Old 12-31-2003, 01:01 AM   #1
haszlan
Member#: 51616
2002 WRX STi V.7
Rally Blue
Default where does my coolant leak from?
Hi there everyone. This is my 1st post here. Got a little problem needs solving.
I have a Subaru WRX STi Version 3. After driving when I open the hood up I can see that the coolant is boiling/ bubbling from the coolant reservoir. And when the car is cold enough when I open up the radiator tank cap the coolant level has dropped. How come it is throwing coolant away? I have already replaced a radiator tank, thermostat, and radiator cap now and it still isn't working. Anyone can point me in the right direction? Thank you.
haszlan is offline   Reply With Quote
Old 12-31-2003, 01:06 AM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
You don't measure coolant like that. Coolant will read higher when it's hot and lower when it's cold. If you really want to see if you are losing coolant, measure at the same time/conditions. For example, look at it in the morning before you start it up and again the next day at the same time. That will tell you if you are losing coolant or not. Plus, you should be able to see it pooling under your car if you're leaking.
Calvin
cnk is offline   Reply With Quote
Old 12-31-2003, 01:21 AM   #3
haszlan
Member#: 51616
2002 WRX STi V.7
Rally Blue
that is what i meant. i check up my car every morning and my coolant (radiator tank) level has dropped (only if i had driven or started the car the day before). and there isn't any puddles of water from under the car. what i have noticed is water been thrown out from the the small coolant tank (water is boiling and bubbling).
Old 12-31-2003, 01:24 AM   #4
cnk
Member#: 10757
Does it consistently drop each day? When's the last time you flushed your coolant?
Calvin
Old 12-31-2003, 01:28 AM   #5
haszlan
Member#: 51616
2002 WRX STi V.7
Rally Blue
I had an overheat problem with my car 3 weeks ago. and after that it had this problem. just got new coolant on my car. if you read carefully i got a New Thermostat, New Radiator and New Radiator cap install after that incident.
Old 12-31-2003, 01:33 AM   #6
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
head gasket is leaking...garanteed
mr2guru is offline   Reply With Quote
Old 12-31-2003, 01:45 AM   #7
haszlan
Member#: 51616
2002 WRX STi V.7
Rally Blue
thanks mr2guru. i do suspect it to be the head gasket as well. just wants a comfirmation before doing a top overhaul on my car. you ever come with this problem as well? water coming out of plastic reservoir bottle? just wondering.....
Old 12-31-2003, 01:50 AM   #8
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
i have experienced that a few times
nothing like pulling a motor 3-4 times...
MJU1983 is offline   Reply With Quote
Old 12-31-2003, 01:59 AM   #9
cky211
Member#: 31129
02 WRX MPB
No TGV + lots of P&P
If it is the head gasket would the oil on the dip stick look different?
Would the oil level read higher?
-Scott A.
cky211 is offline   Reply With Quote
Old 12-31-2003, 03:37 AM   #10
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
You could do a compression test on each cylinder to gather more information, but disappearing coolant without puddles on the ground means a leak INSIDE, or as was stated above, probably a head gasket
CirrusWRX is offline   Reply With Quote
Old 12-31-2003, 05:31 AM   #11
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
-Scott A.
Depends on where the leak is....if it is just between the cyl and the surrounding water jacket then the oil usually isn't affected. But bubbles in your plastic reservior means your coolant is being over pressurized by combustion gasses, assuming coolant temp is normal. Milky oil indicates that the gasket failed between oil passages and the water jacket. That is not usually the case unless the gasket was installed with the incorrect torque sequence or the head surface wasn't smooth.
Old 12-31-2003, 05:40 AM   #12
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
I agree with mr2guru.
Just in case though, have you recently used any type of radiator flush products? I had a similar problem with an older Toyota I used to own. Same exact problems as a bad head gasket... bubbles, overheating, over flowing... turns out the system needed the "flush product" cleansed out more thoroughly. After about 4 flushings with pure water, it returned back to normal.
If not, head gasket.
You can go to an auto shop and have a test done to see if you have exhaust in your coolant system.
mattjk is offline   Reply With Quote
Where's my coolant leaking from? tobylazur Service & Maintenance 4 09-09-2008 01:57 AM
Where is my car leaking coolant from?? teesutt Factory 2.5L Turbo Powertrain 8 08-21-2007 10:07 AM
Where is the coolant leak coming from? subynube Factory 2.0L Turbo Powertrain 4 08-25-2005 05:08 PM
coolant leaking from under turbo The Deliverator Factory 2.0L Turbo Powertrain 11 05-02-2004 06:01 PM
coolant leak, from near thermo(pics) biggreen96 Normally Aspirated Powertrain 26 06-21-2003 01:53 PM
Message Board Statistics All times are GMT -4. The time now is 06:28 AM.
