Welcome to the North American Subaru Impreza Owners Club Wednesday July 29, 2015
Old 02-03-2012, 07:18 PM   #4651
T.bloy
Member#: 307035
2007 Wrx wagon
Psm
Originally Posted by BIGSKYWRX
what's your alignment numbers? spring rates on the H&R's? tires & rims?
Alignment numbers, I don't know
The website i found the rss+ coils on don't have a spring rate listed. Here's a link http://www.andysautosport.com/subaru...r00912840.html
Rims are the gold bbs sti wheels and tires are undecided.
Thanks
T.bloy is offline   Reply With Quote
Old 02-03-2012, 08:11 PM   #4652
BIGSKYWRX
Member#: 7958
09 GH B+
are these parts you have on currently or what your thinking about getting?
Old 02-03-2012, 11:08 PM   #4653
T.bloy
Member#: 307035
2007 Wrx wagon
Psm
The car is completely stock right now, that is a parts list I put together for the upgrades I am looking to do.
Old 02-04-2012, 10:57 AM   #4654
BIGSKYWRX
Member#: 7958
09 GH B+
ahhhh if that's the case, I'd re-consider going the coilover route- they tend to be futzy, and unless you need extremely high spring rates (ie national competitive autox'r or track day *hore) then a more modest spring/quality damper is probably a better option imo, add to that front camber plates or WL Com C's and Grp N rear tops and you have something that is suitable for daily driving and still sporty enough for a track day/autox/canyon carving
Old 02-04-2012, 08:20 PM   #4655
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Default 2002 WRX wagon
Set up for fun, canyon runs and the very occational auto-x.
KYB AGX struts- bottom holes slotted
HR springs
Whiteline com-c tops
Whiteline ALK
Eibach(SPC) lateral links
Hotchkis sway bars
And because wheels/tires are part of the suspension
RS 6 spokes (16x7)
Continental DW 225x16-50(a tad to big for the wheel, 215x16 would be better)
Front: camber -2 with 0 cross camber. Toe 0.00
Rear: camber -1.5 with 0 cross camber. Toe 0.00
Overall very fun to drive. The struts don't offer to much flexibility but they work well enough and are built well. At first I thought the springs were a bit to low, but I have grown to like where they have settled. They do work well with the struts. Com-c set at max neg camber max caster. The Eibach lateral links are not bad(China made by SPC). I was expecting worse and I would say they are better quality than stock. They have rubber bushings that seem to be of a harder compound than stock. Very good adjustability too. Again nothing fancy, but fun to drive.
Bikelok is online now   Reply With Quote
Old 02-08-2012, 07:51 PM   #4656
runboyrun
Member#: 287901
2003 WRX Wagon
Guys! Long time follower, but I need your help now. Girlfriend cant stand my coilovers, I need a new setup and would like your recommendations. The Wagon is my DD but I also want a setup that I can have some dirt/gravel fun with. I had looked into lifting it w/ Forester Struts and JDM pink springs but was told its not necessary. Im now looking into the sti struts with stock springs, but im not sure about the camber issues. Please any recommendations are welcome.
runboyrun is offline   Reply With Quote
Old 02-08-2012, 08:33 PM   #4657
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
STI tack offs with Group N's in the rear and Com'cs up front if you want some more height you can get saggy butt spacer front and rear.
If you want more there is a bolt on spacer (IIRC Jackson racing) check dirty impreza they no allot about getting up.
hope this is helpful.
R-
labcoat is offline   Reply With Quote
Old 02-08-2012, 09:17 PM   #4658
bdj238
Member#: 207561
2005 WRB WRX WAGON
PPG Trans
read more through this forum, search is your friend.
I went through looking for a similar set up on pg. 175:
Originally Posted by bdj238
It seems that for a jack of trades most people are saying koni yellow and springs + camber plates. I would have thought the adjustability of coil overs would be better, which is where I get confused.
What are some suggestions?
Thanks for the help as i feel a bit overwhelmed with the vast amount of information around.
Originally Posted by BIGSKYY
"coilovers are great if you need them ie road racing, competitive autox, rally, etc- for a daily driver probably not the best bet
if you buy cheap ones they are close to useless, if you buy expensive ones they are more likely built very purpose specific
a quality damper and decent springs makes a lot more sense for a daily driver
I can't speak to the gravel worthiness (or unworthiness) of the Koni's, but can say for daily driving, spirited driving, autox and track days- they are a VERY good damper
for a daily driver STi springs are a good compromise on spring rates and can be had for a very good price
add in something along the lines of the Com C stru mounts up front and Grp N rears and get a good alignment and you should be in pretty good shape"
there is a ton of info around on exactly what you are looking for. Get a few more specifics like how much your willing to spend, how much work involved you want, etc.
Like was previously posted STI Take-off's are a cheap and easy way to go, just make sure you get the applicable year model and struts that aren't blown. Also you will for sure need Top Hats to correct for some of the camber issue, LCAs help even more.
bdj238 is offline   Reply With Quote
Old 02-09-2012, 06:40 PM   #4659
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
Ok. Just got an 06 WRX wagon about a month ago and I'm looking into some set-ups for a DD that will see some auto-x use. I've read a ton of stuff on the suspension super sticky and my head is swimming with info.
The goal- I want about a 2-3 inch drop because I'm kind of a form>function type of guy, but since this will be a DD and see some racing use, I don't want to be riding the bump stops and plan on adding the Whiteline roll center kit to keep the camber curve more or less in line at the lowered height. I know there aren't any springs that will drop it like I want without riding like crap on stock struts (s-techs), so I'm looking for a good spring/strut combo that offers a 2-3" drop and proper damping with a relatively stiff spring rate. And what other things (top hats, camber plates, spacers, etc) would be needed with different spring/strut combos? Otherwise I'm probably going to be going the dreaded cheap coilover route with some BC BR's.
On a side note, would a sedan front sway and endlinks work without switching the LCA if I went to coilovers (which will probably have "sedan fitment")?
Sway bars will probably be 27mm front and 24mm rear. I have this feeling that the 27 would be a little too stiff out front with a stiffer spring rate, so I'm thinking a 24mm would be more appropriate, but would be more prone to oversteer with the 24mm rear too.
flat4LGT is offline   Reply With Quote
Old 02-09-2012, 08:29 PM   #4660
jakechup
Member#: 280793
02 WRX Wagon
I travel on a lot of dirt roads where I live. What would be a good affordable suspension for my 02 wagon?
Jake
jakechup is online now   Reply With Quote
Old 02-09-2012, 11:47 PM   #4661
thejaredhuang
Member#: 86206
2006 WRX Wagon
2-3" drop pretty much takes all the spring possibilities out. You can get some S-Techs which you don't want or some DF210s. Neither are stiff enough for that much drop.
thejaredhuang is offline   Reply With Quote
Old 02-10-2012, 01:38 AM   #4662
sleepyfu
Member#: 124219
2004 W(agon)RX
Jake
Do you need the ground clearance? If so keep stock springs and get KYB struts, gr2 is nice and AGX gives you some additional settings. I had an 96 legacy outback and all I did was gr2 struts and it handled beautifully on trails.
sleepyfu is offline   Reply With Quote
Old 02-10-2012, 09:40 AM   #4663
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
That's pretty much what I figured. I tried my best to research set ups that offer that drop with a good spring and damping rate, but had no luck. Thanks for the help though. I'll post the final set up I choose after I get everything ordered and installed so I can post any fender work that I may have to do.
Old 02-10-2012, 06:06 PM   #4664
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Jake
STi springs/struts. They're great on dirt/gravel since they're inverted struts. I used to tear down dirt/gravel roads in my wagon all the time on that setup. Only lowers 20mm or so.
Superorb is offline   Reply With Quote
Old 02-10-2012, 07:59 PM   #4665
BIGSKYWRX
Member#: 7958
09 GH B+
^ that would be my recommendation as well, slight increase in spring rates, moderate lowering and tougher than nails dampers
you're going to have a very tough time finding 04 STi struts w/ low miles now, but the internals can be swapped (from a 05-07), Feal suspension is also offering a full internal replacement and they can custom tune the damping for your particular need
the dealers can still get the v7 STi wagon setup (springs/struts/few bushings) as another option
Old 02-11-2012, 11:48 PM   #4666
e31bimmerman
Member#: 153642
95 Legacy Wagon
Red
Can't believe I missed this thread. I went through a HELL of a time getting my coils to work on my wagon.
So, first things first. I'm running AST 4100s with F/R Vorshalg camber plates (high caster front version). It's on a 95 Legacy, but the BK Legacies have the exact same issues with rear wagon geometry as a GD-chassis wagon, as I discovered.
I ordered my shocks and at the time I was #2 in the country running unmodified ASTs on a wagon. Turns out that wagon rear geometry is different enough to cause side loading, and so I spent the next few months working with AST to figure out what the problem was and to fix it.
The problem is that the side loading was enough to cause the shock to bind internally-- the original design was made for autocrossers and designed to take loadings from a 285 A6 Hoosier...which my car will never see. The loading path in a wagon is different enough to where the secondary support piston was dragging. AST worked with me to get this fixed (my tire was the 'damper' in my suspension for a little while, that was fun). This same issue had been seen by AST-UK but -USA had not heard of it....but now they know the problem and have a fix that works wonderfully.
I believe that my BK, which is a hybrid of GC front and GD rear components, had a worse issue than most GD (GM? i dunno) wagons, but if you have ASTs and they don't ride like they are supposed to, call AST and ask about the wagon rear shock fix. If you are ordering, make sure you order WITH the fix. Vorshlag is aware of the issue, I do not know about other retailers.
The setup works great now, but if anyone is looking at buying ASTs for their wagon (there's an amazing sale going on btw), make absolutely sure you mention it is for a wagon.
Hopefully this helps someone down the road.
BTW, I love the coils. Best upgrade for the car I've done besides the HID retrofit, and allows the car to boogie like no ancient wagon should be able to. Fun times.
e31bimmerman is offline   Reply With Quote
Old 02-12-2012, 09:34 AM   #4667
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
e31bimmerman thanks for sharing your experience, but could you fill out your profile, so am I to understand that you have a Leggy wagon? what year. Also jealous I have always wanted a Leggy wagon.
R-
Old 02-13-2012, 06:16 PM   #4668
GTX666
Member#: 183128
2002 wrx
wrb
This week-end, I'm picking up a 2006 wrx wagon and I want to put some epic engineering springs.
What's the most commun wheels set up, for a wagon without rubbing?
GTX666 is offline   Reply With Quote
Old 02-14-2012, 04:42 AM   #4669
makofoto
Member#: 25243
2006 Legacy Outback
makofoto is offline   Reply With Quote
Old 02-15-2012, 11:06 PM   #4670
runboyrun
Member#: 287901
2003 WRX Wagon
Are there D-Specs made for the wagon yet?
Old 02-16-2012, 12:42 AM   #4671
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Nope, there isn't much specifically made for the narrower wagons.
Old 02-16-2012, 03:38 AM   #4672
e31bimmerman
Member#: 153642
95 Legacy Wagon
Red
R-
Will do.
I've a 95 Legacy wagon, it's fun.
Old 02-16-2012, 01:46 PM   #4673
Jmoney69
Member#: 275618
2011 2.5i wagon
Just curious does anyone know if 2011 wrx wagon disk rotors will fit a 2011 NA wagon? And if I'm on the wrong page for a question like this where should I ask.
Thanks in advance.
Jmoney69 is offline   Reply With Quote
Old 02-16-2012, 11:13 PM   #4674
jamal
Member#: 71875
98 2.5GT
my wheels fit
nice to see some confirmation of something I've suspected for a long time. I noticed I kind of had to force the sti struts on my car into place to get them bolted to the uprights, and figured once the car was at ride height it wouldn't be so bad.
when I put in all the really stiff TIC suspension bushings I noticed that the ride got A LOT worse, likely because of this.
jamal is offline   Reply With Quote
Old 02-17-2012, 12:54 PM   #4675
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Awesome that you guys figured this out... what I don't understand is why other coilover/struts don't experience the same problem.
Are the cleavis "ears" on the AST longer or something?
chimchimm5 is offline   Reply With Quote
The HID FAQ Thread - Read before posting your questions dithergizzard Electrical & Lighting 602 03-20-2015 10:38 AM
What does your rim/tire combo weigh? Post your setup + weight Trevor723 Tire & Wheel 42 06-04-2010 10:40 PM
Post your setup... az ej20 fan South West Impreza Club Forum -- SWIC 20 02-10-2004 11:59 PM
Are these gauge readings correct? post yours too please! T33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-28-2003 01:35 PM
