
Member#: 86659
2005 WRX Sedan
WR Blue
would an exhaust leak, pre-02 sensor cause this cel. i belive i have an exhaust leak since its pretty damn loud now, and I get this code.
blahhblahh is offline   Reply With Quote
Old 11-11-2007, 11:50 AM   #89
20BlueWRX02
Member#: 156673
2007 Impreza 2.5i
CGM
I've been getting this P0171 code like all the rest of us here and the car seems to idle fine, drive fine and if it weren't for the light I really wouldn't notice anything abnormal at all.
My question is: what is the sensor that comes out of the uppipe? The reason I ask is because a few months back I did the up/down pipe install myself and I plugged the bung with a bolt and used the 2.2k resistor mod. Well earlier this morning it hit me and I assumed that might have been the front O2 sensor that was talked about here(then agian it could be the one in the headers too...I think there was one there) Anyway, I went out and checked the resistor and sure enough one end had fallen out of the connector. I replaced it and re-taped it back up good. I reset the code using my AP and took a short drive (less than 5 miles) and no light so far.
Somebody who knows, could this have been the issue? I sure hope so!
20BlueWRX02 is offline   Reply With Quote
Old 11-12-2007, 02:07 PM   #90
PAWRX
Member#: 9008
2002 slvr wrx sedan
07 CBR 600RR
Yeh, the resistor was most likely the problem. The sensor in the uppipe is the EGT. The sensor in the header is the front O2
PAWRX is offline   Reply With Quote
Old 12-14-2007, 05:49 PM   #91
CyaWRX
Member#: 166724
2005 WRX
wow thanks this is going to come in handy seeing as how my cel came up with the P0171 code
CyaWRX is offline   Reply With Quote
Old 01-07-2008, 11:26 AM   #92
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
yes, it could, especially at idle and low tps (where backpressure is low).
Old 01-07-2008, 10:16 PM   #93
wrblueballs
Member#: 121549
2005 WRX 20G, PPG
nice write-up. i now have a direction to go! i'm running a stage four system on my 05 and after i first got tuned, i threw this code. took it back, they said it kicked out my base map and reloaded the realtime. no problems for almost a year, but just last week the cel came back on and the thing has a super rough idle and stalls out when coming to a stop. it's really aggravated the mortal crap out of me...
wrblueballs is offline   Reply With Quote
Old 01-07-2008, 10:57 PM   #94
bluesubywagon
Member#: 168372
2004 wrx sti wagon
blue
Hi. I had a similar problem. It was the intake. My bet would be that the MAF calibration is at the border line with the new short ram. With mine I noticed that as soon as the weather cooled down it stopped happening. In the warm weather it had the same symtoms. Mine was a custom calibration that over time the ecu learned from the O2 sensor to a point that every now and then it was out of the O2 sensors range of keeping the ecu happy. Hope this helps!
bluesubywagon is offline   Reply With Quote
Old 01-12-2008, 09:33 PM   #95
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
this should be sticky.... very nice information here.
Old 01-12-2008, 09:41 PM   #96
wrxrex
Member#: 130196
Old Stage 4 bugeye
guys, if P0171 light came on 30 miles after replacing a fuel filter, what can be wrong? I made it sure it's installed properly and there isn't anything I can think of that can cause CEL.
1. MAF sensor - cleaned and checked.
2. Very smooth idle and drivability
3. No sign of knock (data log done using enginuity)
4. IACV cleaned and new gasket installed 5k miles ago
5. Intake box is sealed well.
6. Fuel injector cleaner and fresh tank of 93 gas
This leaves me with two possibilities - bad O2 sensor or defective fuel filter purchased from autozone. Are there anything else I should be looking at? I just placed an order for a new O2 sensor ($160 shipped).
Thanks guys...
wrxrex is offline   Reply With Quote
Old 01-13-2008, 01:49 AM   #97
wrxrex
Member#: 130196
Old Stage 4 bugeye
I also tried both K&N panel filter and paper filter. P0171 light is still on. I'm running out of idea here. Maybe I should try another fuel filter.
Old 02-13-2008, 09:25 PM   #98
Rodwrx23
Member#: 170948
Hey guys. I've been having this code too for about a month now. After reading the suggestions I've
1. Cleaned my filter on my Perrin Big MAF
2. Cleaned my MAF sensor and replaced the o-ring
3. cleaned my IACV and replaced my gasket
4. replaced my rear 02 sensor after also throwing P0137
5. I have also used fuel injector cleaner/octane booster and ran 110 unleaded
6. I've tried looking for leaks and cracked or loose hoses and can't really find any
7. I have a 2.2k resistor in my uppipe plug and my UTEC logs also say I'm running rich.
I'm really banging my head against the wall and don't know what else to look for.
Rodwrx23 is offline   Reply With Quote
Old 03-03-2008, 02:01 AM   #99
justinh595
Member#: 144052
I'm throwing this code on my 02.
setup:
hks catback
3'' downpipe catless
catless uppipe
cobb ap stage 2
stock intake etc
i've run through the list and haven't had any luck so far. replaced front o2 sensor and still no luck.
The car idles/runs fine...the only thing i notice is poor gas mileage. The only thing i can think of is i may have bumped something doing a trans about a month ago..the code has been coming on since about that time. I've checked everything in that general area (pulled ic etc) thinking i may have bumped something while working but came up with nothing obvious. Also the trans i replaced mine with is out of an 04 which shouldn't effect that but maybe someone knows something i don't. any suggestions?
justinh595 is offline   Reply With Quote
Old 03-10-2008, 10:56 AM   #100
maengelito
Member#: 35404
2005 Forester XT
Originally Posted by Speedinticket View Post
Bumping an old thread.... I just popped this code yesterday. After reading this thread, I found that the airbox wasnt sealed. I reset the computer, and that's the last I saw of it.
Thanks for the help!
i know this particular post is over a year old, but if the airbox isnt properly sealed, will the car still idle fine? one of the plastic tabs that you slide the upper part of the intake box into broke off but the car idles perfectly.
maengelito is offline   Reply With Quote
Everything you ever wanted to know about anything ever made......ever Hester Prynne Off-Topic 12 11-05-2008 05:57 PM
OT Non-Gun Nuts: Everything you ever wanted to know but were afraid to ask (or try) Janq Off-Topic 47 12-29-2006 01:23 PM
Everything you ever wanted to know about exaust systems Back Road Runner Normally Aspirated Powertrain 9 10-24-2006 09:59 PM
('93-'01) Everything you ever wanted to know about Subarus... Porsche914boxer4 Impreza Forum 15 07-23-2001 09:17 PM
Everything you ever wanted to know about WRX exhauasts (old model) --> rao Normally Aspirated Powertrain 5 02-12-2001 08:56 PM
