Welcome to the North American Subaru Impreza Owners Club Monday January 26, 2015
Old 12-29-2003, 10:23 AM   #1
FloridaWRX
Member#: 7708
'83 huffy 10-speed
yellow
Question Does this seem overpriced to you?
02 wrx, my driver's side, front window motor went bad and doesn't work anymore, the window wont roll up or down. when the main motor siezed it took the other motor in the door with it (how it was explained to me) ... they ordered a new one of each, and said the parts were going to be just over $500 ... doesn't that seem a little expensize to you?
FloridaWRX is offline   Reply With Quote
Old 12-29-2003, 11:05 AM   #2
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
For window motors? No... I have an old Mazda 626 ('87 maybe), which blew a drivers window motor. I think it cost about $400.
heffergm is offline   Reply With Quote
Old 12-29-2003, 12:00 PM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Expensive?, nope. But, aren't you still covered under warranty?
Also, 2 motors? ***?? If it were me, I would pull the door apart and look for myself.
A co-worker had an alarm and window problem. The VW dealer said it was a bunch of things and it would be ~$900 to repair.
He asked me and we looked at it. The problem was the wires running from the chassis to the door had overstressed and broken. Some power wires were shorting to each other.
We fixed the problem in about 1/2 hour for less than a buck.
Old 12-29-2003, 07:55 PM   #4
joubtt
Member#: 33901
04 04 STI
No AWD, Not interested
Find part numbers/cost here(just for ref): www.subaruparts.com
joubtt is offline   Reply With Quote
Old 12-30-2003, 12:13 AM   #5
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
it is expensive... new window motors for my M3 were $165/each.
-mike
plus subaru techs are pretty weird... they like to charge about double the time it take @ ~$100 per hour for labor.
MJU1983 is offline   Reply With Quote
Old 12-30-2003, 12:46 PM   #6
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
dont know doors all that well...
but just looked up the motor assy for front door...
list is $221.52
not sure what else you need...
regulator?
you could buy these parts discounted from an on line source
then take them to the dealership to install???
just one option.
good luck
Jamie
www.subiegal.com || www.allsubaru.com
Old 12-30-2003, 01:07 PM   #7
grindMARC
Member#: 23547
13 Focus ST
Blurple
Default Re: Does this seem overpriced to you?
Anyone else recall seeing a TSB or something about the window motors not being mounted properly and it causing them to burn out prematurely?
Unless you're messing around with the window every minute you're in the car, this is not something that should go bad this soon.
Edit, here's a related thread and another.
grindMARC is offline   Reply With Quote
Old 12-31-2003, 01:09 PM   #8
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
I know some people have had issues with the window, usually the drivers side, due to using the glass as a handle to push the door closed and thus damaging window related parts.
Old 01-02-2004, 10:19 AM   #9
andygold
Member#: 7347
2002 Impreza WRX
WR Blue
I had problems with the windows in both front doors. The window regulators both came loose, and caused a loud knocking. At one point, my drivers window would not move at all. This is a known issue. As to whether or not there is a service bulletin, I do not know. Both regulators were repaired/replaced under warranty.
andygold is offline   Reply With Quote
Does this seem wasteful to anyone else? Tkacik Off-Topic 15 11-16-2006 02:47 AM
Does this seem odd to anyone else? FrostyAK Alaskan Impreza Club Forum -- AKIC 7 02-09-2006 11:13 PM
What does this picture mean to you? rex_ruthor Off-Topic 25 10-15-2003 09:46 PM
does this sound right to you?? Scoobs Warranty Issues & SOA Problems 14 07-16-2002 09:50 PM
does this seem right to you guys? EnterTheDragon North West Impreza Club Forum -- NWIC 6 03-05-2002 11:12 PM
