Old 12-29-2003, 09:47 PM   #1
IveBeenBad
Member#: 51525
Default A question on wiring
I am planning on buying a 97+ Imprezza L AWD and want to do an EJ20 swap awhile afer I get the car. My question is this:
Would the wiring be done by feeding the WRX harness throught the firewall, cutting out everything non engine related from the WRX harness, and then matching the wires from the Ls interior harness to the WRXs harness?
IveBeenBad is offline   Reply With Quote
Old 12-29-2003, 10:08 PM   #2
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
pretty much that but it's a little more involved. shoot me an IM once you get started.
Z
Zephyr is offline   Reply With Quote
Old 12-29-2003, 11:04 PM   #3
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Basically when you strip down the stuff you don't need , what you end up with is a stand alone engine harness. The only stuff you splice into the car is stuff like ecu power, fuel pump relay, tach , water temp gauge, speedo, rad fans, etc. There is roughly 10-15 wires you have to splice. But that seems to vary from swap to swap.
Ver.III is offline   Reply With Quote
Old 12-30-2003, 01:43 PM   #4
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
There are a couple who have done this recently or are currently doing it (myself included) so just ask specific questions and you will get some help.
Personally, I'll be tapping into the power for the WRX harness, using the WRX fuel pump relay, tapping the water temp gauge, fuel gauge, oil pressure, tach (basically, gauge cluster stuff), radiator fans, reverse switch, OBD-II, and integrating my existing alternator/battery wiring into the system. My A/C is being removed so no need to integrate that.
More or less, what you need to do is feed power to your WRX engine management harness and tap any signals that must go back into your existing harness.
Here is a good link to read that can be found in the wiring section of the FAQ.
-Jon
Question on wiring prosports. Photoroller Interior & Exterior Modification 2 07-11-2007 07:48 PM
quick question on wire length Krelkor Car Audio, Video & Security 0 08-13-2002 05:14 PM
A Question on MBC wiring RacerinLSL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-27-2002 10:08 AM
Question on wiring of MY02 WRX ignition WRXMod Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-10-2001 03:29 AM
