![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#2476 |
Member#: 91941
NESIC
Vehicle:2012 Mazda3, 87 CSX, 79 Trans Am WS6 |
On the 04+ rear tophats, do I need wagon specific ones, or do sedan ones work too? I'm planning on doing this really soon (in the next few weeks), so I might hit up the local for sale /wanted section to see what people have lying around. I saw that the spring rates on the Swifts were a little weak. Are the RCE wagon springs the best out there for this setup?
Also, I've been told that my rear wheels will rub if I'm running the 18's I have. I'm pretty sure they have a +48 offset. The stockers won't rub, right?
#2477 | |
Member#: 33629
Vehicle:03 WRX Wagon WR Blue |
Are RCE the best well that depends (a very subjective statement)t hey are much stiffer then stock, and great performance springs. That being said you will want to replace your stock struts to work with RCE wagon springs. To know what is best we need to know what you are doing DD, AutoX, Track days? I can tell you the most popular spring I read about is the STI Pink spring also stiffer then stock, and you may want to consider new struts as well. I think you need to do some more research before you make a purchase. Just my 2 cents. R- |
#2478 |
Member#: 91941
NESIC
The car is a daily driver. The stock struts are worn out and the springs, especially in the rear, creak and squeak quite a bit. It's really harsh over the bumps these days. I've heard good things about the D-Specs, so those would probably be the struts I'd go with, as long as they work on wagons. I've done some research on this, but I just wanted to make sure that I buy the best setup that I can for my budget the first time around.
#2479 | |
Member#: 33629
Have you looked at the STI pinks for the wagon? Wagon Pinks they are not as aggressive of a spring. Perhaps maybe a better DD spring (again subjective) they also have less drop then the RCE wagon springs (advertised) I'm no expert and i hope this helps R- |
#2480 |
Member#: 91941
NESIC
Labcoat, you've been a great help so far. Thanks! I was planning on getting camber bolts for the front from Summit Racing this week ( I have to order some crap for one of my Trans Ams). They have them pretty cheap, around $12 for a pair IIRC.
The Wagon Pinks look good as well, and you're right, they are a little less aggressive than the RCE's. They might be a viable option if I can find a good deal on them and a set of tophats. |
#2481 |
Member#: 131996
SCIC
Vehicle:2006 CGM WRX Wagon Yimi Tuned 296AWP/322TQ |
^ with lab here.
for DD you should just go with pinks or STI take offs. d specs are good with them though. i still have my stock struts and they don't do very well with the STI take offs. when these wear out i'll be going with D-specs. but until they do, i can bear it. |
#2482 |
Member#: 33629
Also if you are using the D-specs (02,03) with an 04+ top hats (for 04+ springs, pinks/RCE) then you will also need Scooby921 Strut Spacers they are only like $20.00 R- |
#2483 |
Member#: 91941
NESIC
Yeah, I forgot about those. Thanks! I'm leaning toward the Pink springs right now. I'm gonna see if I can get some prices for this stuff tomorrow.
#2484 |
Member#: 7958
Vehicle:09 GH B+ |
for daily driving/crappy roads- clearly the wagon pinks- modest drop; firm, but not overly firm spring rates
now if you start adding weekend activities to the list ie track days/autox events OR if more drop is wanted, then the RCE springs trump the pinks ![]() |
#2485 |
Member#: 91941
NESIC
at "weekend activities"! I'd love to do autox or a track day someday, but this car is my sole dependable ride to work. My other cars (2 '79 Trans Ams) are in various states of disrepair and diassembly right now, but one of those cars is destined for "weekend activities" in the near future. I'm thinking the Pinks are gonna be the ones I go with. I also realized that the exhaust on my wagon hangs kinda low, so slamming the car on the ground is probably not the best idea with the crappy roads around here. Also, I have to thank you guys again for helping me choose this setup. Hopefully I can contribute more to this awesome thread once I get a better understanding of what I'm doing! ![]() |
#2486 |
Member#: 42233
SCIC
Vehicle:04 WRX waGGon WRB |
Ahh yes I've gone from USDM STi Wagon "Pinks" To RCE Wagon's
I also added koni inserts when I switched over so the comparison is not 100% But the ride on the RCE's is noticeably rougher. However the increase in response and reduced body-roll is also very noticeable over the Pinks. The Pinks sit in a very good place between stock and RCE springs in terms of ride quality vs performance. I am young and don't mind the rough ride on the RCE's most of the time but there are occasions on long trips or rough roads I do wish I had my pinks back on. |
#2487 |
Member#: 7958
Vehicle:09 GH B+ |
^ that should be a very helpful post for folks trying to decide between the two
suspension setup (like any other modification) is a series of compromises, giving up a little of this for more of that- as long as a person knows the direction he wants to head in, and does his homework, he should be able to get pretty close ![]() |
#2488 |
Member#: 91941
NESIC
Well, I ordered up a set of D-Spec's and Scooby921 spacers.
I'm still looking for some Pink wagon springs. I have a line on some tophats locally as well. I'm also getting some Paranoid Fabrications front fender braces locally. I can't wait to install all of this stuff in my car! ![]() |
#2489 |
Member#: 110078
Vehicle:2005 92x - 02 wrx silver 92x-wrb bugeye wag |
Here is my suspension setup, koni sport inserts, usdm wagon pinks, cobb swaybars front & rear, whiteline endlinks front and rear, spt front strut bar. The rear swaybar is set in the mid position, front koni at 1 1/4 turns from soft and 1 turn from soft in the rear. My setup is for spirited daily driving fun, still comfortable but firmer than a non car enthusiast would tolerate. The spt strut bar was a surprise, everybody says that strut bars are just bling. I felt the diference between the ebay strut bar I previously had that made no diference, versus the spt, that does work, noticeable stiffnes in the front end as soon as I drove the car after the install. I'm satisfied with my setup, it's been worth the money and effort.
#2490 |
Member#: 62539
Vehicle:2002 WRX Wagon 2009 Impreza OBS |
SiilverFleet:
I have a 2002 stg 2 wagon and am running d-specs grp n top hats and swift wagon springs and am liking it. I just fingered my wheel wells for drop and it's 3 fingers in front and 2 fingers in the rear. I drive on some pretty beat up roads every day and the softer spring rates of the swifts are very good at handling them. If I didn't have such crappy roads to navigate through daily, a stiffer spring would be more desirable because I autoX, but the swifts are quality springs and I'm enjoying the slightly higher than stock spring rates for every day driving. The drop is minimal on the 2002 wagon as advertised. I wish my 4 yr old didn't break my digital camera because I'd love to show my drop. The pic of the yellow wagon on the fastwrx.com site (if you click on the swift spring link) looks just like my wagon. If you search for swift wagon springs, there is a thread started in early August that has pics of a sedona red wagon that has a drop similar to mine. I'll put it this way: my setup is perfect for a daily driver. For competitive driving, the RCE's would be better, but for "spirited" daily driving, don't be adverse to go with the swifts. I am very happy with them, the group n top hats, the d-specs, and beefed up sway bars and endlinks. If I had a bunch of extra cash, I'd love to try the TiC coilovers though!!! Last edited by mulva; 10-04-2008 at 12:49 AM. Reason: clarity |
#2491 |
Member#: 167263
South East
Vehicle:02 WRX Sedan PSM |
Since I am done for now, here is my setup
02 Wagon 04 front struts 05 rear struts Stock springs STI rear sway bar... Aligned and on forrester wheels so slightly less offset. |
#2492 |
Member#: 91941
NESIC
All my suspension stuff finally came in!
Here's what I have:-02-03 Tokico D-Specs -04+ STI Pink wagon springs -04 rear tophats -2 Scooby 921 spacers -a pair of camber bolts -Paranoid Fabrications cowl stays Am I missing anything to do the struts? While I'm there, I'm doing Group N engine mounts and a Group N pitch stop. I can't wait to do this stuff. ![]() |
#2493 |
Member#: 124219
NWIC
Vehicle:2004 W(agon)RX Silver |
^^^ group n hats, rear strut bar.
#2494 | |
Member#: 63767
NWIC
Vehicle:2009 OXT 5-spd 2011 STi hatch |
Got a few more thousand miles including a drive to Florance with 4 adults and stuff in the car. The only thing I am noticing is some rubber squeaking going over speed bumps which I am 99% sure are the rear swaybar mounting bracket bushings (this has occurred before). I am happy with this set-up. Next summer, PnP craziness and an 18G
![]() Quote:
#2495 |
Member#: 91941
NESIC
#2496 |
Member#: 7958
Vehicle:09 GH B+ |
not "need" in the literal sense, just that the firmer tops would add to the performance gains is all
#2497 |
Member#: 91941
NESIC
I wanted to get them, but they were just out of my price range for the budget on this project. They are expensive! I don't need anything else though, do I?
#2498 |
Member#: 7958
Vehicle:09 GH B+ |
your good to go- get a quality alignment when your done
#2499 |
Member#: 91941
NESIC
Nice!
About that alignment... What kind of specs should I ask for? Someone mentioned earlier that I should get max negative camber in the front and ask for zero toe all around. When I go to the alignment shop, is that all I have to ask for, or are there specific specs I should ask for? I apologize for being a complete noob. ![]() |
#2500 |
Member#: 7958
Vehicle:09 GH B+ |
| Thread Tools | |
| Display Modes | |
| The HID FAQ Thread - Read before posting your questions | dithergizzard | Electrical & Lighting | 569 | 04-24-2013 08:53 PM |
| What does your rim/tire combo weigh? Post your setup + weight | Trevor723 | Tire & Wheel | 42 | 06-04-2010 10:40 PM |
| Post your setup... | az ej20 fan | South West Impreza Club Forum -- SWIC | 20 | 02-10-2004 11:59 PM |
| Are these gauge readings correct? post yours too please! | T33 | Factory 2.0L Turbo Powertrain | 7 | 04-28-2003 01:35 PM |
