Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 01-03-2004, 09:20 PM   #1
citra
Member#: 42461
Default wrc ramp and floor jack
for those of you watch wrc on speed....
where can i buy the low car ramp that those guys use? also the floor car jack. any info will be great. thanks.
citra is offline   Reply With Quote
Old 01-03-2004, 11:33 PM   #2
WRXPRESS
Member#: 393
1986 944T & Outback
Yellow & 99 Ducati 900ss
It's not the WRC one but I picked up a set of low PVC ramps from Wallmart. My STi just clears it and it works very well.
WRXPRESS is offline   Reply With Quote
Old 01-04-2004, 12:23 AM   #3
pierceman
Member#: 44903
2002 NSXsupercharged
silverstone/black/black
mine will not clear the ramps now that it is lowered, I have to use wood extensions. got the ramps at sears
MAtt
pierceman is offline   Reply With Quote
Old 01-04-2004, 01:49 AM   #4
citra
Member#: 42461
yeah i already have a normal ramp from sears. it works okay now but once i lower my car i know it won't clear it.
Old 01-04-2004, 01:55 AM   #5
cnk
Member#: 10757
2013 BRZ Limited 6MT
You can get Rhino Ramps from Pep Boys. They're made for lowered cars. I'm lowered 2" in front and can still get up on the ramps with some wood placed right before the ramp.
Calvin
cnk is offline   Reply With Quote
Old 01-04-2004, 02:52 AM   #6
WillysPU
Member#: 25994
2003 WRX wrb stage 4
What would Scooby do?
You want the low profile 1200 rhino ramps, i bought mine here, may cost a bit more but they work great on lowered wrxs
Auto barn
Much better than the heavy red metal ones i got from sears and have to use wood extensitons with.
Jim
What would Scooby Do?
WillysPU is offline   Reply With Quote
Old 01-04-2004, 03:06 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Rhino's rock
Old 01-04-2004, 04:36 AM   #8
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
wow, great info
subiekid is offline   Reply With Quote
Old 01-04-2004, 04:46 AM   #9
Thunder Lungs
Member#: 33677
1980 2 feet
caucasian
Thunder Lungs is offline   Reply With Quote
Old 01-04-2004, 11:27 AM   #10
catass
Member#: 31976
2004 WRX STi
World Rally Blue
Wow those links are all so expensive. I picked up the same low profile rhino ramps mentioned for $17.88 on sale at pep boys. I think they're normally only $20.
And I picked up a 2 1/4 ton jack from sears with jack stands for $50. Only problem with the jack is I can't pump it up when I slide it under the front because there's no room to lift the handle up and push it back down. But if I drive the car up on the ramps first, then it's not a problem. And it works fine for all the jack points near the tires, which is all I personally need it for. Although I'm sure the $400 jack listed is nice, it's overkill if you're only using it once a year to change your tires like me.
catass is offline   Reply With Quote
Sick deal on 3 ton Floor Jack, Jack Stands and Creeper Kc2iLq Service & Maintenance 7 10-19-2009 07:29 PM
floor jack and jack stands is 2 ton enough Sir Punk Newbies & FAQs 19 07-02-2008 05:23 PM
Where to jack up my car with a floor jack? Sordid Philosopher General Community 1 11-17-2002 03:52 PM
Need a new floor jack, what and where can i buy? Cosworth General Community 16 01-29-2002 11:16 PM
