Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 03-01-2013, 03:55 AM   #251
J_Baker
Member#: 309434
06/9 WRBSTI/SRR2.5i
shop slut/5sp beater
Originally Posted by thelloyd View Post
I work as a mechanic at a honda dealer, and am forever feeling sad/frustrated at all these cars coming in with aftermarket intakes. More often then not you can tell even at idle that it is a bit off. Anyways, Unibombers intake FAQ brought up interesting info about air turbulence throwing off the MAF reading.
You know those fuel saver little turbine things you put in your intake? I am wondering if one of those would help get rid of this air turbulence.
When going through school at UTI I had got a chance to play with a dyno and various verhicles/engines. A fellow student had one of these "fuel savers". So we put a stock 350 on the dyno, then followed up with a couple runs. Put the fuel saver on there, and retested. No gains in HP as the box had claimed. Not so sure about actual fuel saving though. I have never been a fan personally of these types of things. Consider them to be a hoax. But it would be interesting to see if it can help reduce air turbulence since it is kind of "guiding" the air flow.
I like the way you think. I'm an Aeronautical Engineering undergrad and owner of a hawkeye STI, and you're sortof onto a basic understanding of fluid dynamics. Basically, I'm not sure if the right terms are being used here-- laminar and turbulent. What these refer to is whether the airflow is nice and smooth or all "jostly". Regardless of the internal dynamics, when the opening of the intake is given the same pressure, free-stream velocity, temperature, and density of air, the amount of air will depend purely on the dimensions of the pipe-- for incompressible flows below M0.3, at least. A simple A1V1 =A2V2 analysis can be used, where A is the cross-section of the pipe at any point where the flow is purely perpendicular to the cross section. V is the flow velocity. Contrary to what you might think, air is actually basically (~5%) an incompressible flow up to velocities of 0.3 the speed of sound in that specific air mass.
What's this mean? Well. What goes in must go out. While restrictions within will speed up and slow down the air in varying methods, geometry throughout the intake really isn't as important as you might think. It's not going to cause some sort of "backup" and keep air from entering the inlet.
So onto laminar and turbulent. Going off the Air is a liquid analogy, air is a sticky liquid. It likes to stick to itself and surfaces it passes over, forming interesting things like boundary layers-- regions of varying flow velocity near a surface. So, from an engineering standpoint, you want to design your intake to provide an optimally distributed flow across the turbo inlet. From an inviscid view, flow will always be uniform at a crossection where velocity is perpendicular, if it went in that way. From a viscous view, this isn't the case at all, as boundary layers cause regions of high and low velocity, and cause some interesting phenomena at corners-- stuff that even now is nearly impossible to accurately model or predict perfectly. But considering specifically your turbine example. What you're basically doing is "normalizing" the air flow, very similar to what's done before and after wind tunnels in closed-return type systems. You're equalizing the flow across the cross section, chopping it up into tiny little bits and, through rapid velocity change of going through the turbine, forcing these chunks to have roughly equal velocities.
So. Turbine. In theory? It'd help. In practice? It'd be interesting to see what it'd do.
Corollary. This is why open compressor housing breathes so damned well. The airflow before the turbines is basically uniform and still, and thus air pulled in is incredibly uniform, meaning equal mass of air rotating and balanced turbine rotation (the weight of the quantities between blades of air even being equal), and just a good life.
J_Baker is offline   Reply With Quote
Old 03-01-2013, 09:48 AM   #252
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Which is misleading, IMO. The MAF errors you see with aftermarket intakes are very rarely due to turbulence. As Cobb points out in their article, turbulence is untunable:
http://www.cobbtuning.com/Technical-...es-s/70677.htm
Sometimes an intake that has turbulence problems will pop up, usually it's the cheap eBay parts with zero R&D invested. The name brand parts do NOT have turbulence problems, otherwise they too would be untunable. Any AFR problem that is fixable with tuning, is therefore not being caused by turbulence...pretty simple.
I've seen a turbulent intake before, it behaves VERY differently than anything people will see with normal aftermarket intakes. The owner of the car went through THREE different tuners, and none of them could even get the car to run without stalling. It wasn't until he welded in a new MAF flange farther down the intake pipe (farther away from the filter and bends) that the problem went away and he had it idling and running well in a matter of minutes.
So would shoving one of those aluminum cans shaped like a propeller from the movie Twister into the intake solve a turbulence problem? Maybe, but doubtful (if anything it would probably make it more turbulent). Whether it does or not doesn't really matter though, because for the price of the POS turbulent intake and the propeller you could have just bought a decent intake that had a shred of R&D invested and avoid the problem entirely. You'll still need to get a tune, but that is not because of turbulence, it's because of pipe diameter and flow distribution.
Old 03-10-2013, 11:24 PM   #253
07wHiTeDuB-RX
Member#: 349575
2007 Subaru WRX LT.
Pearl White
Thanks for the useful information! I have a stock 07 WRX and I'm currently debating on going with AEM, which I've had a great past with or try something else. Everything here helped me a lot.
07wHiTeDuB-RX is offline   Reply With Quote
Old 03-16-2013, 07:11 PM   #254
Kantnerner
Member#: 341977
2007 WRX wagon
If I'm running cobb AP stage 1 with a catback and nothing else, can I run a K&N intake with that stage 1 tune..? Cobb has a tune for a Cobb sf intake so if I ran that will it be ok to run the K&N and not the Cobb?
Kantnerner is offline   Reply With Quote
Old 03-16-2013, 07:47 PM   #255
Member#: 51961
2005 STi
2012 WRX
No
No
If you want to know why, please do some searching, because this has been covered at length hundreds of times.
Old 03-20-2013, 01:15 AM   #256
Casper12
Member#: 348328
2013 Impreza WRX STI
Dark Grey Metallic
Thanks a bunch! Super helpful!
Casper12 is offline   Reply With Quote
Old 03-20-2013, 03:14 PM   #257
WaitTheresMore
Member#: 289315
2006 STi
"Frosty"
Do you need a tune if you add Cobb post maf hose?
WaitTheresMore is offline   Reply With Quote
Old 03-20-2013, 08:44 PM   #258
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
does a drop in filter need a tune? looking at the aem dryflow
BigRob74 is offline   Reply With Quote
Old 03-20-2013, 08:57 PM   #259
sc00by4life
Member#: 97135
No, but you won't see any real benefit from it (with or without a tune).
Old 03-20-2013, 09:19 PM   #260
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
this is my 1st car without an intake, i dont even know what the interval is to change the oem...lol guess i gotta look in the book
Old 03-20-2013, 09:24 PM   #261
Member#: 51961
2005 STi
2012 WRX
Depends on the car and the filter, but often times, yes. I've seen more than one reputable tuner post results showing the definite need for a tune after swapping in a drop in filter. A year or so ago somebody even posted back to back logs of the AFR from a wideband with the stock filter and an aftermarket filter. He went back and forth a few times, and the aftermarket filter was consistently ~.5 AFR richer than the stock filter at WOT.
Our cars are incredibly sensitive to changes in the flow pattern across the MAF.
Old 03-20-2013, 09:25 PM   #262
minorc
Member#: 208229
2010 STi
Seriously? It's a hose bro.
minorc is offline   Reply With Quote
Old 03-20-2013, 09:27 PM   #263
WaitTheresMore
Member#: 289315
2006 STi
"Frosty"
I understand but these cars are so sensitive with intakes and intake parts.
Old 03-20-2013, 09:27 PM   #264
minorc
Member#: 208229
2010 STi
Alright sorry, No you don't need a tune for the afta-maf hose because its after the maf.
Old 03-20-2013, 09:34 PM   #265
Member#: 51961
2005 STi
2012 WRX
Don't be so sure...anything that alters the air flow pattern around the MAF will alter the MAF scaling. Yes the afta-maf hose comes after the MAF, but that doesn't mean it doesn't alter the flow pattern ahead of it (especially since it's located IMMEDIATELY after the MAF). If you think the air flow pattern through a ribbed tube is the same as a smooth tube, you should go back to fluid dynamics, and probably re-think why companies would offer this tube in the first place if it doesn't change anything. If you agree that the air flow pattern is altered with the afta-maf hose, then why wouldn't the air flow pattern 3 inches in front of it be altered as well?
I'm not saying an afta-maf hose certainly needs a MAF scaling adjustment, but I wouldn't be surprised in the slightest if it did. Hell, if a different panel filter needs an adjustment to the MAF scaling, and if an air/oil separator needs an adjustment to the MAF scaling (due to the change in flow dynamics in the turbo inlet, ask Clark Turner if you want to know more), then why wouldn't swapping from a ribbed after-maf hose to a smooth after-maf hose need an adjustment?
That said, while the car might benefit from an adjustment, it would probably still run alright without one. Having never actually tested it (or seen the results from any tests), I can't say for sure.
Old 04-17-2013, 07:49 PM   #266
bjudd31
Member#: 353484
2013 WRX Wagan
11 pages of helpful stuff! Cobb SF it is
bjudd31 is offline   Reply With Quote
Old 04-17-2013, 08:43 PM   #267
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
well, i bit the bullet and put this on last weekend. its loud, just like everyone said. i know butt dynos dont mean crap, but the car is def faster. in looking at my DP only log, and my DP + cobb sf log, i am def making more boost at a higher rpm than with just the stock intake. still peaking at 19
Old 04-17-2013, 10:06 PM   #268
Shadow4
Member#: 351319
2002 Impreza WRX HB
This is an awesome, informative write-up. It may be answer to something that's been puzzling me. I recently bought my 2002 WRX, and it's been running rich, and I couldn't figure out why. The intake has been replaced with an aftermarket intake, and I wouldn't be surprised to find out that the lack of a tune after the swap is causing the problem.
Shadow4 is offline   Reply With Quote
Old 04-18-2013, 04:26 PM   #269
RedRumbleWagon
Member#: 352018
2010 GH7
Originally Posted by Unabomber View Post
Until proven otherwise, it's crap.
Is this still true, or have the Injen CAI's changed since this was written 9 years ago?
RedRumbleWagon is offline   Reply With Quote
Old 05-13-2013, 01:05 PM   #270
legacyvt286
Member#: 87747
2008 WRX
Dark Grey Metallic
Drops mic, walks off stage.
legacyvt286 is offline   Reply With Quote
Old 06-02-2013, 04:35 AM   #271
ENCHILADAS
Member#: 352836
Is the intake FAQ also for discussion about cabin air filters?
ENCHILADAS is offline   Reply With Quote
Old 06-02-2013, 04:49 AM   #272
ogboot
Member#: 170906
psm
No but the cabin air filter thread is.
ogboot is offline   Reply With Quote
Old 07-09-2013, 07:07 PM   #273
Kraj81
Member#: 361484
2006 Impreza WRX
has anyone else besides Unabomber installed the Perrin? Not saying that I don't trust your opinion, but I checked out their site seeing that you listed them and it looks simple enough to install and the Live tech was quick to educate a noob like me with my dumb noob questions...anyway, any other users of Perrin wants to share their thoughts or opinion?
Kraj81 is offline   Reply With Quote
Old 07-09-2013, 09:05 PM   #274
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
A LOT of people have installed the Perrin. Look in the CAR PARTS REVIEW FORUM for a full review.
Old 07-11-2013, 12:08 AM   #275
Kraj81
Member#: 361484
2006 Impreza WRX
awesome, will give it a look...thanks
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 382 08-24-2016 02:10 AM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 116 08-01-2016 10:03 PM
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 303 06-14-2016 10:03 PM
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 322 05-18-2016 02:47 PM
