Old 10-17-2008, 02:17 AM   #2501
socrates42
Member#: 7747
2004 WRX 5door 5spd
08 E90 M3
I've got to replace my stock strut assemblies for the winter, does anyone know if 06 sti take offs will fit on an 04 wagon? Will I loose anything other than camber?
socrates42 is offline   Reply With Quote
Old 10-17-2008, 02:54 AM   #2502
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The take-off SPRINGS will fit. The take-off struts won't fit.
Old 10-17-2008, 11:40 AM   #2503
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
The rear struts will fit, but only front housings from an 04 STi will fit.
Superorb is offline   Reply With Quote
Old 10-17-2008, 12:07 PM   #2504
SilverFleet
Member#: 91941
2012 Mazda3, 87 CSX,
79 Trans Am WS6
Originally Posted by BIGSKYWRX View Post
I read through your FAQ and it's really informative. I figured someone would post something like that. Again, sorry for being a total noob. So basically, I want:
-somewhere between -1.4 and -3.0 neg. front camber
-stock settings on the rear camber
-zero toe
-zero cross camber
-zero cross toe
Are these settings ok?
SilverFleet is offline   Reply With Quote
Old 10-17-2008, 02:42 PM   #2505
BIGSKYWRX
Member#: 7958
09 GH B+
For most instances I would just max out the front oe bolts (generally good for -1.3ish) and call it good for camber (if your autoxing then consider going w/ more neg camber up front)
otherwise yes that looks fine
Old 10-17-2008, 02:46 PM   #2506
stan_tichomirov
Member#: 150689
2007 Forester XT Ltd
I have an '07 FXT. Currently am on '04+ WRX sedan struts with koni inserts, and RCE wagon springs. I'm using the HDPE 1/2" spacers on the front and the back to gain more height. 0 toe, -1.5 front and -1 back chamber.
I've been running this for a few thoursand miles, and find it a bit too stiff for my daily driving. When I'm in the car alone it's great, but with people/dog in the car I'm more aware of the stiff ride.
So, I want to try '05 STi springs. I'll see how it comes out without spacers, and can add 1/2" rear 1/4" front spacers if needed. What do you guys think?
Car as it sits now:
Stan
stan_tichomirov is offline   Reply With Quote
Old 10-17-2008, 03:15 PM   #2507
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Looks good to me The STi springs only lower a few mm over stock wrx springs, but I'm not sure how they compare to RCE springs which I know are lower/stiffer.
Old 10-17-2008, 04:18 PM   #2508
stan_tichomirov
Member#: 150689
I want to be closer to stock WRX height. I'm at a point now where the geometry is on the border of going to crap and affecting handling, the stiffness of the springs offsets that a bit. I want to be 1/2" - 1" higher than now, less stiff and same stance. I can adjust the sway bars stiffer to compensate for the lower spring rate.
RCE wagon springs are too low for my car. Here's my car without the 1/2" spacers.
Stan
Old 10-17-2008, 06:45 PM   #2509
BIGSKYWRX
Member#: 7958
09 GH B+
on an Impreza the oe STi springs lower ~ 10mm, the RCE springs ~ 30mm
you should see an ~ 20mm ride height gain
Old 10-17-2008, 07:04 PM   #2510
stan_tichomirov
Member#: 150689
Perfect! Sounds exactly what I'm looking for. I've read reviews of '04 STi owners using kons with the stock springs and they love it. FXT is basically an '04 STi as far as suspension and weight goes.
Stan
Old 10-18-2008, 03:56 PM   #2511
socrates42
Member#: 7747
2004 WRX 5door 5spd
08 E90 M3
Whats the difference?
Old 10-18-2008, 03:58 PM   #2512
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The 05+ STis got a new knuckle with a different clevis bolt pattern.
Old 10-18-2008, 04:02 PM   #2513
BIGSKYWRX
Member#: 7958
09 GH B+
different pattern and the clevis is wider (beefier knuckle) on the 05+ STi
Old 10-20-2008, 12:07 PM   #2514
socrates42
Member#: 7747
2004 WRX 5door 5spd
08 E90 M3
so you couldn't make a shim to make it fit, the actual holes are in a different spot? that kills my plans for 06 take offs then.
Old 10-20-2008, 02:16 PM   #2515
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
There's no way to make an 06 takeoff fit a WRX short of replacing the spindles too.
Old 10-28-2008, 12:14 AM   #2516
SilverFleet
Member#: 91941
79 Trans Am WS6
I finally had the time today to install my suspension. Here's the current setup:
-Tokico D-Spec struts
-STI Pink wagon springs
-Stock tophats
-Paranoid Fabrications fender braces
-Replica STI rear strut bar
-20mm bugeye sedan RSB
I had a really tough time with this install! I had a friend with me, and usually,we work very fast. We timed the whole install, and it took a good 6 hours. In the end, I think it was all worth it. The car rides a lot better now, and I like the adjustability on the struts. I have it on 5 turns from full for now. I decided to try out adjusting the camber on the struts as well. I used the stock bolts and maxed out the negative camber. It handles really nice now. It also looks absolutely killer!
I also wanted to thank all that helped me out with picking everything out and helping me understand everything. I really appreciate it!
Old 10-28-2008, 12:17 AM   #2517
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
If that was your first time for doing those mods, 6 hours is not a shameful time at all. Good job!
Old 10-28-2008, 12:23 AM   #2518
Xcelr8to1320
Member#: 131272
2003 WRX Wagon
where's the best source for the STi wagon pinks?
~Alex
Xcelr8to1320 is offline   Reply With Quote
Old 10-28-2008, 12:55 AM   #2519
SilverFleet
Member#: 91941
79 Trans Am WS6
All we did in those 6 hours is the struts and springs. The other stuff was already on the car. Also, I pre-assembled the rear strut assemblies before we began!
I got the wagon pinks from Subaruwrxparts.com. Subarugenuineparts.com is another place that carries them. I believe they both had the same price, but since I'm located in MA, I ordered them from Subaruwrxparts.com as they are in NH. The shipping was much less for me than getting them from Subarugenuineparts.com, which is located in the Northwest. I'd get them from the one with the cheaper shipping, whichever one that may be for you.
Old 10-28-2008, 01:02 AM   #2520
yosemitemtb
Member#: 23437
'02 WRX Wagon
WR Blue Pearl
Did the whole install go slow or did one or two things hang you up? My first suspension install went a little long when I forgot the conical washer under the front tophats.
yosemitemtb is offline   Reply With Quote
Old 10-28-2008, 01:19 AM   #2521
Xcelr8to1320
Member#: 131272
2003 WRX Wagon
thanks SilverFleet, i want to do my wagon's suspension in the spring/summer.
~Alex
Old 10-28-2008, 01:21 AM   #2522
SilverFleet
Member#: 91941
79 Trans Am WS6
We had a hard time getting the rears off the car. The bolts were really stuck on there. Once we got them out, slapping the new ones in wasn't that bad. the fronts made us want to kill ourselves though. We got them off nice and easy, but getting that lower section of the tophat lined up where it was supposed to be was a major PITA. That took forever! The rubber isolator kept getting jammed in there wrong, and it was hard to get the lower part of the spring and that lower part of the tophat where they needed to be at the same time. Getting them back in the car was really easy, as was adjusting the camber.
Old 10-29-2008, 01:49 PM   #2523
wrkXwagon88
Member#: 142458
2007 WRX Wagon
Default parts in!!!
IM SOOOO excited to put in my new perrin suspension.
New 22mm F+R Sways & F+R Endlinks.
Until a good point was brought up: If Im changing a part of the suspension, Do I have to get an Allignment??
Am I gonna have to wait to scrape up enough $$$ to buy the koni inserts for the STI springs I already have????
Do i do it all at once or can i stiffen it before lowering it?
(without affecting alignment)
migs
wrkXwagon88 is offline   Reply With Quote
Old 10-29-2008, 02:04 PM   #2524
Xcelr8to1320
Member#: 131272
2003 WRX Wagon
if it's a major component, i would strongly advise an alignment.
if possible, do everything to the suspension at one time, then align.
if you disassemble after an alignment and then reassemble there is a chance that someone has shifted enough to cause an alignment change.
~Alex
Old 10-29-2008, 02:12 PM   #2525
wrkXwagon88
Member#: 142458
2007 WRX Wagon
[quote=Xcelr8to1320;24264267]if it's a major component, i would strongly advise an alignment.
So are SWAYS & ENDLINKS considered "major component"?
I dont know how long it will be before i can buy the inserts...
The HID FAQ Thread - Read before posting your questions dithergizzard Electrical & Lighting 569 04-24-2013 08:53 PM
What does your rim/tire combo weigh? Post your setup + weight Trevor723 Tire & Wheel 42 06-04-2010 10:40 PM
Post your setup... az ej20 fan South West Impreza Club Forum -- SWIC 20 02-10-2004 11:59 PM
Are these gauge readings correct? post yours too please! T33 Factory 2.0L Turbo Powertrain 7 04-28-2003 01:35 PM
Message Board Statistics All times are GMT -4. The time now is 02:32 PM.
