Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 12-30-2003, 12:11 AM   #1
BajaNut
Member#: 36905
2014 Outback SAP
leggtnut on lgt.com
Default economy
Hey all,
I know that it is a little early now that the turbo is out. But what has been the average MPG that peiple have been getting? I am not too mutch of a lead foot. I am going to be getting my turbo in a month or so and was wondering what people have been averaging already? I also was wondering if peiple have seen a differance with a bed cover and not.
Thanks for the info
Ben
BajaNut is offline   Reply With Quote
Old 12-30-2003, 09:27 AM   #2
hatake
Member#: 34811
04 Baja T
The first MPG was 21.3 mph with 50/50 on highway/city. In visual perspective, the needle was pointing almost 1/8 at 259 miles. I thought wow, 1/8 with my old Impreza was about 300 miles. I wasn't gunning it in any way, so this is pretty much it. I don't have a bed cover as that will be taken off for the most of the time anyway (bike).
hatake is offline   Reply With Quote
Old 01-01-2004, 06:03 PM   #3
Baja Turbo
Member#: 49744
2004 Baja Turbo 10
Regetta Red Pearl
Unhappy Economy
I've had mine alittle over a week.My mileage has been 21 MPG.I think that will drop after break in.Because i'll be driving it harder.This is my 2nd Baja,the last one was a 5spd.I got the auto Turbo this time and i like it better.I had the soft top from Subaru,did'nt care for it much.I'm thinking of getting the painted hard top or the camper top.I've been told by my dealer that this is the last year for the Baja.
Baja Turbo is offline   Reply With Quote
Old 01-03-2004, 12:23 AM   #4
Peloquin
Member#: 41307
2003 Baja
Regatta Red/Silver Stone
I'm starting to average closer to 22 or 23. I usually get to about 350+ miles before the gas light comes on.
Peloquin is offline   Reply With Quote
Old 01-11-2004, 11:27 PM   #5
hatake
Member#: 34811
04 Baja T
4th refill, and I hit 300 miles and fuel light came on. It took 13.6 gal, so that would make it 22 mpg with a turbo. Occasional 4k rpm, but very easy on it. I guess that's as good as it gets. I just took off the roof rack, which reduced the wind noise and save some gas - what, 500 feet for a tanK? Also debadged everything but "AWD" which reduced the weight by some onces. Now with a truck plate, my car looks like a for those never paid attention to Baja.
Old 01-12-2004, 07:58 AM   #6
cadillacjake
Member#: 49969
2004 Baja Turbo
Black Granite Pearl
Default Break-In
I've been told by my dealership that it's actually good to run the motor pretty hard the first 5k miles of its life as it "loosens up" the internals and will actually produce more power once this happens. Anyone notice this happen, or is this guy full of it?
cadillacjake is offline   Reply With Quote
Old 01-12-2004, 08:38 AM   #7
plunk10
Member#: 32342
2004 :derp:
Default Re: Break-In
I would go by the Subaru Engineers that wrote the manual , not the salesman . The book (at least for the impreza) says to keep revs UNDER 4k rpms for the first 1000 miles. In my opinion you don't want to run it to death while all the internal parts are getting used to each other.
After 1000 miles, you should be good to push it a bit harder.
plunk10 is offline   Reply With Quote
Old 01-12-2004, 08:40 AM   #8
cadillacjake
Member#: 49969
2004 Baja Turbo
Black Granite Pearl
Default Engine Run-In
Yeah, that sounds more like the requirements for breaking in any of the engines that I've built in the past. I thought it sounded just a little weird.
Old 01-12-2004, 01:29 PM   #9
BajaBratBoy
Member#: 51555
2004 Baja Turbo
Black Granite Pearl
I've had mine for 10 days. and have 1500miles and 5 trips to the pump.. I've been averaging right at 21mpg. It was hard keeping under 4000rpm for the first 1000 miles!!! going to do my first oil change at 2000 miles, second one at 4000 then switch over to synethic oil...
BajaBratBoy is offline   Reply With Quote
Old 01-12-2004, 03:01 PM   #10
Baha95
Member#: 39844
2003 Baja
Black / Silver
Hi all - speaking of fuel economy, does anyone use premium gas vs regular? Does it make a difference as far as performance and MPG go for the Baja? Just curious as to what others are doing. (I use premium gas, but if it doesn't make much of a difference, I'll switch to regular)
Baha95 is offline   Reply With Quote
Old 01-12-2004, 03:04 PM   #11
cadillacjake
Member#: 49969
2004 Baja Turbo
Black Granite Pearl
Default Octane
Unless your engine's been modded with either a turbo or a higher comp ratio, I'd stick with 87 grade fuel. Mid-grade and premium, unless required by the engine configuration, actually increase the amount of emissions your car produces and as a result, will actually increase the amount of carbon buildup inside. Are you in a high-altitude area? If so you may consider mid-grade to prevent detonation, but that aside, 87 should do the trick.
Old 01-13-2004, 12:00 PM   #12
Baha95
Member#: 39844
2003 Baja
Black / Silver
Hey cadillacjake, thanks for the reply. To answer your question, I live in New England, so altitude is not a problem. I just tried the 87 grade, and didn't notice any difference in engine performance. I'll go with your recommendation and use the 87.
Old 01-13-2004, 09:12 PM   #13
RWS_BajaTurbo
Member#: 51520
2004 Baja Turbo
Regatta Red
I've been averaging about 22 mpg with about 50/50 city and highway driving. I'm somewhat of a leadfoot too.
However, with my last tank of gas I only got 16 mpg. OUCH!!! I have an automatic and my dealer had recommended that I use the sport shifter for down-shifting in city traffic to reduce the amount of braking. Obviously doing so dramatically reduced the milage.
RWS_BajaTurbo is offline   Reply With Quote
Old 01-13-2004, 10:55 PM   #14
Baja Turbo
Member#: 49744
2004 Baja Turbo 10
Regetta Red Pearl
Thats what i was told also was to keep it under 4k for the first 1k miles
Old 01-13-2004, 11:02 PM   #15
Baja Turbo
Member#: 49744
2004 Baja Turbo 10
Regetta Red Pearl
I ran mid grade with my non Turbo Baja,But now that i have a Turbo i got to run premium.They say that it will greatly affect the performance if you use any thing but permium and may eng knock
Mr. Sharpe opens economy size can of whoopass at autox... Tony Tri-State Area Forum 4 01-15-2001 08:35 AM
AFC to improve fuel economy on MY00? Matt Monson Bay Area Impreza Club Forum -- BAIC 1 12-19-2000 10:47 PM
New Impreza's fuel economy Nemesis General Forum Archive 6 11-12-2000 05:22 PM
Economy Suspension Upgrade 2K Legacy? Jason Legacy Forum 0 05-26-2000 10:08 AM
