Old 01-03-2004, 02:56 PM   #1
jikhead
Member#: 32535
2009 Nissan 370Z
Monterey Blue
Default Which gauge to use for IC temp?
Does anyone know what type of gauge would be good to monitor the temperature of the intercooler? And what type of sensor would be needed?
jikhead is offline   Reply With Quote
Old 01-04-2004, 11:08 AM   #2
WRX1
Member#: 3533
2002 Impreza WRX
WR Blue
Autometer make a intake temp gauge that comes with a temp probe. I am running the duel probe setup (before and after the ic), and they work really good.
Russ
WRX1 is offline   Reply With Quote
Old 01-05-2004, 10:11 AM   #3
coolcougar
Member#: 19674
2006 Baja Turbo 4EAT
Brilliant Silver Metallic
Omori also makes one. J-Spec Tuning is one place that carries them.
coolcougar is offline   Reply With Quote
Old 01-05-2004, 10:54 AM   #4
ITWRX4ME
Member#: 24472
2001 Miata
Russ
Sorry to post whore, but what's the difference in temp before and after? Just curious.
ITWRX4ME is offline   Reply With Quote
Old 01-05-2004, 11:38 AM   #5
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
I just got the nordskog performance one from summit. I had to order the extra probe though....looks real nice
ScreaminFast is offline   Reply With Quote
Old 01-05-2004, 11:43 AM   #6
2000vfr800
Member#: 15599
Well, hopefully the temperature is lower after the intercooler otherwise the intercooler isn't doing anything...
2000vfr800 is offline   Reply With Quote
Old 01-05-2004, 01:50 PM   #7
Jon [in CT]
Member#: 2992
02 WRX Sedan
According to the 5th page of this very nice document from Subaru, http://www.endwrench.com/current/sum...XTurboTech.pdf:
The intercooler reduces the temperature of the intake air from 248-266 F (120-130 C) down to 158-176 F (70-80 C) under normal operating conditions.
Another interesting tidbit from that document can be found on the 3rd page:
Rotational speeds of the turbine are in the range of 20,000 rev/min. at idle, to 150,000-200,000 rev/min. at full power. These very high operating speeds and temperatures make lubrication and cooling of the center shaft bearings of prime importance.
Jon [in CT] is offline   Reply With Quote
Old 01-05-2004, 01:59 PM   #8
Tex-WReX
Member#: 7107
2014 Mustang GT
Thanks for another very informative link.
Tex-WReX is offline   Reply With Quote
Old 01-05-2004, 08:17 PM   #9
WRX1
Member#: 3533
2002 Impreza WRX
WR Blue
I am running a stg2.5 (tbe, uppipe, samco hoses, ported tb and intercooler, stock turbo), and at about 16-17psi the outlet of the turbo is 300 degrees, and the outlet temp of the intercooler is usually right around ambient temps. I did a couple of track days so I would be at extended boost runs, and my after ic temps never went over 110 or so. I am runnig a STI scoop and one of my scoop splitters. I have a thread awhile ago called "intake air temps" that had some pics and so good info. I was going to do some updates, but I got so blasted I figured screw it, everyone can get thier own info or contact me personally. I can tell ya this much, I will NEVER run a short ram in my car, fmic or not. I think my intake temps went up about 20 degree pre-ic and 5-10 post-ic just by putting on a short ram.
Russ
Old 01-06-2004, 09:45 AM   #10
ITWRX4ME
Member#: 24472
2001 Miata
Russ, confusing answer to a simple question. What was the typical difference in the tempurature readings between the guage before the intercooler and the gauge after the intercooler?
e.g.
Gauge Before IC = 200
Gauge After IC = 100
Difference = 100
Old 01-06-2004, 09:51 AM   #11
2000vfr800
Member#: 15599
Um...
Difference:
300-110=190
And Russ, your reply didn't seem confusing at all...but I understand about getting blasted when trying to help sure lowers the interest of trying to do so.
Old 01-06-2004, 01:53 PM   #12
ITWRX4ME
Member#: 24472
2001 Miata
Originally posted by 2000vfr800
Um...
Difference:
300-110=190
You're right. Sorry. I guess I was keying on 'before' and 'after' intercooler. Didn't quite associate 'outlet of the turbo' w/ before ic.
My bad.
Old 01-06-2004, 03:04 PM   #13
Wrxtasy
Member#: 4649
'88 323 GTX
http://www.frostalarm.com/cat/p12.html
Model 2dc3-21
Anaologue with in and out temps from intercooler from westach
Wrxtasy is offline   Reply With Quote
Can a defi oil temp gauge be used for water temp duty? hella_sti Interior & Exterior Modification 2 05-05-2007 05:56 PM
Which gauge to use to monitor my O2 bottle jikhead Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 01-06-2004 06:23 PM
Which gauge to use for monitoring CO2 bottle jikhead Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-06-2004 12:54 PM
Which Gauges to Use? silverbetty Newbies & FAQs 22 10-04-2002 10:48 PM
Gonna do the Defi Pod, which gauges to use? Chunky_Chicken Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 09-11-2002 05:30 PM
