Old 01-03-2004, 05:51 PM   #1
serious
Member#: 22879
Default JDM sti 6 speed ? with suretrack
Hi all, I'm wondering if all the jdm 6 speeds have sure track/lsd? I've read on lachutes site that there are three different versions of it available, so that makes me think that it is optional.
Transmission is from a 03 jdm wrx sti non ra car. Been searching for the last 2-3 hours and haven't found any concrete answers or a way to decode the number.
Here's the number if anyone know's how to decode it: ED-TY856WB3KA
Another question, is there anything visually that gives away the dccd option just by looking at it?
Thanks
Brent
serious is offline   Reply With Quote
Old 01-04-2004, 08:33 AM   #2
kaneda3
Member#: 8057
99 rs-t & 02 sti
95 s14.5
contact a guy on here by the name of Julio
he said he could find out if it had a front suretrack by using the serial number
ps how much is the tranny your lookin at and what does it include?
mike
kaneda3 is offline   Reply With Quote
Old 01-04-2004, 06:29 PM   #3
Benjamin Tang
Member#: 4496
2009 Forester
red
when i asked this i was told to search the i - club website for a post were someone listed all the serial numbers... but for some reason i cannot find it just now
Benjamin Tang is offline   Reply With Quote
Old 01-04-2004, 09:08 PM   #4
serious
Member#: 22879
I've already sent the one guy an email asking for some info. I thought i came accross this same information a while back, but thought i would never get a six speed, so i just didn't take note of it. Lucky me
Brent
Old 01-05-2004, 02:15 AM   #5
Chaste Automotive
Vendor
Member#: 44921
Have more part numbers but these are the ones off the top of my head:
TY856WB1AA STD FRt, Center and Rear
TY856WB1BA Suretrack DCCD
TY856WB1CA Suretrack Front STD Center
TY856WB2CA Export Model
TY856WB2FA Export model
TY856WB2GA RS model wit DCCD and tranny cooler
Chaste Automotive is offline   Reply With Quote
Old 01-05-2004, 09:47 AM   #6
Benjamin Tang
Member#: 4496
2009 Forester
red
this one is not on the list... do u know what it is?
Old 01-05-2004, 10:43 AM   #7
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Hey Jeff, I have a WB2GA 6MT and while it does have the tranny cooler lines, it does not have a DCCD.
Old 01-05-2004, 12:02 PM   #8
serious
Member#: 22879
TY856WB3KA- Does anyone have any info on this number? It is from a 03 jdm sti engine if that helps any.
Thanks
brent
Old 01-05-2004, 06:25 PM   #9
serious
Member#: 22879
Somebody out there has to know something .
Brent
Old 01-06-2004, 12:28 PM   #10
Chaste Automotive
Vendor
Member#: 44921
Ben Tang if I am reding your trans correct it is TY856WB1BA which is suretrack w/dccd. My list is not 100% but fairly accurate I iwll have to look around and find the other part numbers.
Old 01-06-2004, 08:04 PM   #11
DubuRX
Member#: 24307
05 Evo MR
AWD LUV
I have a 6 speed that is also not on the list... can you tell me where to get the info possibly?
TY856WN2AA
DubuRX is offline   Reply With Quote
Old 01-06-2004, 08:38 PM   #12
serious
Member#: 22879
We need to send somebody to japan to pick up a book of info for us...i'll volunteer me .
Brent
Old 01-11-2004, 12:10 AM   #13
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
Serious: Your tranny is not DCCD.
Benjamin: Your tranny seems DCCD.
DubuRX: Your tranny is not DCCD.
Dubu: As someone already posted on another thread.
"If it has DCCD, there is a a wire harness that goes from the reverse , neutral switch on the left side of the gearbox and goes to the right rear of the casing. Its a white plastic plug/grommet that the 2 wires go into the case."
Julio is offline   Reply With Quote
Old 01-11-2004, 12:13 AM   #14
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
This is a DCCD tranny:
Old 01-11-2004, 05:24 PM   #15
serious
Member#: 22879
So are all sti transmission limited slip, either viscous or suretrack type, from the factory on a 03 jdm engine?
Do you know how one would check for a sure track/viscous differential in the front? I would think if you turned the front hubs the other wheel should go the same way right?
If this is the case, then i looks like i got F$%ked both ways (lsd and dccd)
Brent
Old 01-11-2004, 07:44 PM   #16
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
Brent
a. Yes
b. No, you can't find out that way.
Old 01-11-2004, 07:49 PM   #17
serious
Member#: 22879
So i tried turning the wheels and the other one went the opposite way. I know if you do this with the rear lsd it goes the same way.
What you are saying then that i can't test it this way? How can i test it if at all? I've tried posting numbers and nobody really knows anything on it.
Brent
Old 01-11-2004, 07:59 PM   #18
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
Brent:
The catalog I have access to, shows as being SureTrack, No CDDC (Same as mine) Standard (Base) 03 JDM STi 6-speed. (Same as mine)
Old 01-11-2004, 08:12 PM   #19
serious
Member#: 22879
Hmmmm...i hope your catolog is wrong. I just took some pictures to let everyone else look at the thing as i don't really know what i'm looking at. By the description above with the two wires i think i have it. It starts between the two plugs, crosses over to the passenger side and goes into a white plug with two holes.
What do you-all think?
Brent
http://photos.yahoo.com/brent2401
Old 01-11-2004, 08:18 PM   #20
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
Brent:
The tranny on those photos is indeed a DCCD tranny. Same as I showed in my photo. If I were you, Id give Gruppe-S a call.
I will give Max a call tomorrow morning. Mine is TY856WB1AA and Chaste shows it up as STD front/Ctr/Rear diff. All info I have says it is a Suretrack Front diff as I requested.
Will let you know.
Old 01-11-2004, 08:25 PM   #21
serious
Member#: 22879
Saaaweeeeet! I have dccd! I was hoping i did have it on there even though i need to figure out how to hook it up now . What is the default setting if you don't hook up the dccd? I've read 35 front 65 rear, but then i've also read 50/50. Anybody know for sure on this one?
Brent
Old 01-11-2004, 08:33 PM   #22
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
Yes, 65/35
Old 01-11-2004, 09:58 PM   #23
DubuRX
Member#: 24307
05 Evo MR
AWD LUV
Does it have Suretrac or not? Thanks.
Also, what did it come out of?
pic:
Old 01-11-2004, 11:10 PM   #24
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
Part numbers indicates No DCCD Suretrack-Yes
I preffer these to the DCCD ones. But that depends on what you want it for. If you are selling one, let me know.
Old 01-12-2004, 04:41 PM   #25
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
Brent
Brent:
You CAN test it this way! How are you doing it? If it goes to the opposite direction, you have an OPEN diff, not a SureTrack.
jdm sti 5 speed vs. usdm/jdm sti 6 speed mannyOlicious Transmission (AT/MT) & Driveline 3 06-24-2008 04:18 PM
Broke 4th gear in JDM STi 6 speed (07 sti gear ?'s) dan avoN7 Transmission (AT/MT) & Driveline 7 11-20-2007 02:05 AM
JDM Sti 5 speed VS JDM Sti 6 speed Ace009 Transmission (AT/MT) & Driveline 89 06-09-2007 03:26 AM
FS: JDM STi 6-Speed Non-DCCD Suretrac with 3.9 R160 subydude MWSOC Private Classifieds 3 02-07-2007 06:39 PM
FS: JDM STi 6-Speed Non-DCCD Suretrac with 3.9 R160 subydude Drivetrain 6 02-06-2007 07:35 PM
