Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 02-18-2005, 11:25 AM   #251
mrazntre
Member#: 30156
2003 WRX Sportwagon
MBP
My current setup:
Sedan rear sway bar (that's it )
I've got other crap that doesn't really do much:
Front/rear strut bars
KB exhaust hangers
KB shifter bushing
Whiteline rear diff bushing
Whiteline steering rack bushing
mrazntre is offline   Reply With Quote
Old 02-18-2005, 11:50 AM   #252
BIGSKYWRX
Member#: 7958
09 GH B+
Originally Posted by forced4
Related question: What manufacturers produce GGA/GGB specific front swaybar upgrades? The only one I can think of is Whiteline. I am talking about direct drop in, no monkeying around with control arms/endlinks/etc.
Cusco makes a GC (turbo) front 21mm (maybe a 22mm too?) bar- this may work on the wagon- I'm 99.9% sure the non turbo GC ones won't- different cross member and thus shape.
It would be nice to see if the Cusco one is a fit- don't know if anyone has tried this or not.
mrazntre- you've got to start somewhere- I'd say the RSB is a good place
Big Sky
Old 02-18-2005, 03:47 PM   #253
ElGranBanò
Member#: 38910
02 wagon:
Tein Type HG
17in Rota SDR
215/45/17 Kuhmo 712 (MX are stickier, 712 last longer)
no rubbing
ElGranBanò is offline   Reply With Quote
Old 02-18-2005, 03:51 PM   #254
BIGSKYWRX
Member#: 7958
09 GH B+
More on the HG ^- ride height, alignment? Thoughts on ride for daily driving, thought on performance on "tarmac"- I'm pretty sure it's very capable on the gravel
I've often thought this might be a good choice for someone like myself that runs both dirt and "tarmac"- I think there is even an option to go to slightly stiffer springs as well?
Old 02-18-2005, 04:13 PM   #255
ElGranBanò
Member#: 38910
HG ride height is about the same as stock right now -and we tryed to make it higher. It only took two trys adjusting the spring pearches to get the rear as high as the front.
My alignment isn't quite right just yet (the inside of my front tires are burned out), but as long as you don' t want massive negative camber, it shouldnt be a problem. With the camber plates maxed out I think I'm around -1 (?).
This is my daily driver. HGs compression and rebound are adustable, its easy to find a comfortable setting that still handles great (I use stock sway bars). HGs are perfect for me and I've never regretted their lofty pricetag- even the used ones I got. Even with thier high price, I'm suprised there are not more daily-drivers with HGs.
Yup, its a pure joy on gravel with Yokohama AO35s on vintage 15in RL-7s.
Old 02-18-2005, 04:20 PM   #256
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
We need some close up pics with the wheels off!
Arnie is offline   Reply With Quote
Old 02-18-2005, 04:29 PM   #257
ElGranBanò
Member#: 38910
^ lemme see what I have at home
Old 02-18-2005, 04:40 PM   #258
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
A pic like this would be cool:
My Group 4
Old 02-18-2005, 04:41 PM   #259
Got Groceries?
Member#: 25323
2003 WRX Wagon
Prodrive lowering springs
Koni inserts - full soft front, 1/4 turn rear
Group N strut tops
SPT rear wagon swaybar
I have to agree, the Koni shocks really are every bit as good as all the gushing suggests. MUCH more refined than the AGX's. I have discovered though that with both front and rear on full soft, the car does porpoise a bit, hence the 1/4 turn in the rear. Nice, flat response now.
I'll have to check into more of this camber bolt voodoo as well before I find a local shop to do an alignment.
I've got a full set of the Group N suspension bushings sitting in the garage waiting for a spare few days this spring...
Got Groceries? is offline   Reply With Quote
Old 02-19-2005, 03:17 PM   #260
sirfrankwilliams
Member#: 6817
2008 E91
Type HG: (front, top front, rear)
sirfrankwilliams is offline   Reply With Quote
Old 02-19-2005, 03:22 PM   #261
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Aweome! Thanks very much for posting!
Old 02-19-2005, 06:38 PM   #262
voam
Member#: 33460
2003 WRX Wagon
Originally Posted by Roamin'Coyote
spelk did the same thing I did...I've got a spare set of struts AND my own OEMs if anyone needs donor struts. Guy near me was moving and gonna throw them out...figured I'd buy them and hang onto them for other koni wagon people. Lemme know if you need a set.
-wYlie
Hey, I could use a set for a KONI insert install! I'll pm ya.
voam is offline   Reply With Quote
Old 03-18-2005, 08:32 AM   #263
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
Crystal Gray, Silver
Who's running a larger front swaybar? If so, what kind and where'd you get it?
Old 03-18-2005, 10:56 AM   #264
BIGSKYWRX
Member#: 7958
09 GH B+
The only wagon specific front bars that I'm aware of are the Whiteline ones. Cusco does sell a GC turbo model (21mm and 22mm) that could possibly work- not sure.
I'm running a 21mm STi sedan front, but have the GC aluminum arms which dictate a wider sway bar (sedan).
I'd be curious to see if there are others out there as well.
Big Sky
Old 03-18-2005, 12:29 PM   #265
joe r
Member#: 53412
2003 Outback
Black and Gold.
I just installed tein basic coilovers on my wagon & I am verry happy with them.
Now if I could find some legacy mutimesh factory wheels I would be set.
joe r
joe r is offline   Reply With Quote
Old 03-18-2005, 04:44 PM   #266
TurbojonLS
Member#: 38772
2 Cars, No Bling
I finally have something to add to this thread:
DMS 40mm coilovers set to 355mm from hub to top of fender arch
FSB - Cusco 21mm Sedan bar w/ Noltec Wagon endlinks
RSB - Whiteline 20mm adjustable (set at middle setting) w/ kartboy endlinks
Was first aligned at -2.3*F/-2.0*R Camber w/ 0 toe. Front camber allowed Falken Azenis 225/45-17s on +48 offset 17x7.5 wheels to fit w/ no rubbing. Rear caused my 205/55-16s on +53 offset 16x7 stock RS wheels to rub. I've since taken the camber back in the rear to closer to 1*, & the 16s fit fine. Haven't tried the 17s yet though.
Update: I'm now running USDM STi springs on AGXs, a GC Cusco bar (fits much better), & front & rear strut tower bars.
TurbojonLS is offline   Reply With Quote
Old 03-18-2005, 07:54 PM   #267
Lowball
Member#: 24198
02 WRX Sport Wag
Black to reality.
What is the reason you went back to -1deg camber vs the -2deg? Just wondering what you felt while driving that made you change?
Lowball
Lowball is offline   Reply With Quote
Old 03-18-2005, 10:19 PM   #268
BIGSKYWRX
Member#: 7958
09 GH B+
I'm guesing inboard rubbing- the DMS are infamous for high camber in the rear- even w/ their most positive camber washer. When I ran them on full positive (they use a camber washer that can be turned both ways) I had very little inboard clearance in the rear.
Old 03-19-2005, 01:40 AM   #269
abaxter34
Member#: 34723
fwd FTL!
i have the whiteline wagon specific 22mm fsb. i got it a while ago from mpj performance for around $100 shipped. i love it. it compliments my rear bar set at 22 very nicely. it increased front end grip quite a bit and made the car completely neutral. i think those running just the rear bar would be surprised at what theyre missing.
abaxter34 is offline   Reply With Quote
Old 03-21-2005, 03:52 AM   #270
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
I'm running the Whiteline adjustable front bar which I bought from allsubaru.com, mpjperformance.com also has them. The stiff setting is supposed to be a bit stiffer than the fixed 22mm bar while the soft setting is a bit softer. Stock springs/struts with the sedan 20mm rear bar.
The front bar improved turn-in and overall grip without any drawbacks that I can notice for your typical daily driver and fun backroad use.
drees is offline   Reply With Quote
Old 03-21-2005, 12:32 PM   #271
phantomsr
Member#: 69071
2002 Stg2-WRX Wagon
WRB & Dust
I just finished putting in the Whiteline 22mm wagon front bar and Perrin 24mm adjustable rear bar. Perrin Endlinks on the rear and stock links on the front, since my front links didn't come in before I put the bars on. I have the rear bar on the middle setting which I think is a tad too light but since it's been snowing I haven't been able to get a good feel for it. So far it feels 200% better than stock. I did take a quick rip with only the rear bar in and turn in was greatly improved. The front bar didn't make as much of a difference in low G cornering and it'll be a week or 2 till things dry up enough to really test it out. Definately worth the $$ though.
phantomsr is offline   Reply With Quote
Old 03-21-2005, 01:37 PM   #272
tegnwrx
Member#: 8589
Prodrive springs
sedan rear sway w/perrin endlinks
super pro steering rack bushings
noltec front camber/caster plates
alignment
Front camber -1.8/-1.8
caster 5.2
Rear camber -1.4/-1.4
Zero toe all around
tegnwrx is offline   Reply With Quote
Old 03-21-2005, 07:02 PM   #273
RR
Member#: 48191
2012 WRX
Ducati Monster
I am going to be picking up USDM STI struts/springs this weekend. As part of the deal I am also getting a set of Eibach Pros. I am planing on getting the Nortec/MRT camber/castor plates. I am going to try and make do with the STI springs from what I read the Eibach's are more apperance less performance. Down the road I will probably switch to STI wagon specific springs when finances allow. If anybody has any comments on this setup feedback would be appreciated.
I also have a sedan sway and whiteline strut bar.
RR is offline   Reply With Quote
Old 03-21-2005, 07:06 PM   #274
Jard
In the silly seat
Member#: 34935
SPB- 2013 Smugmobile
and DADCORE
My old setup:
GT Spec II Front Strut Bar
STi Replica Rear Strut Bar
STi 21mm Rear Sway Bar
Kartboy Endlinks
STi Pink Wagon Specific Springs
JDM v8 STi Struts(sedan)
Noltec Camber/Caster Plates in Front
Group-N Tops in Rear
Alignment:
Front Camber -1.6
Rear Camber - 0.8
Toe 0 all around
Max Front Caster
This was a very good all around and fast street suspension. It was perfect for a daily driver. Very neutral handling, but you could get some oversteer if you lifted.
Jard is offline   Reply With Quote
Old 03-21-2005, 07:36 PM   #275
RR
Member#: 48191
2012 WRX
Ducati Monster
Originally Posted by Jard
My old setup:
Kartboy Endlinks
Alignment:
Front Camber -1.6
Rear Camber - 0.8
Toe 0 all around
Max Front Caster
is their any advantage to the Group-N Tops in Rear?
The HID FAQ Thread - Read before posting your questions dithergizzard Electrical & Lighting 600 03-10-2014 10:27 AM
What does your rim/tire combo weigh? Post your setup + weight Trevor723 Tire & Wheel 42 06-04-2010 11:40 PM
Post your setup... az ej20 fan South West Impreza Club Forum -- SWIC 20 02-11-2004 12:59 AM
Are these gauge readings correct? post yours too please! T33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-28-2003 02:35 PM
