Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 05-05-2009, 11:32 AM   #151
Heider
Member#: 172173
2005 Impreza WRX
wow i wish i saw this thread a couple weeks ago. I had the P0171 code for a few days, so I cleaned my MAF and reset the code with my AP. Since then the CEL has stayed off, but I'm still getting the stuttering boost idle issues that Cinnabuns mentioned above. I will be installing a new front O2 sensor as soon as it arrives. In the meantime I guess I'll just keep checking all my hoses and airbox.
Heider is offline   Reply With Quote
Old 05-06-2009, 11:56 AM   #152
Cinnabuns
Member#: 173912
Pearl Blue
Well guess what... the re-torquing helped .... but my light just came back on yesterday. Same P0171 CEL.
I inspected the engine and it appears the tumble generator valve gasket is blown on the passenger side (where the intake manifold connects to the TGV). Large amount of spatter and fresh leakage indicative of air/oil on the side of the TGV. So new gaskets are getting ordered.
I had to remove the air intake snorkel to fish out a bolt that I dropped. While I had it off I inspected the side of the TGV and it was coated with a carmelly oil blow off from the intake gases.
I'm guessing the re-torquing helped the issue for a time but the gasket is definitely shot now.
I'm going to use thread lock when I reassemble so as to avoid future loosening after the gaskets are replaced.
Cinnabuns is offline   Reply With Quote
Old 05-06-2009, 08:24 PM   #153
skimobile
Member#: 92114
03 WRX (NAVY Camo)
in"Special Ed." Run Group
They have MAF cleaners at most local parts stores.
It's best to use those to cean your MAF.
MAFs are expensive to replace of you ruin them with a solvent/cleaner that wasn't meant for this purpose.
skimobile is offline   Reply With Quote
Old 05-07-2009, 12:33 AM   #154
Psyk
Member#: 92203
2012 SWP WRX Hatch
RIP 05 WRX
Well the cars up and running again. I got a new (reconditioned) maf and it did nothing so I returned that. My father grabbed my a new o2 sensor today and that seemed to be the problem.
I'll take pics of the o2 sensor tomorrow to show how it looks for future use/help. I was at work when my father got home from work (when he had the part) so he decided to put the o2 in for me and (for some reason) decided to change the 2 spark plugs on that side of the engine.
Either way, the cars running smooth (perhaps even smoother than before). Next, I'm hoping I pass inspection in July
Psyk is offline   Reply With Quote
Old 05-13-2009, 10:02 AM   #155
banshee
Member#: 94442
02 WRX
Blaze Yellow
I have been running a K&N Typhoon CAI for the a couple years without any problems. Yesterday, I decided to pull the end piece, move the filter and use it as a short ram. Driving it hard I had no problems, driving in cruise control for 10 min, P0171, reset it... it came on again today. Trying to decide whether to run some Lucas or just revert back to CAI
banshee is offline   Reply With Quote
Old 05-21-2009, 01:56 AM   #156
Psyk
Member#: 92203
2012 SWP WRX Hatch
RIP 05 WRX
Sorry for the extended delay; Just got around to taking the pictures.
Pictures of the o2 sensor and passenger side plugs found here
Old 05-21-2009, 09:06 AM   #157
CyborgX_CZ
Member#: 145351
0000 RIP 2006 STi
04 FXT / 89 SE30
Look exactly like mine but I don't have any P0171 instead my AFR was all over and on top of that my headers cracked. Actually I have this code before and it usually happened on highway but I guess once it got worse then it stopped and instead my AFR went crazy.
CyborgX_CZ is offline   Reply With Quote
Old 05-21-2009, 01:30 PM   #158
Darryl
Member#: 1626
'02 RevLab 11.5:1
Platinum Silver
Default riddle me this
The ce light comes on, I go to Autozone to have the code pulled. P0171. The guy clears it for me. Two days later it comes on again. I have it cleared again. Now I've reported here that the car drives perfectly. No issues. So I figure I can live with it, but I want to be sure no other codes are popping up. I decide to buy an OBDII reader (got one on sale for $50.00). Over the next week I clear the P0171 code twice more. Going on three weeks now and no new ce lights. The car still runs great. Is it just a matter of time? I had that front O2 sensor replaced 17 months ago. Keeping fingers crossed (but suspecting my little friend will return).
darryl
Darryl is offline   Reply With Quote
Old 05-21-2009, 03:19 PM   #159
CyborgX_CZ
Member#: 145351
0000 RIP 2006 STi
04 FXT / 89 SE30
My o2 sensor was 3 months old :-( (the one you see on the picture) Maybe I kill it when my headers cracked who knows...
Old 05-21-2009, 03:31 PM   #160
Darryl
Member#: 1626
'02 RevLab 11.5:1
Platinum Silver
hi Cy,
I guess I agree with you that a cracked header might have something to do with your sensor failure. If you need to order a new o ne, this site seems to have good prices, better than going to the dealer and free shipping: http://www.oxygensensors.com/index.p...024&height=768
hang in there.
darryl
Old 05-21-2009, 03:43 PM   #161
CyborgX_CZ
Member#: 145351
0000 RIP 2006 STi
04 FXT / 89 SE30
Oh thanks but I already have one replaced under warranty so I’m fine right now, also I’m just working on 2 STi part-outs so I have another 2 used for sell.
Old 05-22-2009, 08:27 AM   #162
Darryl
Member#: 1626
'02 RevLab 11.5:1
Platinum Silver
Originally Posted by CyborgX_CZ View Post
Oh thanks but I already have one replaced under warranty so Iím fine right now, also Iím just working on 2 STi part-outs so I have another 2 used for sell.
OK, man. good luck!
darryl
Old 05-22-2009, 12:20 PM   #163
012.5RS
Member#: 95051
02 WRX Wagon
World Rally Blue
Originally Posted by Weemus View Post
Just sharing my problem.
I installed a aps dr 725 fmic and aps cai on a cobb stage 2.5 car(I have access tuner)
Started the car following installation and it ran like *****. Well I figured I had a leak so I checked everything. Started the car still idled like *****!. I figured I am missing something somewhere and it is very hard the hear for leaks so I used a pump to the pressurise the system. No Leaks??? Took the car for a short cruise around the area and it also bucked coming on boost and badly when in 5th building boost, threw a code PO171. Took it home and scratched my head for a few days. I then recalled some issues I had when my aem was on the car. So I hooked up the stock airbox with it sitting on the ic piping. Started the car and it idled perfect! I pulled the cai (to be reinstalled on vacation in a few weeks so I can tune the car) and siliconed the air filter to the top of the stock airbox and hooked it up(the whole box won't fit). Took the car for a spin and it ran like a scalded dog. It seems the issue was a poorly placed maf sensor in the aftermarket cai. I am very disappointed in aps as their products are very $$$ and I would think they would do thier homework.
i also have an aps cai on my wrx. is there anything i can do(other than put stock airbox back in)? Which unfortunitly i dont have cause i bought the car with the aps on it. sorry fi this was already posted, but im at work and cant really read through all these posts without getting in trouble.
012.5RS is offline   Reply With Quote
Old 05-30-2009, 08:48 PM   #164
MYfirst00
Member#: 22928
2011 Outback 3.6R
Gray
Argh, this code is so frustrating. I've been chasing for an answer every day since Wednesday. I've been going down the list. I changed the air filter and made sure the box was tight. I've tightened all the hoses. I've cleaned the MAF with MAF cleaner. I've cleaned the IAC valve and replaced the gasket. I've even dropped full price on a front A/F sensor at the dealer. Code still keeps coming back. Car drives perfectly though, and I got about 110 miles at the 3/4 tank mark.
I just bought the car on Wednesday. 0 mods on it.
MYfirst00 is offline   Reply With Quote
Old 05-31-2009, 09:16 AM   #165
Darryl
Member#: 1626
'02 RevLab 11.5:1
Platinum Silver
I feel for ya, Myfirst00. What is vexing me is that I reset my p0171 a few weeks back now and it has not returned. Before that it would pop up again only a few days after reset. I keep expecting it to. How can it start then stop so mysteriously?
I usually complain about the mileage I get, but yours seems to be well down, unless you're running your car very hard. 99% of my driving is city cycle and I average just a bit over 17mpg.
It's possible that your replacement front O2 sensor has failed. Electric parts will do that, but rarely. Did you buy the car from a dealer or a private owner? Maybe you can go back and discuss this issue with either one, at any rate.
good luck,
darryl
Old 05-31-2009, 09:21 AM   #166
MYfirst00
Member#: 22928
2011 Outback 3.6R
Gray
I don't think I explained it correctly. With the mile mark I'm at, I'm looking at 300ish to the tank which will be about 25mpg. I'm going to replace the fuel filter today. The car was sitting at the dealer for 3 months.
Old 05-31-2009, 10:02 AM   #167
Darryl
Member#: 1626
'02 RevLab 11.5:1
Platinum Silver
Oh!!! I see! Impressive! Can you clear the code yourself? I bought an obdII reader for $50.00, and so far it seems to have paid for itself. I was prepared to live with the code, and simply reset it every few days until I could do something better (but the damned thing has not recurred). I also wanted the reader so I could assure myself that the ce light didn't come on for something more serious. The car runs perfectly still.
darryl
Old 05-31-2009, 10:58 AM   #168
MYfirst00
Member#: 22928
2011 Outback 3.6R
Gray
Yeah I bought a code reader from eBay a few years ago for the same price. Best investment I've made. I can clear it. The code comes back just like in the OP's description. 15 miles or so after the second start.
Old 05-31-2009, 06:08 PM   #169
MYfirst00
Member#: 22928
2011 Outback 3.6R
Gray
Replaced the fuel filter. Also took off the intercooler, tightened the turbo inlet hose, and checked every single hose in the system. Also replaced the PCV valve while i was in there. Anyone have an exhaust gasket issue before the bank 2 sensor and get this code? Engine seems to be loud around this area.
Old 06-01-2009, 11:40 AM   #170
z&cobb
Member#: 12344
2002 2JC
blue
Originally Posted by PAWRX View Post
vile- knowing what I know now I would agree. But probably 99% of the time when the O2 sensor goes bad, the car will start running really rough and crappy. Not the case here.
Mine ran OK with a bad front O2 sensor too, but I run open loop a lot (utec), when not just cruising.
z&cobb is offline   Reply With Quote
Old 06-16-2009, 01:23 AM   #171
Psyk
Member#: 92203
2012 SWP WRX Hatch
RIP 05 WRX
Well the code just came back today when I was ~1hr away from home so I had to drive home with it (without knowing what code I was throwing ). Tomorrow I'm going to change the driver side plugs, clean the IACV and check all connections. If this doesn't correct the code I'm going to stick my stock intake back on as I have inspection in July!
Hopefully something I do tomorrow works.
Old 06-16-2009, 07:04 AM   #172
Darryl
Member#: 1626
'02 RevLab 11.5:1
Platinum Silver
Default I still don't get it
It's been over two weeks since I last posted that I've had no return of the ce light (P0171). I can report that it still has not returned. I'm absolutely baffled. YMR that I cleard the code twice myself, and that since then all has been well. Also the car ran the same and still does, with or without the ce light; just fine.
darryl
ps I guess I'd rather be lucky than good.
Old 06-17-2009, 02:10 AM   #173
Psyk
Member#: 92203
2012 SWP WRX Hatch
RIP 05 WRX
Well I took apart the IACV today to clean it today and noticed that the gasket has swelled to the point when it's way too big to seal correctly! I'm going to pick up a new gasket (as well as two new screws) for the IACV and hope that fixes the problem; Next will be putting in the stock intake (not too sure if it'll do anything, but I'm running out of options).
Old 06-17-2009, 06:58 AM   #174
Darryl
Member#: 1626
'02 RevLab 11.5:1
Platinum Silver
good luck. hope that does the trick!
Darryl
Old 06-17-2009, 07:07 AM   #175
MYfirst00
Member#: 22928
2011 Outback 3.6R
Gray
Get some hex head screws with the same thread pitch and length. So much better than phillips head screws for this part.
Everything you ever wanted to know about anything ever made......ever Hester Prynne Off-Topic 12 11-05-2008 05:57 PM
OT Non-Gun Nuts: Everything you ever wanted to know but were afraid to ask (or try) Janq Off-Topic 47 12-29-2006 01:23 PM
Everything you ever wanted to know about exaust systems Back Road Runner Normally Aspirated Powertrain 9 10-24-2006 09:59 PM
('93-'01) Everything you ever wanted to know about Subarus... Porsche914boxer4 Impreza Forum 15 07-23-2001 09:17 PM
Everything you ever wanted to know about WRX exhauasts (old model) --> rao Normally Aspirated Powertrain 5 02-12-2001 08:56 PM
