Welcome to the North American Subaru Impreza Owners Club Tuesday September 2, 2014
Old 02-09-2013, 01:23 PM   #4951
Daddy_Digital
Member#: 274205
2002 WRX Sport Wagon
World Rally Blue
Originally Posted by labcoat View Post
You don't need group N you do need 04 +
Okay thanks. This will surely save me some money.
Originally Posted by BIGSKYWRX View Post
with an 02 I would want to freshen up the front mounts as well- they are a wear item and this would be the optimum time to replace them
I want to get fresh mounts, just dont want to pay Group N money.
Daddy_Digital is offline   Reply With Quote
Old 02-09-2013, 03:39 PM   #4952
BIGSKYWRX
Member#: 7958
09 GH B+
I hear you
Old 02-09-2013, 05:42 PM   #4953
Daddy_Digital
Member#: 274205
World Rally Blue
Someone on a local forum suggested going to Auto Zone and buying the KYB rear mounts. 69 bucks for a pair. Yes please!
Old 02-09-2013, 07:35 PM   #4954
Bikelok
Member#: 254851
2002 Wrx wagon 5mt
Originally Posted by Daddy_Digital View Post
Okay thanks. This will surely save me some money. I want to get fresh mounts, just dont want to pay Group N money.
Do yourself a favor and get stock rear mounts. Group N is not really needed in the back, unless you are at the track every other weekend. For a street car they are fine.
DO get Group N fronts! You will not regret it. OEM fronts (even new) are terrible for any kind of performance. They are fine for getting groceries but that's about it. Stock fronts are very wishy washy.
Bikelok is online now   Reply With Quote
Old 02-09-2013, 09:54 PM   #4955
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
No really do your self a favor and get whiteline com c's for the front I would say group n are worth doing and for anything stiffer then sti springs. Hell they are worth doing if you are up grading your suspention.
labcoat is offline   Reply With Quote
Old 02-09-2013, 10:12 PM   #4956
Bikelok
Member#: 254851
2002 Wrx wagon 5mt
Plus one for this, if you want or need additional camber/caster.
Who doesn't, right.
I am using the Whiteline and I love them.
Old 02-09-2013, 11:15 PM   #4957
Daddy_Digital
Member#: 274205
World Rally Blue
So do myself a favor and pay more? Im starting to think these parts companies pay people to talk bad about affordable parts. Whatever. Anyhow, I got stock parts anyways. Just picked up OEM 04 impreza top hats for 20 bucks locally.
Ill be unsubscribing from this thread now.
Old 02-10-2013, 04:10 AM   #4958
Joebrauk
Member#: 230546
2004 WRX Sport Wagon
Obviously an upgraded part is going to cost more. If you want to save money, that's your choice. They were just pointing out that the oem top hats are very soft; and there is good reason to replace them if you are interested in performance. I'm sure your $20 stock top hats will serve their purpose, they just wont provide any improvement. The other users are just more concerned with enhancing their handling than you are.
Joebrauk is offline   Reply With Quote
Old 02-10-2013, 08:44 AM   #4959
yosemitemtb
Member#: 23437
'02 WRX Wagon
WR Blue Pearl
Seems you missed the whole point of this thread, to toss around ideas and thoughts on different suspension setups for wagons. Your opinion is that stock parts are good enough, great! Some of us are willing to pay a few more bucks to have more performance or adjustment available. No need to unsubscribe.
yosemitemtb is offline   Reply With Quote
Old 02-17-2013, 11:40 AM   #4960
ringe
Member#: 49998
2007 WRX CT Stg 2
Purchased and waiting to install:
After some thought, wanted to try the Excel G wagon struts while I save up a few more bones for FEAL or Joni inserts;
06 STI takeoffs;
Whiteline Com C front mounts;
1/4" saggy butt shims;
Antilift kit;
Camber bolts for the front and rear.
Taking suggestions on fast-road alignment settings; the com C mounts and alk will be used to help max out the static caster.
Already have 22mm whiteline bars and links on both ends, the front set to soft and the rear to full-stiff.
ringe is offline   Reply With Quote
Old 02-17-2013, 03:52 PM   #4961
BIGSKYWRX
Member#: 7958
09 GH B+
try to get the front camber in the -1.5-ish range, set toe at 0 f/r- don't worry about rear camber unless it's excessive or the cross is bad
Old 02-17-2013, 07:04 PM   #4962
ringe
Member#: 49998
2007 WRX CT Stg 2
Excellent, thank you.
Old 02-22-2013, 01:51 AM   #4963
runboyrun
Member#: 287901
2003 WRX Wagon
Is it possible to run sedan adjustable lateral links without swapping axles?
runboyrun is offline   Reply With Quote
Old 02-22-2013, 03:34 AM   #4964
yosemitemtb
Member#: 23437
'02 WRX Wagon
WR Blue Pearl
Should be, I'm running Hotchkis lateral links on my '02 wagon for about the last 8 years.
Old 02-22-2013, 08:19 AM   #4965
Krang
Member#: 134272
Chapter/Region: HIIC
2002 WRX Wagon - WRB
ej207 v8 vf37
2002 WRX Wagon
Suspension:
Feal 441 Coilovers
WL 24mm Front Sway set to full stiff
WL 24mm Rear Sway set to full soft
KB Endlinks F+R
Sti Aluminum Front Control Arms
WL Roll Center kit
TruHart Adjustable Lat Links + Trailing Arms
Every TIC Bushing Available
17x8 BBS RG-R w/ Hankook RS3 225/40/17
Alignment specs are yet to be determined, getting it all wrapped up this next week hopefully results is a nice AutoX setup =)
Krang is offline   Reply With Quote
Old 02-22-2013, 11:00 AM   #4966
BIGSKYWRX
Member#: 7958
09 GH B+
if they can adjust close to wagon length you're good to go- if they won't adjust below the length of sedan links they won't work
Old 03-03-2013, 07:26 PM   #4967
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
perrin anti lift kit
kyb excel g struts
epic engineering springs
kyb top hats
whiteline front endlinks
perrin rear endlinks
whiteline 22mm front sway bar
epic engineering 22mm rear swaybar
Rear strut bar
whiteline subframe locking bolts
whiteline diff bushings
mrxr250rider is offline   Reply With Quote
Old 03-05-2013, 01:55 PM   #4968
kevin85193
Member#: 145900
2003 16gxt wagon
nm!!!!!
kevin85193 is online now   Reply With Quote
Old 03-06-2013, 03:41 PM   #4969
runboyrun
Member#: 287901
2003 WRX Wagon
Does anyone know how adjustable Eibach/Spc Lateral Links are for our wagons?
Old 03-06-2013, 04:05 PM   #4970
Kessel Run
Member#: 253044
2005 2.5 RS Wagon
SRR
So this is the general consensus? Because saving $300+ would be nice.
Kessel Run is offline   Reply With Quote
Old 03-06-2013, 04:59 PM   #4971
Bikelok
Member#: 254851
2002 Wrx wagon 5mt
I have set on my wagon.
I like them.
They are not pretty, but they are very functional and easy to adjust on the car. They are made well and should hold up well (2 years and no problem). The bushings are rubber and seem very firm (fingernail test). Are they as pretty or nice as the Whiteline set or the MSI set? No, but you do get a set that is stronger than OEM and far better than the Godspeed/eBay junk.
I have seen a complete set of four go for less than $300.
They are stamped SPC, but the box says Eibach.
Old 03-06-2013, 06:13 PM   #4972
runboyrun
Member#: 287901
2003 WRX Wagon
I like them.
Do you know how much adjustabilty you've gotten out of them. They say theyre +-1.5degrees toe but is that for the sedan or wagon?
Old 03-06-2013, 08:16 PM   #4973
Bikelok
Member#: 254851
2002 Wrx wagon 5mt
It's been a while since I've messed with them, but from what I remember when I first put them on with sedan struts I was around -2.2 camber. I dialed them back to a stockish -1.5 camber. I never bothered to see how far I could go with them. I would imagine with wagon struts you could do better than that.
Old 03-07-2013, 05:27 PM   #4974
WRXMunkey
Member#: 286400
2006 WRX Wagon
Looking for a bit of advice on my suspension.
06' wagon with Stock struts and STI pink springs
24mm Front sway
22'mm adj whiteline rear
Front and rear strut bars.
The car is to jittery and just dosn't feel right. Car is a spirited daily driver...
Thinking about pulling the 24mm front and going back to stock and want to change the shocks and maybe the springs at the same time.
Thoughts or suggestions on struts/spring combo.
WRXMunkey is offline   Reply With Quote
Old 03-07-2013, 05:32 PM   #4975
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
I have 22mm sway bars front and rear. Kyb excel g struts and epic engineering springs. It feels great
The HID FAQ Thread - Read before posting your questions dithergizzard Electrical & Lighting 600 03-10-2014 09:27 AM
What does your rim/tire combo weigh? Post your setup + weight Trevor723 Tire & Wheel 42 06-04-2010 10:40 PM
Post your setup... az ej20 fan South West Impreza Club Forum -- SWIC 20 02-10-2004 11:59 PM
Are these gauge readings correct? post yours too please! T33 Factory 2.0L Turbo Powertrain 7 04-28-2003 01:35 PM
