Old 01-01-2004, 03:46 PM   #1
Hotrodguru
Member#: 37210
2002 Tarmac Bugeye
2012 Hyundai Veloster
Exclamation NEED HELP! WTB: Oil Pan Drain Plug w/ Oil Temp Sensor
PLEASE HELP!
Alright, here's the scoop. I have a 2002 WRX and have the OEM
PERFORMANCE GAUGE PACK ASSY-TURBO that's an option. It displays engine boost, voltage and oil temperature and sits where most WRX's have the clock. Well there is a wire that runs from the OIL TEMP gauge down to the oil pan, it's 2 parts. 1 wire from Gauge to midway ending in a female connector, then the 2nd part is the male connector I think that goes to the OIL PAN Drain Plug. The wire is BUILT IN to the drain plug.
Anyway, the wire just happened to be rubbing on the uppipe because a tie down came undone. The wire is burnt through and my gauge doesn't work anymore. The dealer says it's NOT AVAILABLE and I have to order the whole GAUGE PACK $700 YEAH RIGHT! Does anyone know where I can locate the wire running all the way down from the gauge to the drain plug???
I could just cut and splice but then you could change out the crush washer everytime you change the oil.
Needing HELP! Thanx, Guru
Hotrodguru is offline   Reply With Quote
Old 01-01-2004, 09:14 PM   #2
wrx320
Member#: 28631
2002 WRB wrx wagon
AVO stg I,II Shiv ECUtek
Your dealer is giving you a runaround (reach around) you can buy just the sensor but it is bank. about $150+. The wire shouldn't be able to touch the uppipe. If the dealer installed the guage pack, make them pay for the sensor as the factory installation instructions clearly show the wire exiting the firewall then going over to the DRIVER side of the car and down to the bottom side of the engine then across the crossmember to the oilpan. It should never be able to touch the uppy on the passenger side of the motor. Hope this helps.
wrx320 is offline   Reply With Quote
Old 01-01-2004, 09:41 PM   #3
Hotrodguru
Member#: 37210
2002 Tarmac Bugeye
Yeah thanx alot, sure does help. Well truth be told, I purchased the OEM Gauge set off of EBAY , got it for about $220 and I was pretty happy. I actually did run the wire right under the uppipe and tied it down with a zip tie. Well I did that because the wire's not too long and it looked cleaned installed under the uppipe. There was about 2" between the crossmember and the uppipe and didn't actually anticipate the zip tie coming undone. ALRIGHT, ALRIGHT enough about the install I'll know this next time around. So do you think the wire is also available???
Guru
Old 01-01-2004, 10:18 PM   #4
WRX Jim
Member#: 22321
is it just a regular electrical wire?
or what is it?
check summitracing.com, i bet they have it.
WRX Jim is offline   Reply With Quote
Wrxtra oil pan drain oil temp sensor kinger Interior/Dressup/Audio & Security 0 10-20-2009 10:20 AM
FS: 04 oem oil filters and oil pan drain plug slvr bullet Engine/Power/Exhaust 2 12-04-2008 12:33 AM
Where to get an Oil Drain plug for oil temp sensor ? (HKS CAMP) Extraze Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 08-27-2004 03:35 PM
Residual oil leak at oil pan drain plug?? DanZ Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-08-2004 10:27 PM
WTB!! NEED HELP! Oil Pan Drain Plug w/ Oil Temp Sensor Hotrodguru Texas Impreza Club Forum -- TXIC 5 01-02-2004 12:50 PM
