Old 12-30-2003, 03:41 PM   #1
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Default V.8 Jdm Sti?
I keep running into problems with this swap. Im swapping a V.8 motor into my USDM WRX and its a pain.
The STI engine harness was butchered by the guys who pulled the engine in japan, they cut the stupid wire half an inch before the plugs .
So i need to find out what my options are. Can i use both the WRX engine and wiring harness on my STI motor? I know i can use the wiring harness and that i need to run a few extra wires for the AVCS to work but what about the engine harness?
What needs to be converted omitted etc? Is there anyone i can call that knows how to do this or that has done this swap before?
Ive called Teague auto, who i was referred to by gruppe-s. They said that using the wrx wiring harness would be hard etc, but ive also heard from many others that its simple .
Any help on this would be greatly appreciated, id love to get this car back on the road before 2005, thats what keeps going through my mind with all these problems.
-John
LIQUIDSK8S is offline   Reply With Quote
Old 12-30-2003, 03:57 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i beleive that there is only 4 wires difference between the two harenesses..the avcs
Old 12-31-2003, 03:14 AM   #3
neednewengine
Member#: 37326
Default Sorry to hear that.
I spoke to Ron @ axis power racing.
The Most JDM V7 is the 4 wire Job but the V8 doesn't work that way.
I am not sure how true it is but Ron @ Axis is knows his **** when it comes to his motor swap.
He helped me out quiet a bit on my S202 motor.
Good luck...
neednewengine is offline   Reply With Quote
Old 12-31-2003, 04:28 AM   #4
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Ver 8 is pretty much the same as a V7 . Its more than 4 wires that you have to add for the AVCS. Plus switching around a few. Do a search, someone did post the ecu pin outs and procedures.
Edit : its posted in the 2.0L turbo forum.
Ver.III is offline   Reply With Quote
Old 12-31-2003, 12:11 PM   #5
neednewengine
Member#: 37326
Version 8 motor it self might be pretty similiar as V7 but ECU is quiet different.
But of course I can be wrong.
Call Ron @ Axis power racing.
He can help.
Old 12-31-2003, 03:11 PM   #6
cronic
Member#: 9749
He can help.
I have also heard there is a difference in wiring and that it isnt as straight foward as the standard V7..
cronic is offline   Reply With Quote
Old 01-04-2004, 03:15 PM   #7
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
I talked to lachute and they said they never use the JDM harnesses, they always use the wrx engine and wiring harnesses. The wires just need to be rewired slightly, and then have the 6 extra wires run for the AVCS to work rather then the 4 wires required for the v.7 engine. There are also a few pin outs that are diff between the v.7 and v.8, the EGT is also done away with when using the wrx harness.
-John
ver 8 jdm STI cluster to ver 6 jdm sti scoobRA Electrical & Lighting 3 01-12-2010 04:31 PM
* VERSION 8 * JDM STi FRONT SEATS, USDM STi REARS, & BLUE MATS (Phx, AZ) W/ PIX JapCarRealGood Interior/Dressup/Audio & Security 9 09-28-2007 03:52 AM
* VERSION 8 * JDM STi FRONT SEATS, USDM STi REARS, & BLUE MATS (Phx, AZ) W/ PIX JapCarRealGood SWIC Private Classifieds 24 09-25-2007 12:47 PM
V.8 JDM STi heads(big port) AtlWRX Private 'For Sale' Classifieds 4 03-14-2006 05:36 PM
tire pressure warning system for ver7/8 jdm sti? Benjamin Tang Tire & Wheel 3 04-06-2004 11:41 AM
