Old 02-17-2004, 04:30 PM   #101
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
hmm. I would only be using it above 60 degrees and up to 100 degrees.
afpdl is offline   Reply With Quote
Old 02-26-2004, 12:42 AM   #102
ERaab212
Member#: 18466
2003 GT35r Evo VIII
[email protected]
So the only way to fix the boost creep problem is to Port the stock wastegate?
Do STI's have boost creep and bad det stock?
ERIK
ERaab212 is offline   Reply With Quote
Old 02-26-2004, 12:48 AM   #103
300blueballs
Member#: 39941
2004 Impreza WRX STi
It's not the only way but it is the easiest. You can also weld the internal wastegate shut and add an External wastegate.
People also use a boost controller but it does not remedy boost creep. It may keep it down slightly but it is not enough.
Stock STi's have no boost creep and no det. If you search the DET threads, you will find that Subaru remedied the problem for the few who had det issues and all STi's made now do not have that problem.
300blueballs is offline   Reply With Quote
Old 03-03-2004, 05:01 PM   #104
MAD TKD
Member#: 36471
Does the wastegate use a spring. I know on my other car to fix this problem we put a stronger spring in. I am sure it would take bit of testing to see which spring would be best but i could work.
What do u think?
MAD TKD is offline   Reply With Quote
Old 03-03-2004, 05:08 PM   #105
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
The problem is the hole isnt big enough with the wastegate fully open. So I dont see how changing the spring woudl solve anything.
Old 03-03-2004, 05:18 PM   #106
MAD TKD
Member#: 36471
ah hah I see. But that would solve the Boost dying down before redline though
Old 03-03-2004, 08:22 PM   #107
singletrack
Member#: 42440
04 Impreza WRX STi
Platinum Silver
The stock ECM wants the boost to taper at redline. I wouldn't change that without doing some serious monitoring.
-st
singletrack is offline   Reply With Quote
Old 03-05-2004, 03:38 PM   #108
Oppie1
Member#: 41647
2004 STI
Blue Pearl
Should I expect boost creep with Gt spec headers, uppipe, and down pipe?
Oppie1 is offline   Reply With Quote
Old 03-05-2004, 06:21 PM   #109
300blueballs
Member#: 39941
Yes.
Over warmer climates boost creep it is not as pronounced. The addition of an aftermarket downpipe will result in creep.
Old 03-06-2004, 04:58 PM   #110
NORCAL STI
Member#: 48911
well we did mine last nigth going to put it back today. i have the uppipe also from gt spec so we opened the entry to turbo a little bigger and ported teh wastegage. cant wait to hit the streetraces again lol
NORCAL STI is offline   Reply With Quote
Old 03-09-2004, 09:13 PM   #111
manchvegasuruguayguy
Member#: 43283
2004 WRX STI
World Rally blue w/ 19`s
Is it all downpipes ?? or just the over-efficient ones ? I recently purchased a Turbo XS turboback used for my STI installed it ran the car for a couple of days and finally drove it on the highway rolled into it in 4th gear at rather low rpm and gave it alot of load and there it was creep!! But on the other hand we installed a B&B turboback on another buddys STI, AND a Turbo XS manual boost contoller and we turned the boost up and he said his car didn`t creep at all , So I had to try it for myself , I drove it out on the highway in 4th gear again rolled into it gauge went up to 1 bar and stayed there "rocksolid" didn`t creep or bleed down at all , all the way to 7 thousand rpm , So then I tried it again this time in 5th gear and the same thing happened , the boost gauge shot up to 1 bar and stayed there, these next few time I couldn`t wind it all the way up to 7k rpm but more like 5 to 5.5 and still no creep , going back to the shop we took a good look at the exhaust systems and compared the two and the B&B just like the PERRIN down pipe has a dedicated wastegate dump tube that gradually tapers into the downpipe further down the pipe . Could it be that my Turbo XS downpipe / exhaust is too efficient ?? maybe flows too much exhaust, after all it is a 4 inch downpipe ?? Does anyone have a B&B turboback or a Perrin turboback and have boostcreep ?? I`m not trying to say that anyone`s exhaust is inferior , but the majority of threads that I have read has people running Turbo XS turboback having lots of trouble with boost creep . And I have one, and all but the boost creep issue I like my exhaust .
-Dan
manchvegasuruguayguy is offline   Reply With Quote
Old 03-09-2004, 10:03 PM   #112
XDEep
Member#: 39336
-Dan
i think you answered your own question. what are the differences between your cars- he has the boost controller and is holding steady at 1bar. above stock psi with a 3" is where the port seems to be restricting.
speaking of mbc's, i have no idea how one can physically LOWER boost, but i have heard people claim it.. somehow.. somewhere..
XDEep is offline   Reply With Quote
Old 03-11-2004, 12:07 PM   #113
mw1029h
Member#: 51726
04 STi "Cloaked"
Blk,"member of team blew"
thanks for the info I guessed right and just used a cat-back, not the TBE which was suggested. Boy that was close
mw1029h is offline   Reply With Quote
Old 03-15-2004, 11:39 PM   #114
Z06-KILLR
Member#: 51236
I will have to chime in here too. I just took my car for several runs: I have everything stock but I have removed only the stock muffler and placed a straight pipe instead, from the axle back.
The car "seems" a little quicker and I have not noticed ANY boost creeps whatsover. The boost will go all the way up to 1 bar and stay there...tried on 3rd, 4th and 5th....no problems.
The sound is freakin' great!
Z06-KILLR is offline   Reply With Quote
Old 03-16-2004, 03:27 AM   #115
XDEep
Member#: 39336
i think the focus here is on the flow restriction at the wastegate by opening up the downpipe and on. your not having your muffler still leaves your stock downpipe to mid pipe with enough restriction to match the flow of the wg port.
think of it as blowing through a long narrow straw by making your lips open a little. cutting off most of it may help but still leaves the straw as a restriction. if your lips are the wastegate, changing the entire straw to a huge one now makes the size of your lips the restriction - you need to open them wider.
adding a section of small straw (up/down pipe/cat/muffler) anywhere along the big straw will make it match your lips again.
Old 03-16-2004, 10:07 PM   #116
300blueballs
Member#: 39941
Hmm.... I tell my girlfriend the same thing
Old 03-21-2004, 11:55 PM   #117
2003 sedan
Member#: 24103
I will be testing an exhaust in a few eeks that is a different design and may not cause boost creep. Although as I have read some cars do and some don't so my results will be my results. I am attempting this with a 3" catless TBE system. I will post the results either way after the install.
2003 sedan is offline   Reply With Quote
Old 03-22-2004, 02:41 AM   #118
XDEep
Member#: 39336
but to not cause boost creep means this 3" catback is inefficient and not flowing what is should. why spend all that money to only limit yourself to that of the tiny wastegate port? if all you want is sound then just do a stock sized axle back.
Old 03-22-2004, 07:41 PM   #119
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
right! A good tbe causes creep. Bad ones restrict flow enough to prevent it. No magic bullet here
Zornorph is offline   Reply With Quote
Old 03-23-2004, 06:19 AM   #120
singletrack
Member#: 42440
04 Impreza WRX STi
Platinum Silver
Not necessarily. A bad downpipe design will not allow the wastegate to flow and cause creep. So it does have to do with design as well, it's not just about which has more restrictive cats, resonators, mufflers, etc.
-st
Old 03-23-2004, 07:57 AM   #121
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
you just said exactly the same thing that I did.
Old 03-23-2004, 09:22 AM   #122
singletrack
Member#: 42440
04 Impreza WRX STi
Platinum Silver
I read that as bad TBE restrict flow and PREVENT boost creep.
What I said is that a bad TBE can restrict flow out of the wastegate due to poor downpipe design and CAUSE boost creep.
-st
Old 03-23-2004, 10:19 PM   #123
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
right - either one. Stop up the wastegate flow or allow the main to flow better than the wastegate can keep up with.
Old 03-28-2004, 09:09 AM   #124
2003 sedan
Member#: 24103
This is a TBE setup. No restrictions.
Flows mega-loads of exhaust.
I am not installing this for sound.
Old 03-28-2004, 09:28 AM   #125
2003 sedan
Member#: 24103
That is backwards.
If you stop up wastegate flow you will have boost creep.
If the turbine flows more than the wastegate is designed for you will have boost creep.
Tubine speed is caused by pressure differential and heat.
the only way to maintain this is by bleeding off gasses and heat (the wastegate).
If a bellmouth frees up flow across the board then one would assume that flow would increase across the board turbine and wastegate. We all know these downpipes cause creep.
But why not the HKS? or Godspeed?
Think about how the HKS downpipe causes the wastegate flow to hit a flat piece of metal and do a 90 deg turn then another.
This is contrary to what a bellmouth design does, it frees up wastegate flow.
From what I understand Godspeeds downpipe is an oval shaped pipe that allows wastegate flow to be partially blocked(maybe not).
If it is not partially blocked then why does this design not cause boost creep? Is it too restrictive? It is like a small bellmouth.
I think its do to some other reason maybe not. But I will know in a couple of weeks. And so will you guys.
Everything you need to know about a Cutout? zacxzx Newbies & FAQs 25 05-15-2009 06:31 PM
everything you need to know about turbos dankEe Tri-State Area Forum 1 11-08-2007 05:59 PM
Everything I Need to Know about Raleigh Durham But Was afraid to Ask Cdiff South East Region Forum 5 12-13-2005 02:13 PM
Everything you want to know about cheap boost control desiwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 86 03-09-2005 08:21 AM
Everything you wanted to know about the WRC but were afraid to ask rsquire_downunder Motorsports 7 02-12-2003 11:28 AM
