Old 12-29-2003, 02:13 PM   #1
smacksube
Member#: 4067
01 2.5 rs
Question EJ20G codes 14-17... say what?
ok, so i again rewired the coolant temp sensor and the fuel injector grounds, but now the codes being thrown are
1 long blink, 4 short blinks = 14
" " 5 short blinks = 15
" " 6 short blinks = 16
" " 7 short blinks = 17
what the hell are these codes, the only think i can think of is individual fuel injectors maybe?
-eric
smacksube is offline   Reply With Quote
Old 12-29-2003, 02:52 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
ground ?
pretty sure that it is a pull to ground system ...
doubble grounding them won't work too well
14-17 are injector 1-4 errors i posted the codes in your pre christmas post ...
did you ground the injectors or did you run them back to the ecu .. b44 pin 24, 25
according the below diagram the pin you grounded should be at least +10v
Old 12-29-2003, 08:21 PM   #3
smacksube
Member#: 4067
01 2.5 rs
i ran the injectors back to the ecu, i'll double check the voltage but i'm just not getting something. thanks for that page, i'll be quadruple checking voltage and grounds....
Old 12-30-2003, 08:57 PM   #4
Structure828
Member#: 50488
1999 GC8 ej20g!
I think Jaxx is right. Check the voltage of course but double grounding= bad. Hey atleast we got it narrowed down to it being the injectors. Once that is set it should be perfect.
Structure828 is offline   Reply With Quote
Old 12-30-2003, 09:00 PM   #5
Structure828
Member#: 50488
1999 GC8 ej20g!
Jaxx, take a drive to Orlando, Il let you stay at my house and I will pay you $50.00 to help em fix it ;p
ej20g code 45 CEL gc8awdsti Pre-2002 Factory Turbo Powertrain 16 03-29-2009 12:20 PM
ej20g code 43? Rikshaman Pre-2002 Factory Turbo Powertrain 7 01-28-2009 09:57 AM
EJ20G Code 42 question TVA Pre-2002 Factory Turbo Powertrain 1 10-12-2007 03:45 AM
were to get ej20g parts and don't say japan scobaru Subaru Conversions 7 02-06-2004 09:23 AM
Ojibwe Forests ProRally - Aug. 14-17 jmullan Mid West Subaru Owners Club Forum -- MWSOC 67 08-24-2002 01:18 PM
