Old 01-12-2004, 04:43 PM   #26
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
BTW - Email Max (Gruppe-S) about my tranny. Here's his response.
"Hi,
Some of the trannies for the AA have the SureTrack as well... the AA, BA, CA are indications of production revision class, not necessarily what they are... most of the AA's do not have suretrac, but we always request our trannies to have suretrac.
Thanks
Max"
Julio is offline   Reply With Quote
Old 01-12-2004, 04:46 PM   #27
serious
Member#: 22879
Hmmm...first you say i can't check it this way and then you say i can? Which one is it ? Also you said by the catolog you have it says it wasn't at first and then you later say it is?
Dude, what's going on ?!!
Brent
serious is offline   Reply With Quote
Old 01-12-2004, 04:49 PM   #28
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
As for my catalog: It is NOT. As for the photo I say yes.
As it being suretrack... do the test... turn the driveshaft... it front axles turns opposite, you DON'T have a Suretrack.
However: Take a look at Max' answer to my e-mail. I can't do the test yest, since I don't have the driveshaft and axles here. But as soon as I get them, I will test and see if my 6MT has indeed SureTrack as I requested.
Old 01-12-2004, 04:53 PM   #29
serious
Member#: 22879
So if i do the test (already did and they turn oppsite) does that mean i have the other lsd then? Somewhere somebody said that the 03 jdm sti 6mt ALL have a front lsd. So does that mean i have the "Other" lsd or what?
Brent
Old 01-12-2004, 04:58 PM   #30
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
That particular question Im not sure... You may contact Max (Gruppe-S) They do receive LOTS of parts from Japan on a weekly/monthly basis.
Old 01-14-2004, 05:33 PM   #31
serious
Member#: 22879
Ok, Which driveshaft are you referring to? There are 3 of them ! I was turning the front driveshaft, not the rear spline that goes to the rear differential.
I turned the front ones, they go the opposite direction. When i turned the back one, they both wen the same way.
Any ideas?
Thanks
Brent
I called gruppes (didn't talk to max, but someone else) and they said that if it's from a 03 New head lights, not the old round ones, then it's almost for sure that it has a limited slip in the front.
Old 01-14-2004, 10:26 PM   #32
serious
Member#: 22879
I think i've figured out the mystery with many hours or searching .
jdm 2000 and up 6mt-Suretrac was optional-If someone opted for it then you will have the dccd unit with auto mode-13.0:1 quick steering ratio and possibly 17'' wheels. Other things would be no transmission oil cooler and the engine would have a regular oil cooler on it and not the air to oil one of the spec c.
Does anyone agree with this stuff? I pulled all this information up on different jdm exporter websites and it's pretty much conclusive.
If this is true....and i hope it is....then i have dccd and a suretrac front lsd.
Brent
Old 01-15-2004, 05:39 PM   #33
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
That test doesn't work on a Suretrac diff just like it doesn't work on a Quaife diff. It's a torsen type diff, in that it needs to sense a difference in torque from one wheel to the other to work. If there is no load on one side of the diff, it acts like an open diff.
Old 01-15-2004, 07:23 PM   #34
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
Yes, I knew. In fact I told him a few posts ago (1st page)
Old 01-15-2004, 07:56 PM   #35
serious
Member#: 22879
That's cool, so there's still hope. Right now i'm thinking i do have a suretrac front diff.
Here's the next question-can you mix a suretrack front diff with a viscous non suretrack rear diff? In all the jdm reviews that i read the cars were either one or the other (either front and rear suretrack mechanical lsd or viscous open front and viscous rear lsd).
Brent
Old 01-15-2004, 08:01 PM   #36
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
Brent:
All info I have gathered on this last question is exactly the same you wrote.
Old 01-15-2004, 08:06 PM   #37
serious
Member#: 22879
Say huh?
Brent
Old 02-16-2004, 11:14 PM   #38
Turbo4me
Member#: 2200
2011 WRB WRX
08 Maz 3, 96 Landcruiser
Brent,
How is your tranny doing? I have the same thing in my car (waiting on the driveshaft), and I think it is DCCD. Any drivability problems? Did you use a 3.90 rear diff, or is yours a 4.44?
Curt
Turbo4me is offline   Reply With Quote
Old 02-17-2004, 03:26 AM   #39
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
Curt:
Im sure he has a 3:90 Using a 4:44 will give you very fast acceleration, but will top at around 115-120mph with that 6-speed.
If you look at the front diff, does it has a "shaft" in the center?
Old 02-17-2004, 11:48 AM   #40
Turbo4me
Member#: 2200
2011 WRB WRX
I didn't look at the front diff at all. We just stuck the tranny up there and when we were hooking up the wires, we found a 6 pin plug where my 5 spd had a 4 pin.
My worry was that this was a 4.44 final drive tranny as opposed to a 3.90, but I think we are OK on that.
Do you happen to have the ratios for the different trannies? I have searched several different ways, but I am not coming up with anything.
Curt
Old 02-17-2004, 11:58 AM   #41
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
STi ratios: 3.636 (1st), 2.375 (2nd), 1.761 (3rd), 1.346 (4th), 0.971 (5th), 0.756 (6th), 3.545 (Rev.), 3.900 (final drive).
There are variations to these numbers, but just so you have an idea.
Old 06-11-2004, 01:36 PM   #42
Rice Boi
Member#: 25811
2002 WRX (6spd)
2010 TDI CupEdition (DSG)
just wondering, I have a ACT clutch and flywheel from my stock WRX tranny. If I do the Sti 6spd swap, can I still use this clutch?
Rice Boi is offline   Reply With Quote
Old 06-13-2004, 12:46 PM   #43
AXA
Member#: 35566
2002 STI WRX GT30R
WRC Blue
Brent:
The tranny on those photos is indeed a DCCD tranny. Same as I showed in my photo. If I were you, Id give Gruppe-S a call.
I will give Max a call tomorrow morning. Mine is TY856WB1AA and Chaste shows it up as STD front/Ctr/Rear diff. All info I have says it is a Suretrack Front diff as I requested.
Will let you know.
Julio I have the same tranny you have TY856WB1AA.
You can check out the picture in this thread …….. http://www.clubwrx.net/forums/showth...threadid=67242
My question is I am confused reading all this info on this subject is my tranny or not DCCD because I am mounting the tranny in the car as we speak and I what to do this swap by the book…
If my tranny is DCCD what do I need to do ???
Please take a look at the picture and let me know..
Thanks
AXA is offline   Reply With Quote
Old 06-13-2004, 12:53 PM   #44
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
AXA - Your tranny is NOT DCCD. Also depending where you got it from, it is very probably it is not SureTrac. Max from Gruppe-S tries to get them with SureTrac all the time.
Mine has SureTrac.
Old 06-13-2004, 01:08 PM   #45
AXA
Member#: 35566
2002 STI WRX GT30R
WRC Blue
The Tranny came from Japan from a local parts dealer here in Dominican Republic..
Old 06-14-2004, 08:45 PM   #46
gpatmac
Member#: 18446
2002 WRX wagon
psm
Mhmm?
gpatmac is offline   Reply With Quote
Old 06-14-2004, 10:15 PM   #47
Benjamin Tang
Member#: 4496
2009 Forester
red
wow... that shipping crate is pretty impressive
Benjamin Tang is offline   Reply With Quote
Old 06-14-2004, 11:51 PM   #48
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
TY856WB3JA
anyone know what it is? is it 3.9 or 4.44?
ImprezaRSfan! is offline   Reply With Quote
Old 06-15-2004, 04:14 PM   #49
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
3:90
Old 02-17-2013, 05:58 PM   #50
tyrel.boyce
Member#: 270178
2002 Subaru
WRB HTA68 ported
TY856WB3KA
This is the same tranny Code as mine and it has auto dccd and suretrac on it as what i have found out.
tyrel.boyce is offline   Reply With Quote
jdm sti 5 speed vs. usdm/jdm sti 6 speed mannyOlicious Transmission (AT/MT) & Driveline 3 06-24-2008 04:18 PM
Broke 4th gear in JDM STi 6 speed (07 sti gear ?'s) dan avoN7 Transmission (AT/MT) & Driveline 7 11-20-2007 02:05 AM
JDM Sti 5 speed VS JDM Sti 6 speed Ace009 Transmission (AT/MT) & Driveline 89 06-09-2007 03:26 AM
FS: JDM STi 6-Speed Non-DCCD Suretrac with 3.9 R160 subydude MWSOC Private Classifieds 3 02-07-2007 06:39 PM
FS: JDM STi 6-Speed Non-DCCD Suretrac with 3.9 R160 subydude Drivetrain 6 02-06-2007 07:35 PM
Message Board Statistics All times are GMT -4. The time now is 05:13 PM.
