Old 01-04-2004, 06:07 AM   #1
03ShrtBus
Member#: 43757
2003 WRX Wagon
Sonic Yellow
Question Wagon Suspension- read and post your setups
Need help on my Suspension. Long story short i Got Progress springs for free and I just installed my Rota Attacks and Potenza tires. They are 225/45/17. I have a pretty severe rub in the back and barely any rub up front. I am a big fan of the tires and wheel and don't want to lose them. I have available to me a set of H&R Springs. The H&R's as many if not all of you kno don't sit quite as low. Any help in this manor is greatly appreciated and if it could be sooner then later............thanks again
PS.........WAGONS POST YOUR SETUPS AND IF YOU HAVE RUBBAGE
03ShrtBus is offline   Reply With Quote
Old 01-04-2004, 06:48 AM   #2
Mark Avery
Member#: 10313
2002 WRX wagon
This has been done before - do a search.
Lowered wagons with +48 offset rims will rub in the rear.
Solutions:
- Don't lower a wagon.
- 215/45-17s on +53 offset rims.
- Get the rear fender lips rolled.
I have 215/45 Bridgestone SO3s on 17x7+48 rims, Tein wagon coilovers, -0.9" rear drop. My rears rub - fender lips to be rolled soon.
Mark Avery is offline   Reply With Quote
Old 01-04-2004, 07:26 AM   #3
ripvw
Member#: 27790
Mark is right - here is the major thread on the topic:
http://forums.nasioc.com/forums/show...that+fit+wagon
Other possible solutions:
- adjust rear camber - you will need camber bolts or something more exotic and a good tech
- Prodrive springs - about 1/2 inch drop in the rear
Good luck.
ripvw is offline   Reply With Quote
Old 01-04-2004, 12:03 PM   #4
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I say this all the time, but just get your fenders rolled. I got mine done about a month after getting the car, just because I didn't want to be limited by what tire and wheels I could run. I have Tanabe Sustec Pro S-S coilovers with the car lowerd about 1 1/2" in rear, and about 1 3/4" in front. On the street I run 225/40-18 SO-3's on 18x7.5, +48mm wheels. At the track I run 235/40-17 Toyo RA-1's on 17x8. +48mm wheels. Also have camber plates in the rear and running -1 degrees camber, so I actually have less rear camber than stock. Still no rubbing. I got my fenders rolled professionally. They used the special fender rolling tool (you can sometimes rent these tools and try it yourself too), and a heat gun, so there was no cracked paint. No signs of cracking or rust after 30K miles. It cost me $240 to get all four done. For me, money well spent. A lot of people will say to just do it yourself and use a baseball bat, but the few cars I've seen done with that method had cracked paint, an uneven lip, rust, or all of the above. That's just my experience. Good luck!
Old 01-04-2004, 12:13 PM   #5
jcwrx
Member#: 25989
2009 WRX Built EJ257
Lightning Red Hatchback
No rubbing here:
Summer: 215/45/17 Firestone FireHawk FZ50 EP
Rota Tarmac 1 w/ 48+ offset
Winter: 205/55/16 Blizzak LM22
OEM wheels
Running Prodrive Springs
No rubbing ever
JC
jcwrx is offline   Reply With Quote
Old 01-04-2004, 01:48 PM   #6
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
SPT suspension kit, with 17" Prodrive P1 wheels (perfect offset) and Dunlop SP9000s in 215-45-17. No rubbing, no nuttin'. Even when I had the car about 1.5" down with the DMS coilovers, I didn't rub.
Kevin
gtguy is offline   Reply With Quote
Old 01-04-2004, 06:09 PM   #7
Benjamin Tang
Member#: 4496
2009 Forester
red
i remember a long thread sometime this year with this same question and many people answered it... try a search?
Benjamin Tang is offline   Reply With Quote
Old 01-04-2004, 07:16 PM   #8
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Solutions:
I'll have to disagree with mark here.
48ET is the correct offset for a 7.5" wide rim. And depending on your tire size and brand, as well as rear camber, do not rub. 53ET is correct for 7" wide and 55ET is correct for 6.5" wide rims.
I have 48ET 7.5" wide rims and they never came close to rubbing on a 3/4" dropped STi Genome suspension. I was using 215/45-17 Yokohama AVS Intermediates. Alignment was -1.5 F/ -1.1 Rear Camber. I switched to 225/45-17 Toyo T1-S and they had slight rubbage on the rear with about -1.1 degrees negative camber. I have since rolled my rear fenders and all is right with the world.
Some tires are wider than others, the S03 and Azenis are pretty wide for a given width, for example.
Arnie is offline   Reply With Quote
Old 01-04-2004, 07:46 PM   #9
abaxter34
Member#: 34723
fwd FTL!
prodrive springs, 215/45/17 kumho 712's, 7.5" wide rims with 48mm offset= no rubbing, ever
abaxter34 is offline   Reply With Quote
Old 01-05-2004, 12:26 AM   #10
wrathfirex
Member#: 45909
2002 WRX Wagon
Red
Warning! Don't lower the rear too much on a Wagon or you'll damage the rear differential. Mine lowers two fingers at the rear, almost one inch and no rubbing.
7.5 inch 5Zigen Fireball rims
225/45/17 Falken Tyres
Hks Springs <--- upgrade to hipermax 2 coilovers soon!
wrathfirex is offline   Reply With Quote
Old 01-05-2004, 12:29 AM   #11
MNbiker
Member#: 18148
'08 WRX
Dark Gray
Approx. 1.75" drop front & 1.25" drop rear with 225/45-17 Falken Azenis (probably the widest 225 street tire available) on 7.5" Rota Attacks. Fenders not rolled (yet), and I've had ZERO rubbing - with extensive autox & track use. The secrets? Negative camber & stiff springs (7k/7k last year, 8k/10k this year).
-Steve
p.s. I'll be running 245's with rolled fenders this year.
MNbiker is offline   Reply With Quote
Old 01-05-2004, 06:29 AM   #12
mav1c
Hoodbridge!
Member#: 560
I could guess, but why do you say this?
Old 01-05-2004, 12:41 PM   #13
wrxman02
Member#: 24162
2014 Legacy 2.5i
2012 Impreza 2.0i
hi brian
wrxman02 is offline   Reply With Quote
Old 01-05-2004, 03:42 PM   #14
Saunders
Member#: 34480
2003 WRX Wagon
-Steve
Steve, did you have any rubbing issues before adjusting camber or springs? This year, for the stx class, i am planning on running 225/45/17 azenis on some rota slipstreams on a 03 wagon. I havent done anything to the suspension other then rollbars/end links. You think i will have any problems?
Saunders
Saunders is offline   Reply With Quote
Old 01-05-2004, 03:56 PM   #15
mav1c
Hoodbridge!
Member#: 560
Rota doesn't make slipstreams in 17" for Subies. Lots of other Rota wheels to choose from though.
Old 01-05-2004, 05:43 PM   #16
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
I would hope Steve doesn't get any rubbing with that setup, he has no suspension movement whatsover!
but I have to say, its a bit irksome when someone says they don't have any rubbing because a) either they have incredible spring rates so the tire never even gets to the point of rubbing or b) they are at stock ride heights and never push things hard enough to get rubbing. its just not a fair assesment if a specific wheel/tire/suspension doesn't show/indicate full suspension travel. This is by no means a dis on MNbiker. .
Steve, what alignment settings do you have in the rear? This might give some folks an idea of how much negative camber one might need to avoid rubbage when having a car lowered that much.
Old 01-05-2004, 07:08 PM   #17
Mark Avery
Member#: 10313
2002 WRX wagon
Disagree all you want. I've seen enough wagon rubbing posts here to know that folks with +48 offset 17s that get no rubbing are in the minority - usually explained by: 1. not lowered, 2. very stiff springs, or 3. lots of negative camber.
But, if it rubs, 17x7+53 will put the tire 5mm farther away from the offending fender lip. So will more negative camber, but I don't want my fenders deciding my alignment specs. I run -1.0* in the rear, and yes, I know that contributes to the problem.
Old 01-05-2004, 07:35 PM   #18
mav1c
Hoodbridge!
Member#: 560
So get your fenders rolled. Never have to worry again. Run whatever tire and wheel you want (within Subaru fitments), with whatever camber specs you want.
Old 01-05-2004, 07:39 PM   #19
Mark Avery
Member#: 10313
2002 WRX wagon
I'm working on it! Got an estimate today - $275.
Now I have to figure out when I can drive the wife's car for a day.
Old 01-05-2004, 11:10 PM   #20
OneManArmy
Member#: 36154
2004 WRX Wagon
I really want to run the prodrive springs. I want to go down a little bit but stay with the stock struts and not go down to much because I spend mad time in the snow.....prodrive seems to be the perfect solution. Will be running 17's. Either Rota, speedline or weds.
Only problem....have an 04 and people are lagging on getting stuff together for 04's. And I really don't want to put the 03 tops on and what not...just want freakin springs.
Hopefully prodrive will have it together by marchish.
Anyone know?
OneManArmy is offline   Reply With Quote
Old 01-06-2004, 02:42 PM   #21
abaxter34
Member#: 34723
fwd FTL!
not likely. your cv joints might go out but the diff would be just fine
Old 01-06-2004, 02:56 PM   #22
Heather
Member#: 11627
Default Re: Wagon Suspension--Read and post your setups
20mm rear swaybar w/KLC30 aluminum Whiteline endlinks w/Poly bushings rear
stock 19mm front swaybar w/Poly bushings and Whiteline aluminum endlinks
Whiteline ALK (anti-lift-kit)
Michelin Pilot Sport A/S tires on stock rims
Steering rack bushings
Really improves the handling greatly with exceptional turn-in and steering response
Heather
Heather is offline   Reply With Quote
Old 01-11-2004, 06:33 PM   #23
MK19
Member#: 21977
Bear s like food
17” Gold Prodrive P7's w/ 225/45-17 Bridgestone Potenza RE070’s (street setup)
17” White Rota Attack’s w/ 225/45-17 Kumho VictoRacer V700’s (dedicated auto-x setup)
Dulalmin “Light Weight” black lug nuts
Cusco Zero-2R coilover suspension (“3” for street and 5-front/4-rear for auto-x)
Cusco Type II front lower arm brace
Cusco rear adjustable 22-24mm sway bar
Cusco front strut bar (Type OS)
STi rear trailing link arm kit
STi rear lateral link kit (6 piece, full pillow ball)
STi lower control arm bushings (Group N)
STi V7 power steering pump (coming this week)
Rev-Labs Quick ratio 10.5:1 (2.0 turn) steering rack (coming this week)
Whiteline steering rack bushings
Track/Auto-X alignment (-1° front camber w/ stock camber bolts; 2.5-3° w/ Cusco camber plates for auto-x)
I don't rub on a daily basis, but when I run the Rota's for auto-x, if I corner really hard, I get a touch of rub; not too bad tho, now that I have the car setup properly
MK19 is offline   Reply With Quote
Old 01-11-2004, 08:50 PM   #24
Bolster
Member#: 22290
2002 WRB WRX Wagon
I'm running
-Koni inserts front and rear (soon to be KYB AGX rears)
-Ground Control coil overs (350 front, 325 rear)
-Whiteline 22mm non-adjustable rear swaybar
-Whiteline HD swaybar mounts
-Hairpin racing spherical endlinks
-Hairpin racing swaybar collars (to prevent swaybar "walk")
-STi Group-N front strut tops
-Factory rear strut tops
-17" 48et Rota Tarmacs with Yoko AVS ES100 225/45
-Lowered 1" all around
-NO rubbing on 3 different suspension setups (I must just be lucky, so my fingers are staying crossed here)
-Replica of STi titanium front strut bar (aluminum and stainless, not Ti)
-Replica STi rear strut bar
-slightly worn rear tires that allow power-on oversteer from time to time
-Whiteline steering rack bushings still sitting on the shelf in the garage- greatly enhancing the shelf's response to inputs
Bolster is offline   Reply With Quote
Old 01-11-2004, 08:50 PM   #25
gtguy
Member#: 2184
Hey, didn't we put pink adjustables on your car?
Kevin
The HID FAQ Thread - Read before posting your questions dithergizzard Electrical & Lighting 671 09-15-2016 09:50 AM
What does your rim/tire combo weigh? Post your setup + weight Trevor723 Tire & Wheel 42 06-04-2010 10:40 PM
Post your setup... az ej20 fan South West Impreza Club Forum -- SWIC 20 02-10-2004 11:59 PM
Are these gauge readings correct? post yours too please! T33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-28-2003 01:35 PM
