Old 01-02-2004, 02:40 PM   #1
Subasaurus Rex
Member#: 5269
1998 Forester L
Black Diamond Pearl
Question Couple of questions regarding '04 USDM STi motor into '01 RS...
- Will this engine bolt up to the 5mt without any fitment issues (clutch, etc...) ? I would probably put a better gearset in the tranny for obvious reasons.
- How compatible are the wiring harnesses? If I get the STi's harness/ECU, I just need to wire in the chassis/dash part from the RS, correct? Yes, I know... the wiring will be a pain!
- If the RS's exhaust manifold bolts up to the STi motor, and I make a custom up-pipe (behind the crossmember), I shouldn't have to swap out the crossmember... right?
- Does anyone know if the STi intercooler will fit in the GC engine bay?
Guess that's all I can think of for now. If you have anything to add, feel free. I searched around, and read most of the conversions FAQ, but if you know of any specific threads regarding this swap, please post them.
Thanks.
Subasaurus Rex is offline   Reply With Quote
Old 01-02-2004, 03:31 PM   #2
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
Crawford/I-Speed is offline   Reply With Quote
Old 01-02-2004, 08:33 PM   #3
Subasaurus Rex
Member#: 5269
1998 Forester L
Black Diamond Pearl
Thanks for the response.
What is different about the crossmembers, other than clearing the up or downpipe? What exactly doesn't fit?
Old 01-03-2004, 04:52 AM   #4
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
it's probably the routing of the exhaust right off the head, my exhaust goes under the crossmember and i believe the the new design goes over the crossmember
bobturismo is offline   Reply With Quote
Old 01-03-2004, 11:49 AM   #5
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
It's just the uppipe.
scoobyimprza is offline   Reply With Quote
Old 01-03-2004, 12:47 PM   #6
Subasaurus Rex
Member#: 5269
1998 Forester L
Black Diamond Pearl
So as I originally asked, if I do some custom exhaust work, I won't have to swap crossmembers?
Old 01-03-2004, 01:12 PM   #7
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
well it would cost more in the long run, and you would have to make a complete new intake, you would have to redo the pipes to the intercooler and you would have to do some other **** that is just not worth it.
just swap the damn crossmember. its not that hard. 4 bolts.
subiekid is offline   Reply With Quote
Old 01-03-2004, 01:19 PM   #8
subiekid
Member#: 25516
forgot to add, you might run into trouble with the water pump if you use the n/a cross member/
Couple of questions regarding tire sizes. gaveup Tire & Wheel 1 02-16-2010 02:36 PM
couple of questions regarding some simple mods... 07_DUBRXTR Interior & Exterior Modification 1 05-08-2009 10:22 PM
STi Injector into '01 RS manifold buhrietoe Normally Aspirated with bolt-on Forced Induction Powertrain 16 09-09-2006 01:37 PM
USDM STi Motor into 2000 2.5RS 2000 RSTi Subaru Conversions 29 04-12-2005 02:53 PM
'04 USDM STi tophat into '02 WRX? cdvma Brakes, Steering & Suspension 3 05-18-2004 08:43 PM
