Old 07-26-2012, 01:47 AM   #4851
nickguyver
Member#: 228730
2005 Saab 9-2X Aero
I just put suspension techniques coilovers on my wagon. Already had an epic 22mm rear swaybar set to middle. Previously I was running on Epic springs.
I put Whiteline ComC tops in front and group N in the rear. Tristan at Circuit (good service) told me I should put saggy but spacers in the rear and included them in the package.
Once the suspension settled I got it set at 13.5" front and 13.75" rear. Looks awesome but I'm seriously not liking the ride. Incredibly bouncy, feels like there is no damping at all over anything but large bumps. If you bump the fender the whole car shimmies for a few seconds. Not at all the firm but well damped ride I was expecting from ST/KWv1
Also, the ComC mounts have given me too much caster (4.5) so now the car is painfully slow to turn in. Not sure if I messed up somewhere but this is not at all what I was expecting given previous reviews.
goosebumpz - Immediately after installation I had +0.7 camber in the rear but was able to get it down to -0.8 without camber bolts.
nickguyver is offline   Reply With Quote
Old 07-26-2012, 01:49 AM   #4852
go0sebumpz
Member#: 147521
03 WRX swaggonn
I see, thanks for the update! Has your car been in a collision? Do you know why our camber is so bad in the rear?
go0sebumpz is offline   Reply With Quote
Old 07-26-2012, 09:09 AM   #4853
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
If you lowered it on the coilovers, your camber should have gone into the negative. My wagon's rear camber sits at -2 without camber plates or bolts, just natural from lowering.
Is the damping adjustable on your coilovers? (I'm not familiar with suspension techniques brand) Too bouncy means you are most likely underdamped. Do you have any idea how the damping and spring rates of your coilovers compare to stock?
flat4LGT is offline   Reply With Quote
Old 07-26-2012, 11:09 AM   #4854
nickguyver
Member#: 228730
2005 Saab 9-2X Aero
Suspension techniques are only adjustable for height. They are identical to KWv1 which is why I am surprised at how under damped they feel. Going to give them a call today.
Old 07-26-2012, 11:30 AM   #4855
bdj238
Member#: 207561
2005 WRB WRX WAGON
PPG Trans
Does anyone have any good info on how all the geometry is changed with suspension adjustment? I put the wagon on STI springs, so not much lower but have noticed I have a hard time keeping my toe in the right spot. I know that as the car is lowered each piece of the front end changes geometry. I was thinking whiteline's roll center kit might help correct for this but would also like to find some good threads with more in depth info.
bdj238 is offline   Reply With Quote
Old 07-26-2012, 11:46 AM   #4856
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
The biggest thing that changes when you lower a car is the angle of the lower control arm. The LCA essentially determines camber through the range of suspension compression. With a macpherson style strut, you want to try your best to keep the imaginary angle between the LCA and the road surface above parallel to keep your camber out of positive as best as possible. Positive camber through turns reduces your contact patch, reducing your grip.
The roll center kit isn't going to make much difference on keeping your toe in place. The RCK is designed to keep the camber curve in the right areas by keeping camber from going positive too quickly when the suspension is compressed. It extends the ball joints to push the LCA-hub mount down increasing the imaginary angle between your LCA and the road surface. It also extends the tie rod ends the same amount to ensure steering stays neutral.
I have the RCK on my wagon that's lowered ~2" and it makes a noticeable difference in reducing bump steer. I previously had an LGT that was lowered about 1.5-2" without the RCK and the bump steer was pretty wicked.
Old 07-26-2012, 01:56 PM   #4857
nickguyver
Member#: 228730
2005 Saab 9-2X Aero
Forgot one other thing, the lower mounting point is slotted, this is what I used to get my camber back to negative at the rear.
A question for you - did you use saggy butt shims when you installed your STs? What heights did you go with and how is the ride?
Originally Posted by go0sebumpz View Post
I have a question on those people running coilovers on your wagons. I curerntly am running Suspension technique coilovers on my wagon with ComC front plates to add camber. Fronts I get about -1.5 camber and my rears i'm not running any camber bolts. The rears I get a +.5 which is weird. My alignment shop says it might've been in an accident and it hasn't at all to change that drastically. I was wondering if I get camber bolts in the rear how much camber would it add?
Old 07-26-2012, 08:00 PM   #4858
go0sebumpz
Member#: 147521
03 WRX swaggonn
The ride is nice, at first I had it pretty low and I lifted it to a two finger gap. While it was low, I had positive camber still. I still have that positive camber. What do you mean the lower mounting point is slotted? I need to get that to negative. Also I did not use any saggy butt shims.
Old 07-26-2012, 08:17 PM   #4859
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Originally Posted by BIGSKYWRX View Post
ahh- so they do make a three way damper- very nice
They have for awhile actually, and you could get them for Subarus:
The 3-way clubsports are probably going to cost a little less though.
jamal is offline   Reply With Quote
Old 09-01-2012, 07:47 PM   #4860
jhayesvw
Member#: 326502
2003 WRX Wagon
My 03 wagon has
Koni yellow adjustable struts
Tein Springs (~1" drop only)
BBS RGR 17x7.5 et 48
Michelin Pilot Sport 225/45/17
Whiteline front sway
Epic rear sway
Whiteline endlinks
It doesnt rub that I can tell, rides very nice and is still high enough to take on dirt roads if needed. (i do not rally race it)
I would like to add a rear strut bar to the car to reduce the flex in the back end. Perhaps a whiteline quick release unit?
jhayesvw is offline   Reply With Quote
Old 09-02-2012, 12:04 AM   #4861
maxim05
Member#: 97619
04 WRX Wagon
As you know there are 2 mounting points for each of the struts. The rear strut's lower mounting hole is slotted on the ST/KW V1, so you can adjust the camber with just the stock bolts. I would go so far as to say, NEVER use camber(lobed) bolts in the lower mounting hole because they are already slotted. The mounting holes on the front are the same as the stock, so there is very little adjustment that can be made without the use of camber adjusting strut mounts.
Like the other member, I will also attest that the ST coilover is a bit under dampened and can be a bit bouncy. I would say that the STs are not harsh by any means but could be better. I believe my lowering settings are somewhere in the neighborhood of 13.5f and 13.1r. I initially went pretty aggressive by adding an WL ALK(Sport), camber at -2.5f, and -1.0 rear with 5.5 deg caster(I am also running STi LCAs and WL Com-Cs as well) and had Falken ZE512. With these settings, I hatted the ride and the noise! Since then, I have ditched the ALK for a more modest SPT STI control arm bushing, -1.5f/-.9r camber, 4.0 caster and replaced the tires with Falken ZE912. The ride is much nicer for the daily drive and seems to be very compliant though still a bit bumpy. I mentioned the tires, because the ZE512s were crap and induced some of the harshness as well.
maxim05 is offline   Reply With Quote
Old 09-15-2012, 06:00 PM   #4862
GetawayInBouldr
Member#: 57023
04 WRX Wagon
I've been running TEIN H-Tech springs on stock struts with Noltec Camber/Castor plates for about 6 years, around 60K miles. It worked really well for me... fairly comfortable ride, no rubbing on 225/40/18 tires, seemed to perform well at auto-x, etc. But I looked under the hood last week and found out the urethane bushings are deteriorating, fast! (pic below)
I think the stock struts are toast, time for a revamp. I'm thinking about going with Koni inserts all around with Whiteline Com-C's up front, stock top hats in the rear.
Anyone run this setup and like it? This is for a spirited daily driver, not auto-x'ing anymore. Will the spring rates and drop be OK with the Koni's? I would also consider Tokico or Gabriel shocks, I just don't have any experience with them.
GetawayInBouldr is offline   Reply With Quote
Old 09-16-2012, 04:34 PM   #4863
discodan
Member#: 227431
2014 Crosstrek
Desert Khaki
I'm subscribing for info
discodan is online now   Reply With Quote
Old 09-25-2012, 01:22 PM   #4864
rexwagon02
Member#: 226312
2007 WRX Wagon
OBP swirled to perfection
Default need moar softer
Hello Nasioc,
I purchased an 07 wagon with a crap ton of mods and spare parts. Long story short, it has H&R Coilovers that are way, way to stiff for my bad back. It came with a set of koni inserts and I picked up a used set of sacrificial wagon struts for the conversion. I'm on rockauto looking at the KYB strut mounts f/r. Group Ns are just too pricey.
Questions: Should I get the strut bellows as well?
Does anyone have recommendations for a more compliant suspension for a daily driver?
Setup:
07 wagon
Whiteline sways, endlinks, mounts
whiteline ALK
Prodrive GC-014i 17x7.5
225/45 r 17 PS3s
Rolled rear fenders
needs:
f/r strut tower braces
wagon coilovers will be available shortly
thanks!
rexwagon02 is offline   Reply With Quote
Old 09-25-2012, 01:59 PM   #4865
mmiller2002
Member#: 159286
2002 WRX Wagon,Com-C
RCE wgn sprngs/Konis/H6
Originally Posted by rexwagon02 View Post
Hello Nasioc,
You should be able to find stock takeoff springs pretty cheap. And, maybe some GR-2 struts to go with.
mmiller2002 is offline   Reply With Quote
Old 09-25-2012, 02:03 PM   #4866
wrx surfwagon
Member#: 262719
02 WRX
PSM with rust accents
He already has koni inserts.
Wagon pinks should be good unless your trying to go low. I think you might be overdampened with stock springs on koni's, but I could be wrong
wrx surfwagon is offline   Reply With Quote
Old 09-25-2012, 02:09 PM   #4867
rexwagon02
Member#: 226312
2007 WRX Wagon
i forgot to mention...i also have a set of Eibach springs, not sure which model.
Old 09-25-2012, 05:05 PM   #4868
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
Eibach springs are low and to soft.
If you want stock ish ride hight and slightly stiffer then stock then look for Sti take offs or Pinks.
If you want a little more firm and performance look for RCE black's
If you have lower correct stiffness the RCE Yellow.
If you want more then get Ground control adapters and any spring you like, pick you ride hight and stiffness.
I am guessing you are under a budget as you commented that group N top pats are to expensive so just get some Sti take offs and I would recommend ether whiteline or group N top hats. yes they are worth it.
I would get the top hats and skip the strut tower braces for now.
R-
labcoat is offline   Reply With Quote
Old 09-25-2012, 06:20 PM   #4869
Keif
Member#: 107302
Yep, check the classifieds for STi springs. There are plenty. Got mine for $70 shipped.
Keif is offline   Reply With Quote
Old 09-25-2012, 07:47 PM   #4870
aepilot
Member#: 318713
I have swifts for the wagon with d-specs. Rides great, recommend them if you are looking for stock-like ride.
here's the setup
aepilot is offline   Reply With Quote
Old 09-26-2012, 09:59 PM   #4871
Beard_Of_Moses
Member#: 316926
2004 wrx wagon
Hey, a bit of a suspension noob here with a 2004 wrx wagon. My current setup is what I bought the car with, stock struts and some brutal lowering springs. Long story short my stock struts are toast and the springs are way too low but still somehow soft enough to bottom out everywhere, I can only fit one finger between the tire and the fender and I scrape everywhere.
My priorities are having a higher car (slightly lower that stock preferably) but still be stiff for spirited driving/occasional track use. Coilovers are out due to road conditions here. What would the ideal setup be? OEM or aftermarket struts? what springs? Budget is $1100ish.
(also am planning on getting things like swaybars and strut tower bars in the future as money becomes available if that needs to be taken into consideration.)
Thanks for any help.
Edit:sorry if I'm unclear but I'm asking for both springs AND struts.
Last edited by Beard_Of_Moses; 09-26-2012 at 10:03 PM. Reason: grammar and clarity
Beard_Of_Moses is offline   Reply With Quote
Old 09-26-2012, 10:24 PM   #4872
aepilot
Member#: 318713
Beard- I would suggest going with swift wagon springs. That's what I have on my mine and they ride like stock, if not better because my struts were shot. I replaced my stock struts with d-specs and they are awesome. You can adjust them for track days and your ride back home.
This setup should put under your budget. Best of luck.
Old 09-27-2012, 09:05 AM   #4873
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
I recommend ether d spec or Koni inserts and any of the below:
Sti take offs + saggy but spacer
STI Wagon Pinks
RCE blacks + saggy but spacer
RCE yellow+ saggy but spacer ( if you want to be as lower then a stock sti)
keep in mind if you go with d-specs you will need more negative camber adjustment.
I also suggest Group N top hats or white line com C front top hats.
if you want more info SEARCH NOOB... just kidding look for a series of post started by big sky wrx.
R-
Old 09-27-2012, 02:07 PM   #4874
Beard_Of_Moses
Member#: 316926
2004 wrx wagon
^^ Thanks and I actually did search, that's how I found this thread, I dug through it a bit and just wanted to clarify everything before I went for it.
I was under the impression that the struts would fit 2004 tophats as long as you had the scooby spacers? Or are the new ones required? Also for camber adjustment do I just need to get rear camber bolts, or does it require more than that?
sorry for the questions, I just want clarification so we don't end up with a new thread down the road along the lines of "OH GOD EVERYTHING HAS GONE HORRIBLY WRONG"
Thanks
Old 10-13-2012, 02:44 PM   #4875
rexwagon02
Member#: 226312
2007 WRX Wagon
Default got moar softer
Update on my suspension:
My old suspension was H&R coils, model 29339-2 a model only available in Europe (i was recently stationed in Germany where I bought the car). If the manufacturer didn't state otherwise, I'd swear they were made of solid concrete. There was no compliance making the ride too harsh. However, there was no body roll and these were nothing short of amazing on the Nurburgring. Ride was OK on perfect (ish) European roads, but unacceptable on North American roads (I have a bad back, so this is more pronounced).
I had the Koni inserts installed with the Eibach springs and KYB tophats. First impressions: bumps, joints, and other road imperfections are greatly reduced. The interior isn't shaking itself apart on every drive.
Handling prowess is reduced. There is more body roll, but this was a known tradeoff. Still better than stock, and is fine for a DD.
Ride height is a little higher. The coils were height adjustable, and the previous height was low, but not slammed, about one finger all around. Now the height is two in front, one in back, and other than saggy butt spacers, I'm not sure I can do anything about that.
Overall, I'm glad I did the change. Coils will be in the FS section soon. They only have about 3500 miles on them (long story).
The HID FAQ Thread - Read before posting your questions dithergizzard Electrical & Lighting 669 04-26-2016 08:06 AM
What does your rim/tire combo weigh? Post your setup + weight Trevor723 Tire & Wheel 42 06-04-2010 10:40 PM
Post your setup... az ej20 fan South West Impreza Club Forum -- SWIC 20 02-10-2004 11:59 PM
Are these gauge readings correct? post yours too please! T33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-28-2003 01:35 PM
