Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 11-06-2012, 10:02 AM   #4901
Dentt42
Member#: 180570
2002 WRX Wagon
WR Blue
Originally Posted by BIGSKYWRX View Post
-1.2 isn't too shabby if you have the caster dialed up
OK, cool. Thanks for taking a look. I've been through a million threads and it's all a blur now, do the GC arms add any caster over the stock GG wagon arms?
Dentt42 is offline   Reply With Quote
Old 11-06-2012, 10:56 AM   #4902
haberkorn
Member#: 97732
2004 STi
65 Nova [email protected]
I'm about to install at set of dspecs on a stock 02 wagon.
Are the com-c tophats enough to fix the caster issue the sedan struts create or do I need to just stick to stock tophats and run camber bolts in the lower holes on the front?
haberkorn is offline   Reply With Quote
Old 11-06-2012, 04:24 PM   #4903
BIGSKYWRX
Member#: 7958
09 GH B+
no they are identical to the steel arms (except for their aluminum construction )
it's not a caster issue w/ sedan struts, it's camber and yes the com-c's will overcome the neg camber lost w/ sedan struts (as a bonus you'll have more positive caster and a firmer top)
Old 11-06-2012, 05:34 PM   #4904
haberkorn
Member#: 97732
2004 STi
Thanks sir.
Do the com-c's need to be orientated a certain way upon installation to ensure that the camber is put back in the set up?
Old 11-06-2012, 06:42 PM   #4905
BIGSKYWRX
Member#: 7958
09 GH B+
there are two ways to install them- one w/ maximum caster (slight camber gain), the other w/ maximum camber (slight caster gain)
w/ sedan struts I'd probably go w/ the max camber orientation
Old 11-06-2012, 06:50 PM   #4906
Dentt42
Member#: 180570
2002 WRX Wagon
WR Blue
Here's a visual aid to go along with what BIGSKY is describing:
(I just like posting pictures-- must be all that time in OT)
Old 11-06-2012, 07:41 PM   #4907
haberkorn
Member#: 97732
2004 STi
Ok nice to know going into an install, thanks for the info.
I'm a little confused on how you change the top hat if it's all assembled from the factory but I'll figure it out.
Thanks for the info!
Old 11-06-2012, 07:57 PM   #4908
BIGSKYWRX
Member#: 7958
09 GH B+
the bolts are equidistant, so the position can change- you can also swap them left and right- not sure if that is necessary w/ the com-c's- you can do that w/ camber plates
if you put them in the wrong position you can go the other way (the bad way) w/ camber and caster
the stock tops the hole is dead center so the orientation doesn't matter, it does w/ these
Old 11-06-2012, 09:56 PM   #4909
Dentt42
Member#: 180570
2002 WRX Wagon
WR Blue
Even after you torque the big nut at the top of the strut to hold the whole spring/strut/tophat assembly together, the tophat spins freely on its bearing. Just rotate it to the position you want, put the studs through the three holes in the tower, and tighten the nuts.
Old 11-06-2012, 11:55 PM   #4910
haberkorn
Member#: 97732
2004 STi
So the hole in the center of the com-c's that the strut passes through isn't centered I'm guessing.
The arrows must be pointing to the front of the vehicle?
Old 11-07-2012, 12:31 AM   #4911
Dentt42
Member#: 180570
2002 WRX Wagon
WR Blue
Yes on both.
Old 11-07-2012, 01:10 AM   #4912
haberkorn
Member#: 97732
2004 STi
Got it so if I put the strut shaft closest to the engine not the fender I'll fix the camber issue.
Thanks again for the help I appreciate it.
Old 11-07-2012, 11:01 PM   #4913
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
Here's my '02 Bugeye WRX Wagon's suspension setup.
Koni Sport (Yellows) Strut Inserts in OEM Housing
RCE Yellow Springs
GTWorx Front Camber Plates
OEM Group N Rear Strut Tops
D-rex Front Strut Extenders
Saggy-butt Spacers / Scooby 921 Adapters
JDM STI V6 Aluminum LCAs*
JDM STI V6 Pink Lateral Links and Trailing Arms*
Whiteline Roll Center Adjust Kit*
Whiteline ALK Sport*
Whiteline Steering Rack Bushings*
Whiteline Rear Diff Bushings*
Whiteline Subframe Lockout Bolts*
Hotchkiss Competition Mounts, Sways & Endlinks*
What else should I be looking for? Any ideas or feedback on the above parts? Can't wait to put some life back into this 140K suspension, and capitalize on my current setup (10K on the Koni/RCE).
*asterisk means the part is sitting in my closet waiting for warmer days
LatentWagen is offline   Reply With Quote
Old 11-09-2012, 04:02 PM   #4914
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
03 dee badged impreza wagon
Suspension/Brakes
Tokico Spec D adjustable dampers
Whiteline sway bars f & r
stock springs
stock height
GC Aluminum control arms
Tein camber plates front
Group N tophats rear
Whiteline anti lift kit
Whiteline Lateral Links rear, stock Sti front
Megan Trailing Arms w/poly rear bushing
Perrin Rear Diff & Subframe Bushings
Front & rear tower braces
Camber bolts front
jdm gc Sti calipers
mhoerath is offline   Reply With Quote
Old 11-13-2012, 10:14 PM   #4915
Texas Shooter
Member#: 174881
2002 Stage 2 Wagon
Black 'n Blue
Default Now that my wagon and I are older...
Short version: I want more positive camber in the front.
Long Version: I am on MadDad Road Hugga springs (very close to STi springs I'm told) with Wagon GR2's. Ride height is great, spring rates are fine. I have had a few different alignments and gone through a few sets of tires while loving the handling over the past 4 years. Now my daily driver/family hauler needs less cornering prowess and more tire longevity.
As it sits with the front camber bolts at max positive I'm at -.9/-1.0 deg. On a side note, I can get almost -2 deg with the stock bolts. -.9 is an ok daily driver camber, except that I spend 90%+ of my time on the highway. Even with regular rotations (and wheel flip/ inside-out changes to put the wear side out) the sides show steel while the center is barely showing the wear bars. Toe is zero all around.
I was seriously considering some camber plates but since it is now just a daily driver I can't justify the cost. I still read that there is not a great solution to not enough negative camber when using Sedan struts so I was considering that road but still seems expensive parts to throw at a head-scratcher.
I know nothing is bent, two trustworthy alignment shops have given me the same numbers (with me under the car watching the adjustments and the computer) and I still feel like I'm missing something.
Any guru's want to chime in? If this seems reasonable, any idea of how much positive camber I can get with aftermarket bolts in the bottom holes? Thanks for any help you can offer.
Texas Shooter is offline   Reply With Quote
Old 11-13-2012, 10:30 PM   #4916
BIGSKYWRX
Member#: 7958
09 GH B+
w/ bolts in the lower holes you should get a minimum of a degree of adjustment- I wouldn't go past 0 to the positive (I'd still go a little neg- a tenth or two minimum)
a lot of guys would trade to have your "problem"
Old 11-14-2012, 06:15 AM   #4917
Texas Shooter
Member#: 174881
2002 Stage 2 Wagon
Black 'n Blue
Thank you BigSky... that is what I was hoping to hear. I was very happy when I first installed this setup and saw how much (or little?) camber I could get out of it. Once I got the rear camber where I like, it would oversteer just a little bit then with some throttle modulation would progressively break loose and just 4-wheel drift around most flat corners. Great fun in the turns but got expensive with my daily drive.
Old 11-14-2012, 07:53 AM   #4918
rmaxwellusn
Member#: 310864
2003 WRX wagon
Red
My setup is as follows:
Feal 441 Coilovers
Unibomber's sexy rear end
Kartboy Endlinks
Whiteline 22MM F 24 MMR Swaybars
Camber: 2.5F 1.0R
Running 225/45/R17s on 17X7.5 P1Rs.
rmaxwellusn is offline   Reply With Quote
Old 11-17-2012, 07:49 AM   #4919
mt1101
Member#: 291990
2003 BUGEYE WAGON
I never planned on doing too much to the stock 205 motor and really looking into upgrading my suspension. My budget is $500. what would you recommend? I don't plan to autox at all just spirited driving. current suspension setup so far is just dspecs/tanabe gf210. Thanks.
mt1101 is offline   Reply With Quote
Old 11-17-2012, 10:00 AM   #4920
rmaxwellusn
Member#: 310864
2003 WRX wagon
Red
Swaybars/endlinks would make a world of difference. They're not that expensive either.
Old 11-17-2012, 01:22 PM   #4921
Dentt42
Member#: 180570
2002 WRX Wagon
WR Blue
Agreed. The F&R swaybars and endlinks were actually my first suspension upgrade, but still remain my favorite. That, and any bushing you have the budget and time to upgrade is 100% worth it. Each one I swapped out was perceptible.
Old 11-17-2012, 04:23 PM   #4922
mt1101
Member#: 291990
2003 BUGEYE WAGON
Awesome. Thanks for the input.
Old 11-19-2012, 05:32 PM   #4923
sleepyfu
Member#: 124219
2004 W(agon)RX
Maybe try higher tire pressure?
......Even with regular rotations (and wheel flip/ inside-out changes to put the wear side out) the sides show steel while the center is barely showing the wear bars. Toe is zero all around.
sleepyfu is offline   Reply With Quote
Old 12-10-2012, 04:47 PM   #4924
Texas Shooter
Member#: 174881
2002 Stage 2 Wagon
Black 'n Blue
Well, the lowest tire pressure I have run is the Mfg Recommended (33/32 I think?) but I usually run 36/34 f/r as it is more smooth on the highway. On that note, if I can get the camber .5-.75deg more positive and drive fast enough to get the greatest benefit of both the centripetal forces and the thermal expansion of the air in the tire I estimate only the outside 1 inch and inside 2 inches (measured from the exact center-line) of the tire will be touching the road anyway, solving almost all of my wear problems.
Old 01-24-2013, 11:46 AM   #4925
ringe
Member#: 49998
2007 WRX CT Stg 2
Sorry to be the noob who asks this question, but literally hours of searching and I still don't have a definitive answer; from what I can tell, STI Sedan and STI Wagon spring rates are the same, it's just the rear free-height that's different, correct? (I'm talking 06 STI takeoffs, not pinks here).
Thanks, and flame-suit donned for the "searchnoob" replies...
For context, I'm looking at a set of 06 takeoffs, GR2s, and saggy-butt shims just in case. 1/4". While I run that setup for a while I'll save up some bones for a set of Koni or FEAL inserts to retrofit my stock struts down the road.
ringe is offline   Reply With Quote
The HID FAQ Thread - Read before posting your questions dithergizzard Electrical & Lighting 673 10-11-2016 09:16 PM
What does your rim/tire combo weigh? Post your setup + weight Trevor723 Tire & Wheel 42 06-04-2010 11:40 PM
Post your setup... az ej20 fan South West Impreza Club Forum -- SWIC 20 02-11-2004 12:59 AM
Are these gauge readings correct? post yours too please! T33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-28-2003 02:35 PM
