Old 05-22-2010, 10:12 PM   #3776
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Originally Posted by littlewhitewagon View Post
+1 on this, it seems that this combo works well for people. It used to be 235/40R17 was the ticket, but it seems that people are ok with the extra delay from the taller sidewall in exchange for the width.
The 9" wheel or even 8.5" are much more gangster, but the fitment is sometimes tight. For your STI struts, I think they are very close in clearance to the sedan struts. I used sedan struts with wagon lower arm parts and 9" with 245 fits with ease, only issue is the lack of camber which you can resolve with camber plates.
There is a group doing a groupbuy for a 5x100 version of 17x9 RPF1, this can fit the wagon with wagon lower suspension parts. Pricing is not bad and the wheel speaks for itself.
If they made the Boost in 17x9 I'd get that, but everyone has the DPT's and I'm just not a DPT fan. I'd love some Buddy Club 6-spoke wheels, but those are some serious money. RPF1's are out of my budget, new wheels/tires/lugs are already going to cost a ton. 17x8 is slightly cheaper as well, but I admit that a 17x9 wheels sure would look nice
Superorb is offline   Reply With Quote
Old 05-23-2010, 01:05 PM   #3777
pescatom
Member#: 215425
16 STI DGM
06 WRX Wagon SGM
Originally Posted by pescatom View Post
06 Wagon
Sti Wagon Pink Springs
Stock Struts
Whiteline Com C Front Strut Mounts
Stock Front Sway Bar
Whiteline 22mm adj Rear Sway Bar
Whiteline basic endlinks F+R
Whiteline F+R Strut Tower Braces
-2.1 F Camber
-1.5 R Camber
0 Toe
215x45x17 Bridgestone RE960 Pole Position AS on Stock wheels
225x50x16 Falken Azenis Summer on Konig Driver 16x7 et48 (old summer setup)
225x45x17 Dunlop Direzza Star Spec Summer on 04 Sti BBS Gold (new summer setup)
No rubbing on first two, but haven't mounted the 04 BBS yet...don't expect them to rub.
Update...
On the summer setup it does rub a bit on full lock on the inside. Was under there this morning and forgot to check where it was rubbing.
Installed an AD Motorsports 25mm adj front swaybar. It made an immediate improvement over the stock bar. Turn in feels more controlled and the rear end feels less twitchy. It's set at the soft setting with the rear 22mm still at soft setting.
Anyone running this combo with Pink springs find an "ideal" setup with the bar settings? Thanks!!! Mike
pescatom is offline   Reply With Quote
Old 05-23-2010, 01:37 PM   #3778
jdmboy
Member#: 240161
2002 wrx wagon R.I.P
87 bmw e30
hey guys, thought id post my set up.
-bc coilovers
-whiteline camber bolts all the way around
-cobb sway bars
-rota torque 17x8 with 48 offset
-245/45/17 bfgoodie g-forces
-fenders are rolled and pulled slightly all the way around
jdmboy is offline   Reply With Quote
Old 05-23-2010, 05:58 PM   #3779
Wagon Jon
Member#: 97630
2004 WRX Wagon
Red
Originally Posted by Superorb View Post
Sedan struts and you managed -1.6* with stock camber bolts?
STI takeoff springs
Tokico D-Spec
RCE Camber Plates
Stock Camber bolts
Camber bolts maxed out, camber plates as far as they would go before they hit the fender. Sorry if I wasnt clear.
Wagon Jon is offline   Reply With Quote
Old 05-23-2010, 08:02 PM   #3780
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Originally Posted by Wagon Jon View Post
STI takeoff springs
Tokico D-Spec
RCE Camber Plates
Stock Camber bolts
Camber plates make ALL the difference
Old 05-23-2010, 08:03 PM   #3781
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
I forgot to ask what offset would work best with the 17x9 or 17x8 wheels. What do you guys think?
Old 05-24-2010, 09:56 AM   #3782
jdmboy
Member#: 240161
87 bmw e30
IMO on a wagon with 9" wide wheels your going to want like a mid to low 40's offset (much higher than 45 and your probably going to hit the strut, and any lower than 40 your going to have to do serious fender work) as for a 8" wide rim a i like a 48 offset you will most likely have to do a little work but how much depends on tire selection of course.
Old 05-24-2010, 10:13 AM   #3783
BIGSKYWRX
Member#: 7958
09 GH B+
^ I'd agree w/ that assessment 40-42 for 9", 45-48 for 8" should be pretty close
you can always fine tune inboard rubbing w/ thin spacers
Old 05-24-2010, 11:02 AM   #3784
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Thanks guys
Old 05-24-2010, 12:44 PM   #3785
littlewhitewagon
Member#: 103068
11 STI sedan
This is generally correct, but it really depends on the strut or coilover. Like I said, I can easily fit 9" +45 and 245s with my KW and stock struts, but had much less clearance with my JICs. Pick your suspension, then get the wheel/tires that fit.
littlewhitewagon is offline   Reply With Quote
Old 06-10-2010, 11:13 AM   #3786
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Is there a Wagon compilation somewhere that lists drop-rates for springs? I'm trying to decide between RCE blacks, yellows, wagons, and Swift R Spec. I'm moving to Denver so I'd prefer a mild drop to clear snow covered streets.
Old 06-10-2010, 11:21 AM   #3787
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
Bigsky has a google spread sheet with specs on it.
RCE yellows and wagons are very simalar from what I understand I have yellows I'm thinking will go on next weekend.
Blacks are not much drop like STI take offs
I looked at swifts but I don't remember.
R-
labcoat is offline   Reply With Quote
Old 06-10-2010, 12:46 PM   #3788
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
R-
I'll need ground clearance, so that's what's leading me to the RCE blacks, but I still don't want to look like a monster truck. I can't find the rates I want with a drop I like.
I haven't talked to anyone with Yellows or Wagon springs that live with snow though.
Old 06-10-2010, 12:53 PM   #3789
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
Iirc blacks will give you like a half an inch drop like sti take offs at a higher /diffrent rates I can search right now but if you look for drop with sti take offs to a wrx and the blacks are simalar
Ry
Sent from my Droid using Tapatalk
Old 06-10-2010, 01:36 PM   #3790
cueball89
Member#: 90513
2003 wrx wagon
black
I've got wagon springs and they went through this last winter just fine with snow tires. I think NY snow might be different to Colorado snow though. lol
cueball89 is offline   Reply With Quote
Old 06-10-2010, 02:01 PM   #3791
JVD
Member#: 213130
R-
Pardon my ignorance...but where can I view this spreadsheet?
I'm ordering springs soon. Hate the saggy butt.
JVD is offline   Reply With Quote
Old 06-10-2010, 02:44 PM   #3792
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Ry
I'm already on STi takeoffs and STi struts and I'd like for a small amount lower drop, but I don't know how any springs will compare when they say they drop X car X amount when I don't have X car. For example, if they lower an 04 STi 20mm and 05+ STi 25mm, how low will it lower my WRX? I'm assuming 2mm lower than now since I've already got STi springs, but I don't know if my car originally was lowered 5mm or 10mm since the 05+ and 04 are different.
Have you driven in thick snow? Like 4"+ of snow on the ground?
Old 06-10-2010, 02:51 PM   #3793
jeisen
Member#: 27258
who dat be dat was?
I was 14"F/13.75"R hub center to fender with koni inserts in wagon housings and RCE Wagon springs. I drove through over a foot of snow with the car without any issues.
jeisen is offline   Reply With Quote
Old 06-10-2010, 03:58 PM   #3794
flyinghighlm
Member#: 156235
2002 Subaru WRX Wgn
You can view it right about here...http://spreadsheets.google.com/pub?k...fS2h3RXc&gid=1
Hope it helps out.
flyinghighlm is offline   Reply With Quote
Old 06-10-2010, 04:48 PM   #3795
JVD
Member#: 213130
Hope it helps out.
Hey thanks!
Who has experience with GF210 on a wagon? I'm hoping it will even out the fender gap a bit.
And yeah, snow doesn't really matter in these cars as far as I can tell. I've driven through over a foot of snow. Plowed through with ease.
Old 06-10-2010, 05:10 PM   #3796
cueball89
Member#: 90513
2003 wrx wagon
black
4", no problem. I don't think I've driven in more than 8" or 10", this winter was a little lame snow wise.
Old 06-10-2010, 05:14 PM   #3797
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
I was on a snowboarding vacation in WV and they'd gotten TONS of snow before we arrived. I was trying to go up a gentle grade with about 6" of snow on my stock 17" RE92 tires and just would not get up it. I'm on STi springs too so I'm not dropped much at all.
Old 06-10-2010, 05:45 PM   #3798
RobE
Member#: 114550
Found your problem.
RobE is offline   Reply With Quote
Old 06-10-2010, 06:18 PM   #3799
cueball89
Member#: 90513
2003 wrx wagon
black
Definitely get snow tires. You will be so happy. I hardly ever engaged my abs stopping during winter or broke traction accelerating.
I was rolling around on these, they are soft and squishy but in the snow they are amazing.
http://www.tirerack.com/tires/tires....Altimax+Arctic
Old 06-10-2010, 06:50 PM   #3800
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Originally Posted by RobE View Post
Found your problem.
Yeah, that's what I figured.
The HID FAQ Thread - Read before posting your questions dithergizzard Electrical & Lighting 670 06-17-2016 08:50 AM
What does your rim/tire combo weigh? Post your setup + weight Trevor723 Tire & Wheel 42 06-04-2010 10:40 PM
Post your setup... az ej20 fan South West Impreza Club Forum -- SWIC 20 02-10-2004 11:59 PM
Are these gauge readings correct? post yours too please! T33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-28-2003 01:35 PM
