Old 05-29-2012, 01:20 PM   #4826
gable
Member#: 173417
2007 wrx wagon
been running swift wagon springs on stock stuts for a bit now. struts are done, no surprise.
want to run koni inserts. is it necessary to change the tophats as well?
gable is offline   Reply With Quote
Old 05-29-2012, 01:20 PM   #4827
gable
Member#: 173417
2007 wrx wagon
been running swift wagon springs on stock struts for a bit now. struts are done, no surprise.
Old 05-29-2012, 01:43 PM   #4828
RicardoPT
Member#: 244797
2006 wrx wagon limit
sgm
^^^ not necessary but like the "wise" say , if you already have the struts apart and upgrading to konis and alignment to follow, might as well . I didnt when I did my inserts, my wagon had 50000 miles on it the top hats look new so,....... its all up to you but if you have the money for some group N top hats why not upgrade everything at the same time.
RicardoPT is offline   Reply With Quote
Old 05-29-2012, 02:40 PM   #4829
2JZ
Member#: 291949
Koni inserts + RCE wagon specific springs + Whiteline COM-C top hats + Group N rear top hats + kartboy rear subframe lockdown bolts + FHI 20mm rear sway bar.
18x8 rims 225/45/18. Fenders are NOT rolled. NO RUBBING.
Best wagon setup imo. Zero nose dive, incredible response, very conservative and practical drop,
and much more comfortable than initially expected (it's spring rate is much stiffer than an sti!).
2JZ is offline   Reply With Quote
Old 05-29-2012, 02:46 PM   #4830
2JZ
Member#: 291949
It's recommended to do so. The stock top hats cannot compare to the group N stiffness. Go with aftermarket in the front; Whiteline COM-C. It gives you more negative camber and most importantly caster.
I called the Myles at Race comp engineering and he told me for the stiff spring rate (280lb) I needed them.
Old 05-29-2012, 02:54 PM   #4831
gable
Member#: 173417
2007 wrx wagon
thanks for the responses. com-c are out of my budget. the group n's seem more reasonable for a DD as well. gonna look into them more.
thanks again.
Old 05-31-2012, 02:27 AM   #4832
paperdukie
Member#: 214796
2004 OBS
I'm almost done with my suspension goals finally.
RCE T2 coilovers
RCE lowering camber plates
Group N rear tophats
Whiteline 22mm rear sway bar
Whiteline front strut bar
Kartboy endlinks front and rear
TiC fender braces
04 STI BBS 17x7.5
Pirelli P Zero Rosso 225/45/17
Impressions:
Awesome. Car feels amazing especially coming from worn out OBS suspension. the coil overs are dialed in almost prefect, not too stiff but definitely stiff enough to tackle turns with a lot of confidence.
Next is the Whiteline front sway bar and then on to the brakes. My goal is to work on one part of the car at a time. Suspension, then brakes, then motor.
paperdukie is offline   Reply With Quote
Old 05-31-2012, 12:44 PM   #4833
makofoto
Member#: 25243
2006 Legacy Outback
Is this for Auto Cross or Track ... good idea to start with AX first
makofoto is offline   Reply With Quote
Old 05-31-2012, 04:54 PM   #4834
my name is joe
Member#: 171412
Funny because even with coils I still feel nosedive. I've been in so many cars with dedicated track suspension and there's still nosedive. Do explain because I'm confused.
my name is joe is offline   Reply With Quote
Old 06-22-2012, 12:30 AM   #4835
aepilot
Member#: 318713
Bumping this thread up. Just wanted to share my setup
07 Wagon
D Specs
Swift Wagon Springs
Enkei Raijins 18x8e45
Generals 225/40
Rear fenders rolled
Have struts dialed in 5 turns in all corners. Rides great, full soft was too bumpy for my taste(if that makes any sense). I'm pretty satisfied was the finished product. Kinda wish it was a little lower... but I think this setup is for good for my DD needs.
aepilot is offline   Reply With Quote
Old 06-23-2012, 11:03 AM   #4836
paperdukie
Member#: 214796
2004 OBS
I need some help, whenever I hit a semi hard bump the car pulls left. But when it's flat road there's nothing and it's perfectly straight. Any ideas?
Old 06-23-2012, 01:53 PM   #4837
BIGSKYWRX
Member#: 7958
09 GH B+
probably time for an alignment, how long since your last one?
Old 06-23-2012, 02:12 PM   #4838
paperdukie
Member#: 214796
2004 OBS
Just left the alignment shop. Front was all crazy but they got it back in spec. The rear camber was off too but they couldn't get it back into spec.
The pull after bumps is a lot less noticeable but is still just enough that of you pay attention it's there.
Old 06-23-2012, 02:14 PM   #4839
BIGSKYWRX
Member#: 7958
09 GH B+
post up the numbers please
Old 07-09-2012, 12:44 AM   #4840
desertaero
Member#: 88954
'05 Saab 92X Spec C
desert silver metallic
Have been away from the boards for a while, but I've gotten back into autocrossing a bit so I'll post my setup.
3-way KW coilovers, 18x8 BBS CK, 235/40/18 Star Specs, Rear Fenders rolled
Front: -2.7/-2.3 ( will get realigned)
Rear: -2ish both sides
Still trying to dial in setup as there's alot of adjustment to play around with!
20110701-July 01, 2011untitled-10.jpg by dekonti, on Flickr
20110701-July 01, 2011untitled-11.jpg by dekonti, on Flickr
20110701-July 01, 2011untitled-12.jpg by dekonti, on Flickr
20110701-July 01, 2011untitled-13.jpg by dekonti, on Flickr
Let me know if anyone has any questions, or if people have similar setups!
desertaero is offline   Reply With Quote
Old 07-09-2012, 10:58 AM   #4841
BIGSKYWRX
Member#: 7958
09 GH B+
what three adjustments do you get w/ the KW's?
Old 07-09-2012, 12:09 PM   #4842
littlewhitewagon
Member#: 103068
11 STI sedan
Height, rebound, compression? Not real 3 way damping adjustment I'm guessing since I have clubsports too...
littlewhitewagon is offline   Reply With Quote
Old 07-09-2012, 03:57 PM   #4843
BIGSKYWRX
Member#: 7958
09 GH B+
I was wondering, as I didn't think that KW had a 3 way damping setup- start getting into some real $ when you start looking at splitting up rebound and/or compression
Old 07-09-2012, 04:42 PM   #4844
desertaero
Member#: 88954
'05 Saab 92X Spec C
Adjustments are: low-speed compression and high-speed compression (adjustable by turning seperate knobs on bottom of external resevoir), and rebound on the top of the mcpherson strut in the middle of the camber plates. Spring rates are 600lb/in front, 500 lb/in rear.
My KW's are prototypes of these: http://www.kw-suspensions.eu/int/kw_...s&EntryId=4409
I made a gentleman's agreement to not talk/post about them until they were released
I will take pictures next time I do a tire rotation or adjust the ride height.
Old 07-09-2012, 04:59 PM   #4845
Skemcin
Member#: 167252
2002 OBS Wagon
Midnight Blue
2002 Impreza Outback Sport
Current Lift = +3.25" from factory
- Forester Struts (+1.25")
- Gorilla Strut Tower Spacers (+1")
- General Grabber 215/65/16 (+1")
Future Plans = +2" more
- Gorilla Coil Springs (+1")
- Drivetrain spacers (+1")
- Wheel Spacers (5mm)*
* I anticipate the wheel spacers will resolve the only rubbing issue I have right now. When I turn to lock (right) the driver side wheel rubs the subframe - same happens on the opposite side when I turn to lock, left.
Skemcin is offline   Reply With Quote
Old 07-09-2012, 08:25 PM   #4846
BIGSKYWRX
Member#: 7958
09 GH B+
ahh- so they do make a three way damper- very nice
Old 07-22-2012, 08:49 PM   #4847
javablackpearl
Member#: 142949
2004 WRX Wagon
jbp > mbp > obp
Originally Posted by mrxr250rider View Post
need some help guys looking to upgrade my front and rear swaybars on my wagon. im pretty sure i have a 22mm whiteline front sway bar in my garage. wondering what i should go with for the rear????
heres my setup
greddy coil overs
fenders rolled
rear strut tower bar
18x8 rota tarmac 2 48et 245/40/18
sick wagon..
i'm looking to run a similar wheel setup eventually, 18x8 Tarmac 3s, 245/40 tires (maybe 255/35.. maybe). i like a meatier look and don't mind a bit of wheel arch overhang. never liked the "hellaflush" look or whatever it's called.
how low are you dropped, and have you had any issues with rubbing even after having your fenders rolled? do you have any other pics? thanks.
javablackpearl is offline   Reply With Quote
Old 07-22-2012, 09:37 PM   #4848
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
not sure how low but for summer/winter daily driving i wouldnt wanna go any lower. never had any rubbing.
more pics and info in my build thread. check it out
http://forums.nasioc.com/forums/show....php?t=2253526
mrxr250rider is offline   Reply With Quote
Old 07-23-2012, 01:00 AM   #4849
javablackpearl
Member#: 142949
2004 WRX Wagon
jbp > mbp > obp
awesome, thanks.
Old 07-26-2012, 01:49 AM   #4850
go0sebumpz
Member#: 147521
03 WRX swaggonn
I have a question on those people running coilovers on your wagons. I curerntly am running Suspension technique coilovers on my wagon with ComC front plates to add camber. Fronts I get about -1.5 camber and my rears i'm not running any camber bolts. The rears I get a +.5 which is weird. My alignment shop says it might've been in an accident and it hasn't at all to change that drastically. I was wondering if I get camber bolts in the rear how much camber would it add?
go0sebumpz is offline   Reply With Quote
The HID FAQ Thread - Read before posting your questions dithergizzard Electrical & Lighting 673 10-11-2016 09:16 PM
What does your rim/tire combo weigh? Post your setup + weight Trevor723 Tire & Wheel 42 06-04-2010 11:40 PM
Post your setup... az ej20 fan South West Impreza Club Forum -- SWIC 20 02-11-2004 12:59 AM
Are these gauge readings correct? post yours too please! T33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-28-2003 02:35 PM
