Old 03-28-2010, 02:13 PM   #3651
SuperHawk
Member#: 1036
2006 WRX Wagon Ltd.
From what I have read the GR2's have the same dampening as the AGX struts set on 2.
Dennis
SuperHawk is offline   Reply With Quote
Old 03-28-2010, 06:22 PM   #3652
pescatom
Member#: 215425
16 STI DGM
06 WRX Wagon SGM
Originally Posted by labcoat View Post
How did you install the Com C's and whats your caster?
Thanks
R-
Hey - I removed the front struts, compressed the springs, and removed the stock unit, installed the Com'Cs, and put it all back together. Did it all with hand tools, other than an electric impact wrench to work the spring compressors. Wasn't bad with the right tools. I didn't get a caster reading from the alignment shop. Should have, but didnt.
pescatom is offline   Reply With Quote
Old 03-28-2010, 07:32 PM   #3653
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
Oh I'm sorry I meant did you set up them to be max camber, max caster or a littel of both?
Sorry for the confusion
R-
labcoat is offline   Reply With Quote
Old 03-28-2010, 07:37 PM   #3654
pescatom
Member#: 215425
16 STI DGM
06 WRX Wagon SGM
No problem. I installed them with the "max camber" setting alignment. ie, center hole was inboard and rear.
Old 04-03-2010, 07:04 PM   #3655
drifterx
Member#: 25128
2005 Baja turbo
well i finally got around to installing my agx's w/ ground controls (350f &250r), strut bars, and fender braces and holy hell what a difference.
i think i got my ride height set pretty much exactly where i want it (13.75" from hub to arch and the front and 13" hub to arch in the rear). at what point is the excessive lowering start to become a handling issue?
drifterx is offline   Reply With Quote
Old 04-04-2010, 01:13 AM   #3656
relliMmoT
Member#: 206931
2004 WRX Wagon
6MT JBP 318WHP//300WTQ
I have read the GR2's are about 15% stiffer than stock, and of course they ARE the stock strut revalved a little stiffer. (KYB makes the stockers for Subaru of course.)
Ive also the AGX are 20% stiffer on lowest setting.
The only thing I know FOR SURE is that the GR2s are around 15% or so stiffer, says KYB
relliMmoT is offline   Reply With Quote
Old 04-05-2010, 06:37 PM   #3657
Bankie
Member#: 37785
OT hates your car
So they (the GR-2s) should be a nearly perfect match for the STI pink springs?
Bankie is offline   Reply With Quote
Old 04-05-2010, 08:35 PM   #3658
scoobydrew06
Member#: 32951
^^ I've got the pinks on right now and I've had the GR2's sitting in my garage for a year. They'll be going on as soon as all this april snow goes away. I'll let you know how they feel.
scoobydrew06 is offline   Reply With Quote
Old 04-05-2010, 11:09 PM   #3659
Bankie
Member#: 37785
OT hates your car
I'll probably be ordering a set this week anyway. The stockers have 150k miles (about 100k with the pinks) on them now so they're probably in need of replacement.
Old 04-09-2010, 01:30 PM   #3660
drifterx
Member#: 25128
2005 Baja turbo
wow. just got back from getting my alignment and taking it for a quick spin and damn i love the way it sticks now.
-2.3 camber up front
-2 camber out back
and
0 toe all around
Old 04-09-2010, 01:38 PM   #3661
littlewhitewagon
Member#: 103068
11 STI sedan
-2 camber out back
and
0 toe all around
Ride height, suspension parts, and wheel/tire? I imagine that your rear will have camber wear if you aren't driving fast enough to get the outside to wear...
littlewhitewagon is offline   Reply With Quote
Old 04-09-2010, 01:52 PM   #3662
drifterx
Member#: 25128
2005 Baja turbo
13.75" hub to arch in the front
Agx struts
Ground control coils 350lb. Front and 250lb. Rear
25mm fsb
20mm rsb
Camber bolts f&r
Front and rear strut tower bars
Group n top hats
Lower h brace
Subframe lock bolts
Rear diff bushings
Outrigger bushings
Steering rack bushings
Front and rear endlinks
Fender braces
99 legacy gt snowflakes w/ hankook k406's
I'm aware tires might wear out a little quicker on street but the amount I drive annually with this car (maybe 10k and the amount of events I attend in the summer makes me think ill be okay
Old 04-09-2010, 01:53 PM   #3663
drifterx
Member#: 25128
2005 Baja turbo
Agx struts
25mm fsb
20mm rsb
Camber bolts f&r
Group n top hats
Lower h brace
Subframe lock bolts
Rear diff bushings
Outrigger bushings
Fender braces
Old 04-09-2010, 02:26 PM   #3664
subi400
Member#: 216984
1996 Impreza outback
Green
I have a 1996 impreza outback and just got some Enkei rsv wheels 17x7 with some 215 45r17 Maxxis MA V1 tires like two weeks ago. Other than the new tires and wheels, I have the KYB GR2's struts with the stock springs, everything else is stock for now..lol
I would eventually like to upgrade to a 20mm front sway maybe an adjust one, a 22m rear adjus sway with Perrin endlinks and stout mounts front and rear. I will be picking up some 05 wrx wagon struts with maybe 15k miles and will be pairing them up with some Epic Springs and wrx top hats for all four. I will also be upgrading all the bushings from the front to the rear with the polyurethane ones. Then I'll be getting some front and rear strut tower bars, well at least the rear strut tower bar. I think that is it for now
subi400 is offline   Reply With Quote
Old 04-10-2010, 06:36 PM   #3665
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
Default Top hat studs
I did some looking around but didn't find any satisfactory results.
From what I can tell I think the are 8 mm x 1 I would like to purchase longer studs so I can use my 3/8" saggy but spacers and a rear strut bar.
I can find is people that will sell me nuts and bolts, I'm not sure how this will work out.
So has anyone figured out what studs to purchase or do they even exist.
Thanks in advance
R-
Old 04-10-2010, 07:30 PM   #3666
BIGSKYWRX
Member#: 7958
09 GH B+
I think they are 8x1.25- you should be able to use bolts after removing the studs
Old 04-10-2010, 07:53 PM   #3667
Brisky
Member#: 148078
2001 Legacy GT
Birch White
Agx struts
25mm fsb
20mm rsb
Camber bolts f&r
Group n top hats
Lower h brace
Subframe lock bolts
Rear diff bushings
Outrigger bushings
Fender braces
Where did you get your sway bar and what brand is it?
Thanks!
Brisky is offline   Reply With Quote
Old 04-10-2010, 08:00 PM   #3668
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
Hmm If I use the bolts wont the nuts be contacting body?
Should I put the nuts on top of or under the saggy but spacers?
Ry-
Old 04-10-2010, 08:10 PM   #3669
BIGSKYWRX
Member#: 7958
09 GH B+
bolt head would go under, but here's something even better
scroll down a bit
http://www.camotoy.com/products/saggybutt/index.php
Old 04-10-2010, 09:09 PM   #3670
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
Default Re: Wagon Suspension- read and post your setups
scroll down a bit
Biggy been there done that shane told me its just a bolt kit same as i have from mach V
Ry-
Sent from my Droid using Tapatalk
Old 04-10-2010, 09:16 PM   #3671
BIGSKYWRX
Member#: 7958
09 GH B+
ahhh- they show a pic of studs
I looked McMaster-Carr and they only have SAE ones, no metric
Old 04-11-2010, 09:27 AM   #3672
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
Yea I looked there too McMaster is great I use them allot at work
I'm sorry I wasn't clear, I get the bolts head goes under but were does the nut go?... between the top hat and the saggy butt spacer?.. or the top of the spacer... or should i drill out the hole in the spacer so the nut doesn't interfere with any of the parts?
Thanks
Ry-
Old 04-11-2010, 09:31 AM   #3673
BIGSKYWRX
Member#: 7958
09 GH B+
I would assume on top of the spacer- the nuts, even on longer bolts shouldn't be interfering w/ anything (possible the metal dust cover, but I ran w/o those for years as I had adj struts to mess w/)
Old 04-11-2010, 09:46 AM   #3674
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
Yea well the dust covers are going as I have Koini's going in and I'm going to pre-assemble everything well soon.
Thanks
Ry-
Old 04-11-2010, 09:49 AM   #3675
BIGSKYWRX
Member#: 7958
09 GH B+
^ your going to like the Koni damping
The HID FAQ Thread - Read before posting your questions dithergizzard Electrical & Lighting 670 06-17-2016 08:50 AM
What does your rim/tire combo weigh? Post your setup + weight Trevor723 Tire & Wheel 42 06-04-2010 10:40 PM
Post your setup... az ej20 fan South West Impreza Club Forum -- SWIC 20 02-10-2004 11:59 PM
Are these gauge readings correct? post yours too please! T33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-28-2003 01:35 PM
