Old 07-18-2011, 10:09 AM   #226
legy the legacy
Member#: 281188
good info ... im looking for a air intake system just dont know what to get
legy the legacy is offline   Reply With Quote
Old 08-26-2011, 01:41 AM   #227
RSm1thX
Member#: 225407
2007 WRX STI
Obsidian Black Pearl
im researching to buy an intake...
the intakes i have came down to get is between the K&N and SPT.
-i have not read anything bad about the K&N.
-however i have read that the SPT intake runs at a higher temperature than other aftermarket intakes due to the aluminum...is this true?
out of the two intakes, which one is recommended?
i drive an 07 STi with a TurboXS TBE on a Cobb Stage 2 Tune.
RSm1thX is offline   Reply With Quote
Old 08-29-2011, 07:28 AM   #228
BpRyan422
Member#: 254633
2009 WRX STG 2
Dark Grey Metallic Prem.
I drive an 09 WRX with the Typhoon intake, Turbo XS TBE, Torqued Performance stage 2 tune and couldnt say anything bad about anything.
Typhoon intake gives a tad bit of power but it def. makes a huge difference in the "sucking" noise.
I'd go with the Typhoon over SPT parts. Im not a fan of SPT. Poor quality when comparing the two brands.
BpRyan422 is offline   Reply With Quote
Old 08-29-2011, 07:35 AM   #229
shaggydog
Member#: 247390
'11 STi
Why not get the Cobb SF Intake?
shaggydog is offline   Reply With Quote
Old 09-30-2011, 09:08 AM   #230
Cool Hwip
Member#: 295976
2011 STI Sedan
Alright Unabomber... I'm calling you out. Not really. I'm keeping the stock intake on my car because I think intakes are a waste of time unless it's a racecar. What are your thoughts on a foam panel filter i.e. Perrin vs. and an oiled K&N panel filter?
Cool Hwip is offline   Reply With Quote
Old 09-30-2011, 09:18 AM   #231
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
If you are running a Cobb tune, you can only run Cobb's SF intake or the stock airbox. They dont have tunes spec'd for the K&N or the SPT.
2Fast4U1DAY is offline   Reply With Quote
Old 09-30-2011, 09:21 AM   #232
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Panel filters are fine. Pick which ever fits your budget. You just cant change the intake charge piping, without a protune, as the diameter or orientation of the MAF sensor can throw the MAF scaling off.
Old 09-30-2011, 09:26 AM   #233
Cool Hwip
Member#: 295976
2011 STI Sedan
Yea I know about the diameter thing. Just curious if there's any advantages to a foam over a oiled gauze.
Old 09-30-2011, 11:34 AM   #234
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
The only advantage to running the foam filter over the oiled K&N is that you don't have to worry about sucking oil onto the MAF. HOWEVER, if you don't drench the K&N with oil, you wont have any issues, and you can clean it evey now and then and use it for years to come.
Old 09-30-2011, 11:41 AM   #235
DroppedClutch
Member#: 52313
2005 STiOmgWtfBbq20G
2007 MS3 Black
Originally Posted by Cool Hwip View Post
...I think intakes are a waste of time unless it's a racecar.
Should be: ...unless it becomes a bottleneck.
Originally Posted by 2Fast4U1DAY View Post
...if you don't drench the K&N with oil...
I always clean the MAF after drive 25 to 50 miles or so when using an oiled filter even if I know I didn't over oil it. JIC.
DroppedClutch is offline   Reply With Quote
Old 09-30-2011, 03:26 PM   #236
Cool Hwip
Member#: 295976
2011 STI Sedan
The Perrin drop in filter still takes oil but they claim you don't have to drench it in oil because you can work it into the foam manually where as the K&N you have to drench it in order to get the oil in all the crevices.
Old 09-30-2011, 04:38 PM   #237
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
You don't have to drench it. Just bend the filter a little. I always get the spray on recharge kits, and it specifically says NOT to drench it. Just spray it on until theres an even red tint all the way across the filter. If you spray 6 inches away like says, and move in a steady motion, you can get an even coat on it (even in the crevices) without drenching it.
Also it says to let it sit for 20 minutes so the application of the oil has time to soak in evenly, so this negates having to drench it to get an even coat.
Old 12-03-2011, 10:13 PM   #238
hi-revs
Member#: 233229
2007 sti
wrb
Looking for a serious answer here-
I bought my 07 sti used and it's in great shape.
Previous owner opensource tuned it to stage2 with a cbe along with the stock airbox.
My question: since it's already tuned to stage2. Can I just go ahead and bolt on an intake without tuning it again? Or will I need a retune?
hi-revs is offline   Reply With Quote
Old 12-03-2011, 10:33 PM   #239
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
If you are looking for a serious answer, here is one: do NOTHING to your car until you realize 100% of the information about open source tuning as bolting ANYTHING to your car that is not tuned for can lead to you buying a new motor.
Old 02-23-2012, 08:49 PM   #240
MarkSkySTI
Member#: 311325
2005 Impreza WRX STI
So stock is better? Hmmm
MarkSkySTI is offline   Reply With Quote
Old 02-23-2012, 09:04 PM   #241
Tonyturkey716
Member#: 307879
2013 WRX Hatch
they do bring in some power but they are not really needed until you upgrade the turbo. especially on the new ones, the stockers are good until 350-400 whp
Tonyturkey716 is offline   Reply With Quote
Old 04-15-2012, 05:57 PM   #242
MakuseruSukotto
Member#: 293159
2005 WRX
CGM
Question.
My '05 WRX came with the Snorkus already removed, it has a plastic plug covering where it would enter into the fender at. (Im pretty sure it still has the silencer and everything else, as it's very quiet)
Would it be worth while to track down a snorkus and put it back in?
MakuseruSukotto is offline   Reply With Quote
Old 05-07-2012, 09:25 AM   #243
VuN86
Member#: 242074
2007 WRX Wagon
Question Issues with SPT Intake???
does running an SPT intake create an issue running a stage 1 COBB flash on a '07 WRX? i ran into someone the other day adamantly expressing that i should hold off on installing it until i can get a protune.
VuN86 is offline   Reply With Quote
Old 05-07-2012, 09:48 AM   #244
DoogieSTi
Member#: 247023
2007 STi
I am running an AP flashed with "stage 2" 93 map. I recently removed my SPT intake and heat shield and went back to stock setup and reflashed. It made a huge difference and smoothed out the power curve. With the SPT intake I would feel a fluttering in boost at WOT and it was not smooth...it would come in inconsistent 'surges.' I would recommend waiting on the intake and spend your money elsewhere.
Just my .02
DoogieSTi is offline   Reply With Quote
Old 06-01-2012, 12:21 PM   #245
filipin0y
Member#: 216968
2oo2 wrx sedan
psm!
so we can conclude that on a wrx without a tune, an intake is useless??
just my 2 cents but i removed my intake silencer, im running stock intake, and ive been driving around without my passenger fender for a couple of days since its getting painted and ive noticed a BIG difference in the way the car runs. the direct airflow makes turbo spool up sooo much quicker and the car feels like it drives a lot smoother. but of course i cant be driving around without a fender lol so i feel that the stock intake works good, it just needs room to breathe
filipin0y is offline   Reply With Quote
Old 06-14-2012, 08:42 PM   #246
Yakattak
Member#: 284332
2003 Impreza WRX
Platinum Silver Metallic
Are there any drawbacks to using a short ram intake such as Cobb's or SPT's?
Yakattak is offline   Reply With Quote
Old 08-14-2012, 11:36 PM   #247
audiomind
Member#: 322149
2011 WRX STI
Thanks man. Great info and help saves money.
You're the best Unabomber \m/
audiomind is offline   Reply With Quote
Old 09-05-2012, 09:18 PM   #248
BlueHeelInsert
Member#: 313489
Would an aps intake without a tune be the cause of hesitation when i first get on it? When i initially put the pedal to the metal in first it's almost like the car is thinking about it before it goes. I bought the car back in march with the intake already installed.
BlueHeelInsert is offline   Reply With Quote
Old 11-02-2012, 11:25 AM   #249
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
The section entitled "Which intakes do not cause problems with the air/fuel ratio?" needs a BIG disclaimer. Those claims are ONLY on the old models (like in 04, when this thread was written), any intake 08+ needs a tune STAT! Maybe this is why so many people try to run untuned intakes on the 08+...NONE of those claims apply to the 08+ models, this should be clarified in the post.
Old 03-01-2013, 12:14 AM   #250
thelloyd
Member#: 348314
1997 Outback
Default intake curiousity
I work as a mechanic at a honda dealer, and am forever feeling sad/frustrated at all these cars coming in with aftermarket intakes. More often then not you can tell even at idle that it is a bit off. Anyways, Unibombers intake FAQ brought up interesting info about air turbulence throwing off the MAF reading.
You know those fuel saver little turbine things you put in your intake? I am wondering if one of those would help get rid of this air turbulence.
When going through school at UTI I had got a chance to play with a dyno and various verhicles/engines. A fellow student had one of these "fuel savers". So we put a stock 350 on the dyno, then followed up with a couple runs. Put the fuel saver on there, and retested. No gains in HP as the box had claimed. Not so sure about actual fuel saving though. I have never been a fan personally of these types of things. Consider them to be a hoax. But it would be interesting to see if it can help reduce air turbulence since it is kind of "guiding" the air flow.
thelloyd is offline   Reply With Quote
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 303 06-14-2016 10:03 PM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 111 06-11-2016 09:28 AM
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 322 05-18-2016 02:47 PM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 378 12-27-2015 07:49 AM
