Old 12-30-2003, 01:26 PM   #1
annointed
Member#: 5960
FXT 11.6@118 93 oct
NSX 450 whp SC'd (93 oct)
Talking '93 EJ18 to '97 EJ22 swap
Yes, that's right, I'm looking to add a whopping 20 hp and 25 ft-lbs to my '93 Impreza L wagon, along with upgrading to the bulletproof, non-interference EJ22. Actually, the EJ18 sounds like it has some bottom end damage and smells REALLY bad like rotton eggs when you start it up, along with making a lot of loud noises (but it still runs and moves under its own power).
Anyway, I'm looking for an EJ18 to replace it, but since I have an EJ22 laying around from a '97 Impreza, I was wondering how easy it is to just swap that into the '93?
Specifically, will it be plug and play? Or will I have to swap any of the EJ18's accessories to make it work? Are there any components that simply won't swap?
The EJ18 ECU will probably have to run the whole set up, since I highly doubt that the '97 EJ22 ecu will plug up to the '93 harness.
Thanks for any heads ups and insights!
Mark
annointed is offline   Reply With Quote
Old 12-30-2003, 03:03 PM   #2
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
yeah will prolly work ... what years are the engines?
i have a 1.8 laying around .. but ... kinda far away ..
Old 12-30-2003, 03:28 PM   #3
annointed
Member#: 5960
FXT 11.6@118 93 oct
Default Re: '93 EJ18 to '97 EJ22 swap
What years are the engines? Lol, Jaxx, did you even read my post?
Originally posted by annointed
Re: '93 EJ18 to '97 EJ22 swap[/b]
my '93 Impreza L wagon...I have an EJ22 laying around from a '97 Impreza, I was wondering how easy it is to just swap that into the '93?
...since I highly doubt that the '97 EJ22 ecu will plug up to the '93 harness.
Sorry, Jaxx, had to do it. You've been there through my first and now second swaps over the past 2 years. I wish you were closer too, I might just scoop up your EJ18. I personally am figuring that the EJ22 will drop right in, and that I can probably swap sensors, etc that don't match the EJ18 wiring harness, but figured it can't hurt to ask here too.
Old 12-30-2003, 05:16 PM   #4
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
hmm sorry bad day at work ...
i would just take the harness and the vacume lines off the 1.8 and put it on the 2.2
all the sensors should work
what is the compression on the 2.2??
Old 12-30-2003, 05:25 PM   #5
annointed
Member#: 5960
FXT 11.6@118 93 oct
Originally posted by Jaxx
i would just take the harness and the vacume lines off the 1.8 and put it on the 2.2 all the sensors should work
That's exactly what I'm trying to confirm, whether every plug/connector will just mate up or not. I'd be pleasantly surprised if they do, but I'm hoping that the components that don't plug and play I can swap from the EJ18 block onto the EJ22 motor, and not skip a beat.
Old 12-30-2003, 06:22 PM   #6
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
Hey mark
I put my old EJ22 in my buddies 93 EJ18 car. There are only two plugs on the block: crank and cam sensor that need to be connected, I dont think the 93 has a knock sensor. The COMPLETE 1.8l intake will bolt to the 2.2 so no worries. Just pull the HOLE intake off and swap them. My 98 EJ22 didnt have any EGR ports on the exhaust but thats not really a problem, I am thinking your 97 wont either, it will just throw an EGR code. Most 2.2 use the same injectors as 1.8 The 1.8 ecu seems to run the 2.2 fine!!
Have fun swapping
Scoobie Steve is offline   Reply With Quote
Old 01-01-2004, 09:11 PM   #7
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Sorry to disappoint you, but the EJ22 became an interference motor in '97. You'll want a '96 for a non-interference motor.
-WaC
Wayne
wac is offline   Reply With Quote
Old 01-01-2004, 11:26 PM   #8
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
You may run into a few wiring issues.
My buddy dropped a 2.2L motor (not sure what year) into his 1996 Impreza 1.8L, and everything was pretty much bolt up (no wiring).
Graham
Graham is offline   Reply With Quote
Old 01-01-2004, 11:26 PM   #9
annointed
Member#: 5960
FXT 11.6@118 93 oct
Default Re: Re: '93 EJ18 to '97 EJ22 swap
-WaC
Wayne
Well that's good to know. So that means that the EJ22 in my '96 Legacy is still a free spinning motor, right? I'm pretty sure that its never had a timing belt change in 158k miles!
Now, why did the change it to an interference motor? Does it have anything to do w/ Phase I vs. Phase II motors?
Old 01-01-2004, 11:48 PM   #10
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Default Re: Re: Re: '93 EJ18 to '97 EJ22 swap
The '96 Legacy should be interference-free also.
The change was probably required to go from 9.5:1 to 9.7:1 CR, which bumped peak hp from 135 hp to 137 hp.
-WaC
Wayne
Old 01-05-2004, 03:42 AM   #11
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
I just got a 95 2.2L NA motor to swap out the 93ish (maybe newer, I don't remember) motor in my 93 Impreza.
The plugs are different so I just swaped the entire intake mani, crank and cam sensors. The 2.2 has a knock sensor on the back whereas the 1.8 seems to have it in the power steering pump mounting bracket. I also put the red top 2.2L injectors on there.
I'll drop it in as soon as I can get a truck for a few hours and rent a cherry picker. Right now the engine is just sitting next to the car.
Oh and BTW, I thought the red top injectors were 280cc, why does the 95 2.2 have red injectors? The 1.8 injectors were gray and are for sale along with the fuel rails.
Chad
93 2.2T
subachad is offline   Reply With Quote
Old 01-05-2004, 05:47 PM   #12
Scoobie Steve
Member#: 2289
1998 11.87@112mph
I have seen both red and gray tops in 2.2l Most 2.2l had gray tops, my 98 had gray tops but my sisters 2.2l legacy has red top. I think the cc are close enough either will work fine.
Old 05-11-2009, 12:31 AM   #13
JMK167
Member#: 210981
1995 Impreza L Coupe
RED
learning
JMK167 is offline   Reply With Quote
Old 05-11-2009, 12:31 AM   #14
JMK167
Member#: 210981
RED
so confusing feel like im in class
Old 05-11-2009, 01:30 AM   #15
annointed
Member#: 5960
FXT 11.6@118 93 oct
Ah, good memories. I sold the green '93 wagon with the swapped EJ22 years ago. It's kind of funny, I did the EJ22 swap in one weekend while the parents were on vacation and did a 240sx engine swap that same weekend! I just had to pull their cars out of the garage to make room for the projects! Man, it's nice having my own garage now.
Also, last I heard, the green '93 wagon was rolling around in Camden on chrome dubs!
Old 05-11-2009, 08:43 PM   #16
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Only the phase 2 2.2 engines are interference.
Old 05-12-2009, 11:35 PM   #17
sense of nature
Member#: 112759
02 Srp STi...
R ur Boltz to long????
No sohc Subaru engine is an interference engine .period
sense of nature is offline   Reply With Quote
Old 05-13-2009, 07:31 AM   #18
Storm
Member#: 5218
96L Most Over-
Developed Beater
Wrong in too many ways.......Please delete your post before someone accidently takes it as truth.
Jay Storm
Old 05-13-2009, 09:28 AM   #19
lele
Member#: 156792
94 Ver2 STI
I got 94L 1.8 awd and I have a 99' 2.2 sohc engine and tranny, so the 1.8L ecu will run this 2.2 without issue?
lele is offline   Reply With Quote
Old 05-13-2009, 10:30 AM   #20
urabus555
Member#: 102091
1994 1.8l Impreza L
Open Class Build w/110hp
Will it run LEAN???
~very curious~
urabus555 is offline   Reply With Quote
Old 05-13-2009, 03:11 PM   #21
Storm
Member#: 5218
96L Most Over-
Developed Beater
It'll run pretty good. If you run into issues, it'll only be at WOT. My 96 EJ18 ECU ran an EJ25D with no issues, but I added a piggyback fuel controller to dial it in a little better.
Jay
Old 05-27-2009, 02:17 PM   #22
ciper
Member#: 15543
90BJ Legacy LS ABS
Next time I get a set of bent valves in a 99+ EJ22 or EJ25 I'll take a picture.
Old 01-28-2012, 04:05 AM   #23
etron71
Member#: 308269
1992 legacy
flat black
Default Help Please!!!!
i just finished swapping a ej22 into a 94 impreza.
i used the intake manifold, wiring, crank and cam sensors off the ej18 and put them on the ej22
the engine turns over and has good compression but no spark.
when i turn the key off the fuel pump runs constantly and the check engine light is on but no other lights.
when the key is on the check engine light turns off.
the car ran and drove fine with the ej18 but it had blown head gaskets
what did i do wrong? someone please help
etron71 is offline   Reply With Quote
Old 01-28-2012, 09:58 AM   #24
69subaru360
Member#: 159682
1995 WRX
You have a bad ground or left a ground wire off somewhere.
69subaru360 is online now   Reply With Quote
Old 01-30-2012, 09:12 PM   #25
etron71
Member#: 308269
1992 legacy
flat black
Default Thank You!!!!
1994 Subaru impreza sedan awd with ej22 swap
299,xxx mi on car
120,xxx on engine
is now for sale
http://seattle.craigslist.org/sno/cto/2826725041.html
Whats reusable for a swap EJ18 to EJ22 OBD1 Karas Normally Aspirated Powertrain 6 05-05-2010 01:41 AM
Ej18 to ej25 parts swap ralliboi Normally Aspirated Powertrain 2 04-28-2008 07:09 AM
96 ej18 intake manifold -> swap to 96 ej22 manifold mxpunk Subaru Conversions 4 05-02-2007 05:18 PM
EJ18 to EJ25 NA swap q's? left footed whooten Subaru Conversions 3 09-30-2005 03:11 AM
'93 Impreza wagon, AWD dark green w/EJ22 swap - $1500 obo annointed Private Vehicle 'For Sale' Classifieds 27 12-15-2004 12:29 AM
Message Board Statistics All times are GMT -4. The time now is 08:49 AM.
