Old 03-25-2012, 01:55 AM   #4726
SubieMonte
Member#: 264803
2005 WRX Wagon
Originally Posted by cerealkillerJST
Hi All,
I just installed the following on my 02 Wagon:
STi Wagon Pinks
KYB Excel-G Struts
How are these working out?
SubieMonte is offline   Reply With Quote
Old 03-27-2012, 12:08 PM   #4727
cerealkillerJST
Member#: 204107
2002 WRX Wagon
SRP
It's working out nicely. Now I know just how beat the old struts were, and I like the new firmness (although I wouldn't want much firmer for DD). Bumps are "one and done", no bobbing. The KYBs seem to have enough damping for the pinks.
cerealkillerJST is offline   Reply With Quote
Old 03-27-2012, 12:13 PM   #4728
SubieMonte
Member#: 264803
2005 WRX Wagon
Where did you buy the KYBs from?
Old 03-27-2012, 03:36 PM   #4729
BrandonDrums
Member#: 118630
2005 Wrx wagon
Red
I should have posted here long ago
05 WRX wagon
Koni Inserts
Swift Spec-R springs
3/4'' saggy butt spacers in rear
Cusco Sways F+R
Kartboy Endlinks F+R
17x7.5" w/ 48mm offset Rota Tarmac 2
225/45/17 Hankook Ventus V12 EVO tires
Whiteline Anti-Lift Kit
Camber Bolts up front running 1.5 deg. of negative camber (was running 2.0)
No rubbing, not even close. Still have about 3/4" clearance from spring perch and 1/2" from fender up front. Not sure about the back but there's plenty of room
BrandonDrums is offline   Reply With Quote
Old 03-28-2012, 01:15 AM   #4730
wrx surfwagon
Member#: 262719
02 WRX
PSM with rust accents
Just installed coilovers. Do you guys think these are too low, ie have moved into 'form>function' territory? One is seized, but if its too low I'll get it rebuilt
It felt awesome on the way to the shop to drop it off for the alignment. I didn't expect to feel that much difference in acceleration, its really night and day. Please let me know what you guys think, sorry the pic sucks. Its only like 1 1/2 finger gap in the rear, 2 in the front. I thought I would have more gap
wrx surfwagon is offline   Reply With Quote
Old 03-28-2012, 09:40 AM   #4731
BIGSKYWRX
Member#: 7958
09 GH B+
looks pretty low to me, would be more accurate if you measured (and posted) the ride heights- on level surface measure from the center of the wheel strait up to the center of the wheel arch- try to get it the measurement to the closest 1/16-1/8"
Old 03-28-2012, 01:19 PM   #4732
wrx surfwagon
Member#: 262719
02 WRX
Thanks bigsky. I get the car back today or tomorrow so i'll post #'s then
Old 03-29-2012, 11:10 AM   #4733
classicaddict
Member#: 220619
04 wrx wagon
Sti stock rear sway on an 04 wagon as a cheap temp upgrade? Go......
classicaddict is offline   Reply With Quote
Old 03-29-2012, 02:29 PM   #4734
maxim05
Member#: 97619
04 WRX Wagon
^^ depends - do you have the sti lateral links and endlinks to go with it?
maxim05 is offline   Reply With Quote
Old 03-29-2012, 08:19 PM   #4735
wrx surfwagon
Member#: 262719
02 WRX
Ok quick measurement was 13 3/8. Just under 22" from the ground if I remember right
Old 03-30-2012, 10:17 PM   #4736
BIGSKYWRX
Member#: 7958
09 GH B+
^ is that the front or rear?
the oe ride height for the wagon is 387/376 or 15.2/14.8"- I've found lowering around the 1" mark to be about right- you're almost double that, so yes I'd say you're too low
Old 03-31-2012, 02:41 AM   #4737
wrx surfwagon
Member#: 262719
02 WRX
Crap. I was hoping that it would be in range. I will have to pull the seized one and see if I can fix it.
Also, just for general information, jic flta1 coilovers use the same wrenches as skunk2 (not sure what model) just a heads up because jic doesnt sell wrenches anymore for that model. Not that most people are still running flta1's anymore
Old 03-31-2012, 10:44 AM   #4738
BIGSKYWRX
Member#: 7958
09 GH B+
^ if one of the struts is seized, probably want to take care of that regardless
Old 03-31-2012, 12:00 PM   #4739
wrx surfwagon
Member#: 262719
02 WRX
Oh no sorry. The struts not seized, just the threads to adjust height. Otherwise I wouldn't be quite so low
Old 03-31-2012, 02:33 PM   #4740
BIGSKYWRX
Member#: 7958
09 GH B+
^ ahhh- gotcha, still worth getting the ride height up up a bit imo
Old 03-31-2012, 06:22 PM   #4741
wrx surfwagon
Member#: 262719
02 WRX
I agree. Luckily the problem strut is the rear, so I can pull it and not need another alignment... I'm gonna enjoy it as is for a while first going from oe suspension with 200k to these is ridiculous
Old 03-31-2012, 09:03 PM   #4742
classicaddict
Member#: 220619
04 wrx wagon
I know the front won't fit, I thought the rear would fit.
Old 04-02-2012, 11:28 AM   #4743
paperdukie
Member#: 214796
2004 OBS
Will 05 STI take off springs (not struts) fit on my 04 wagon?
paperdukie is offline   Reply With Quote
Old 04-02-2012, 11:32 AM   #4744
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
Yes No need to change anything, The springs are a little stiff for your stock struts.
R-
labcoat is offline   Reply With Quote
Old 04-02-2012, 11:35 AM   #4745
paperdukie
Member#: 214796
2004 OBS
Thanks for the info. I know they're a little stiff for the stock struts, I'm planning on getting some D-Specs in time. How will the car react if the springs are too stiff?
Old 04-02-2012, 11:36 AM   #4746
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
it will tend to be under damped so a little bouncy. I cant say how much I have no experience with that set up.
R-
Old 04-02-2012, 02:59 PM   #4747
cerealkillerJST
Member#: 204107
2002 WRX Wagon
SRP
Amazon. They also had the bumpstops(helper springs) and boots.
Old 04-02-2012, 04:23 PM   #4748
maxim05
Member#: 97619
04 WRX Wagon
The suspension geometry is different on the rear as well. I thought about doing the rear myself when converting the front, but in the end did not see the point in spending the extra time and money sourcing the parts to do it properly. Larger diameter sways and endlinks for our cars(non-STI) are relatively cheap and easy to find used imo.
Old 04-03-2012, 03:33 PM   #4749
ChopstickHero
Member#: 191525
2003 WRX Wagon
Just installed Swift Sport wagon springs, KYB GR2 wagon struts, and GroupN top hats. Already have Whiteline front and rear swaybars with Whiteline endlinks, and Whiteline rear wagon strut bar. Things are pretty stiff and response through the corners are nice. I marked my camber bolts before taking them off, but will do an alignment in a week or two anyways to check them and to check toe.
Do you guys think rear camber bolts are necessary?
ChopstickHero is offline   Reply With Quote
Old 04-03-2012, 04:31 PM   #4750
wrx surfwagon
Member#: 262719
02 WRX
Did you at least do a diy/backyard style check for tow? You replaced major components, I wouldn't drive 2 weeks without an alignment.. But that's me
The HID FAQ Thread - Read before posting your questions dithergizzard Electrical & Lighting 669 04-26-2016 08:06 AM
What does your rim/tire combo weigh? Post your setup + weight Trevor723 Tire & Wheel 42 06-04-2010 10:40 PM
Post your setup... az ej20 fan South West Impreza Club Forum -- SWIC 20 02-10-2004 11:59 PM
Are these gauge readings correct? post yours too please! T33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-28-2003 01:35 PM
