Welcome to the North American Subaru Impreza Owners Club Tuesday January 27, 2015
Old 12-30-2003, 12:14 PM   #1
mrtrex
Member#: 12223
2005 WRX
Default Sway bars differences in a stiffer front or a stiffer rear.
Why do some sell kits with a larger bar in the front and a smaller bar in the rear? I thought the best way to go would be a larger bar in the rear and smaller in the front???
mrtrex is offline   Reply With Quote
Old 12-30-2003, 05:23 PM   #2
mrtrex
Member#: 12223
2005 WRX
anyone?
Old 12-30-2003, 06:58 PM   #3
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
I think the car comes stock with a bigger front than rear if that tells you anything.
whtlegacy is offline   Reply With Quote
Old 12-31-2003, 05:00 AM   #4
kdmd2b
Member#: 6670
2002 WRX Sedan
WR Blue
Best is a relative term in suspension. Bigger rear can induce more oversteer or minimize understeer while a bigger front can do the opposite. However, swaybars are only one component of your suspension so what one person chooses to do with them should depend on the rest of their setup.
kdmd2b is offline   Reply With Quote
Old 12-31-2003, 05:02 AM   #5
kdmd2b
Member#: 6670
2002 WRX Sedan
WR Blue
Old 12-31-2003, 10:46 AM   #6
mrtrex
Member#: 12223
2005 WRX
That was a good post. the reason why I am asking this is my set up is is a little different than most set ups. This is what I have
22mm bar in the front
24mm bar in the rear
tanabe front brace
Tanabe coilovers
448 front spring rates
336 rear spring rates
1.75 inch drop
front camber -1
rear camber -2
0 toe
stock caster
This set up set up works great and I redused my autocross time a ton with each change
Old 12-31-2003, 01:18 PM   #7
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
2002-03 WRX come with 20mm front and 20mm rear bars on the sedan and 20mm front and 17mm rear on the wagon. although the new 04 WRX is different.
StarDogChampion is offline   Reply With Quote
Old 12-31-2003, 04:10 PM   #8
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
front camber -1
rear camber -2
0 toe
stock caster
this is actually a pretty "standard" setup that many people are running when replacing both swaybars on the WRX. With the rear being a 22-24mm adjustable.
The stock setup as mentioned above of size matched or the rear being smaller is a lowest common denominator setup for safety with a tendency towards understeer at the limit.
Arnie is offline   Reply With Quote
Old 12-31-2003, 06:12 PM   #9
angryfist
Member#: 22760
#54 STR S2000
crazymonkeyracing
tanabe front brace
Tanabe coilovers
1.75 inch drop
front camber -1
rear camber -2
0 toe
stock caster
you should dial in more front camber for autox... about -3 to -3.5 is great for turn-in
angryfist is offline   Reply With Quote
Old 12-31-2003, 06:15 PM   #10
mrtrex
Member#: 12223
2005 WRX
I need to get some front camber plates first. I have the front as negitive as it will go on the stock bolts.
Oem wrx wagon rear sway bar, driver control arm, and front/rear endlinks mywaganiswhite SCIC Private Classifieds 12 01-24-2011 03:20 AM
Question: '08 WRX shocks and front sway bar different than '08 base Impreza? Kylemorg Brakes, Steering & Suspension 14 07-27-2008 10:46 AM
*** PERRIN REAR 2008 WRX and STI REAR SWAY BARS ARE IN *** PERRIN Suspension/Brakes/Handling 13 07-24-2008 10:07 PM
rear sway bar differences between 02-05 theo79 Brakes, Steering & Suspension 3 03-24-2008 07:51 PM
STi springs - should I go with stiffer front or rear? ringmaster Brakes, Steering & Suspension 0 07-27-2004 06:54 PM
