06-26-2007, 01:45 PM | #276 |
Member#: 49978
NESIC
Vehicle:2002 WRX w/ JDM STi 6spd, EJ255, VF39 & EWG |
I would expect that it was protuned anywhere from the 14psi to 20psi range. Just give your tuner a call and find out what it's mapped for.
06-27-2007, 10:50 PM | #277 | |
Member#: 7327
NWIC
Vehicle:2008 Mazdaspeed3 2006 Wrangler Sport |
Just because you're overboosting does not mean you have reached the physical limit of boost creep. |
06-28-2007, 12:40 PM | #278 | |
Member#: 142040
Vehicle:2005 STI HTA Twisted |
+1 for that..... |
07-17-2007, 09:45 PM | #279 |
Member#: 129134
Vehicle:2009 wrx 5-door Black |
creep question
I am going to post this here, because it has to do kind of with boost creep(Sorry if it does not belong here). So i know boost creep = bad and read all about it. I have a wrx not an sti (2007) I was going to just get a cat back to avoid boost creep all together. So i am skimming daddysscp website and i came across the MadDad(TM) Metal V2 two-piece Downpipe, I have seen this b4 nothing new but reading a lil bit more i read "The MadDad(TM) Metal V2 is the only hi-flow catted downpipe with a catless wastegate design, offering the fastest boost control response to eliminate boost creep." My big question is is that true? if i get this down pipe i will not have boost creep at all?
07-18-2007, 07:20 AM | #280 | |
Member#: 59692
Vehicle:2005 Impreza WRX STi WRB-Gold |
Everyone needs to read this!!! Stop using the term boost creep...it is confusing the crap out of sooooo many people. |
07-18-2007, 10:42 AM | #281 |
Member#: 94752
Vehicle:2003 wrx wrb |
I had mine tuned and then re-tuned several times. I couldn't keep boost under 20psi when I accelerated. Yesterday I had my wastegate ported and now it stays at 17psi and the car feels like a beast. I didn't check incorrect orifice size on the boost control lines, stuck/siezed wastegate, etc etc., but I do know that porting the wg fixed my problem.
2.5liter hybrid with td05-16g |
07-19-2007, 08:29 PM | #282 |
Member#: 119777
Vehicle:2013 BRZ SWP |
If I'm running an axleback and no other mods, would boost creep be an issue?
07-19-2007, 10:34 PM | #283 |
Member#: 142040
Mate Please read this whole forum.....the answer is here.....Also read nhluhr above post.....
Originally Posted by nhluhr The dumbest thing I've ever heard would be somebody automatically assuming they have boost creep before eliminating other possibilities such as incorrect wastegate duty cycle mapping, incorrect orifice size on the boost control lines, stuck/siezed wastegate, etc etc. Just because you're overboosting does not mean you have reached the physical limit of boost creep. |
07-20-2007, 07:59 AM | #284 |
Member#: 59692
09-19-2007, 01:57 PM | #285 |
Member#: 15891
NWIC
Vehicle:2006 STI Aspen White |
Just so I understand boost creep occurs at high RPM's and if your tune is pusing ~20psi between 3-4kRPM (stage 2) it's just a boost spike?
09-19-2007, 02:27 PM | #286 |
Member#: 49978
NESIC
09-19-2007, 02:36 PM | #287 |
Member#: 15891
NWIC
09-19-2007, 05:23 PM | #288 |
Member#: 116914
VIC
Vehicle:2006 WRX Wagon Obsidian Black |
09-19-2007, 06:11 PM | #289 |
Member#: 159678
NWIC
Vehicle:2005 WRX STi Obsidian Black |
thanks man this sucks if only i knew what i was going to get into when i put this dam tbe on my sti oh well see if i can fix it
09-20-2007, 03:53 PM | #290 |
Member#: 49978
NESIC
You should know your target boost, and compare it with what you're hitting. You can log it or get a boost gauge, or do both.
09-20-2007, 04:19 PM | #291 |
Member#: 88322
Vehicle:2009 BMW 135i |
And hopefully your tuner hasn't set the fuel cut so damn high that it is useless...
09-20-2007, 04:59 PM | #292 |
Member#: 15891
NWIC
09-23-2007, 02:32 AM | #293 |
Member#: 159720
South East
Vehicle:2005 WRX STi OBSIDIAN BLACK PEARL |
Thanks For All The Info. All This Was A Big Help, Especially Being A Newbie. I Just Got My Sti And Obviously I Dont Want To Have Any Problems With It. This Definitely Helped Me Make A More Wise Choice Getting A Tbe Or Cbe. Thanks Guys, Keep Up The Good Info.
Chris D. |
10-01-2007, 06:40 PM | #294 |
Member#: 155040
Vehicle:07 WRX TR white |
I read most of the thread and it seemed mostly to pertain to STi's.
I have a 07 wrx with a turbo xs TBE that i bought and installed without knowing i needed to do anything else (im a newbie). anyways, ive been experiencing the stutter refered to in the first post and i just feel like im breaking my car. Ive been told getting the cobb stage 2 AP with eliminate this problem, but i dont have the 700 dollars right now since im in college. besides getting the AP, is there any short term solution like reinstalling my stock axel back? ive only had the TBE on for about 1000 miles, but could someone shine light on just how much damage i am doing to my car by keeping it on till christmas time? Thanks in advance, i know i probably sound retarded but this is my first turbo car and im not all that mechanically inclined to begin with. |
10-01-2007, 08:38 PM | #295 |
Member#: 127556
Vehicle:2006 WRX RomRaided. |
If you hae a TBE without engine management, you're most certainly hitting fuel cut, as it's like 13 PSI on the stock map.
You need some engine management. Period. |
10-02-2007, 12:25 PM | #296 | |
Member#: 142040
very simple mate you if have the read this thread then please understand this......either wrx of sti......the problem still is there.....it all depends on the car and the mod.....you may or may not have problems.....The only way to make sure would be to get em and talk to a tuner. |
12-23-2007, 09:27 PM | #297 | |
Member#: 167359
12-23-2007, 10:17 PM | #298 |
Member#: 123347
NWIC
Vehicle:1993 POS burgandy legacy |
02-23-2008, 10:39 AM | #299 |
Member#: 145884
Vehicle:06 STi |
Does someone have step by step direction for this? What tools were used? My friend and I might attempt this today as I have a divorced wastegate DP going on.
03-30-2008, 06:27 PM | #300 |
Member#: 159025
Vehicle:2004 STI (RIP 2013) 2007 STI |
so he is saying that...if I throw on a DP...I won't get boost creep because i still have my stock catback???
Everything you need to know about a Cutout? | zacxzx | Newbies & FAQs | 25 | 05-15-2009 06:31 PM |
everything you need to know about turbos | dankEe | Tri-State Area Forum | 1 | 11-08-2007 05:59 PM |
Everything I Need to Know about Raleigh Durham But Was afraid to Ask | Cdiff | South East Region Forum | 5 | 12-13-2005 02:13 PM |
Everything you want to know about cheap boost control | desiwrx02 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 86 | 03-09-2005 08:21 AM |
Everything you wanted to know about the WRC but were afraid to ask | rsquire_downunder | Motorsports | 7 | 02-12-2003 11:28 AM |
