Old 01-03-2004, 12:43 PM   #1
Lee Chun
Member#: 32639
Question Differences between US EJ20 and JDM EJ20?
I am a total Subaru noob, and had some questions. If there is a FAQ with this information, please post a link for me.
The JDM WRX makes 280hp, right? What are the differences between the US spec? More boost, different internals, etc, etc???
Thanks
Lee Chun is offline   Reply With Quote
Old 01-03-2004, 02:06 PM   #2
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
You can start here....
www.spdusa.com
and then if you search around here you will find more info.
Old 01-03-2004, 03:45 PM   #3
norcaliwrx
Member#: 46374
02 WRX
i know the jdm motor has varible valve timing, which they took out of the wrx because of our crappy gas, i believe the sti has it though since it is required to run 93 octane. i'm sure there are other things, i just odn't know them. hope this helps
norcaliwrx is offline   Reply With Quote
Old 01-03-2004, 08:35 PM   #4
ChristophWRX
Member#: 19009
2005 M3/WRX by clark
silver/white
Default differences
Engine Codes: JDM EJ207
USDM EJ205
207 has a semi closed deck with forged internals.
205 has an open deck with cast internals...
207 has twin oil grooves in the crank for superior cooling....
205 has one.
those are the major differences, the cylinder heads are also two total opposites...
Check out Rallispec.com for information and pictures on what a 207's internals look like...
cz
ChristophWRX is offline   Reply With Quote
What is the difference between US cops and UK cops? Kosmic Off-Topic 64 10-26-2006 02:43 AM
Difference between US sti and Impreza drive shafts? IA Performance Transmission (AT/MT) & Driveline 13 11-29-2003 07:32 PM
Differences between US BE's and ones from Japan bwolf33 Legacy Forum 8 03-10-2003 09:17 AM
Fitment issues between US GC8 and JDM WRX Ver x gryphon Normally Aspirated with bolt-on Forced Induction Powertrain 13 03-14-2002 06:14 AM
