Old 04-04-2013, 01:28 PM   #5026
kantthinkofasn77
Member#: 220808
2005 WRX Wagon
Well i really wanna help you and if they cant figure it out then we need to lol you could email a video to me or post one on youtube and post the link on here to it. I have the same wagon you do.
kantthinkofasn77 is offline   Reply With Quote
Old 04-04-2013, 01:36 PM   #5027
Zwilks14
Member#: 336694
2005 Wrx wagon
Gray
Ok send me ur email
Zwilks14 is offline   Reply With Quote
Old 04-04-2013, 02:35 PM   #5028
Zwilks14
Member#: 336694
2005 Wrx wagon
Gray
I gut a video how do i put it on here?
Old 04-04-2013, 02:37 PM   #5029
Zwilks14
Member#: 336694
2005 Wrx wagon
Gray
Old 04-04-2013, 03:31 PM   #5030
kantthinkofasn77
Member#: 220808
2005 WRX Wagon
Originally Posted by Zwilks14 View Post
That helps alot. Sounds like clunking maybe a CV joint. Have you checked your diff oil level or have had it changed out? Also check your trans level just to be safe or change it out if you havent. Get under ur wagon and pull push and move side to side on the rear axle shafts to see if there is any excessive play there shouldnt be any movement or maybe a really small amount. I noticed too you said it happens when ur turning right only but in the video ur going left haha
Old 04-04-2013, 03:59 PM   #5031
kantthinkofasn77
Member#: 220808
2005 WRX Wagon
Yarp.
Old 04-04-2013, 07:15 PM   #5032
Zwilks14
Member#: 336694
2005 Wrx wagon
Gray
Yea i meant left lol
Old 04-04-2013, 07:47 PM   #5033
Zwilks14
Member#: 336694
2005 Wrx wagon
Gray
The thing i dont get is that it never happened untill i put the co's on.
Old 04-04-2013, 08:27 PM   #5034
kantthinkofasn77
Member#: 220808
2005 WRX Wagon
Lowering the vehicle may have changed intended geometric angles on the drive line and now there is more stress when cornering because the old springs and struts/shocks would absorb the body roll more
Old 04-05-2013, 01:00 AM   #5035
Zwilks14
Member#: 336694
2005 Wrx wagon
Gray
Do you think it could be the rear diff going out? I hope not man...
Old 04-05-2013, 04:57 AM   #5036
kantthinkofasn77
Member#: 220808
2005 WRX Wagon
Check ur fluid levels.. I doubt its the diff. Its prob ur axle shafts taking the heat of the new coil overs.. They could have been worn already and now that there is more stress on them cause of the stiffer suspension you are hearing that. But thats just my guess. Maybe the guys who put them on didnt tighten something down all the way. Its possible ur axle nuts may be alil loose too. That happened to me awhile ago when i accidentally clipped a curb in my old 2.5i sedan and i would get something similar to the noise you have when cornering. Thats all i got though man. Lemme know what happens. Sorry to everyone else for the thread jack... Jus trying to help
Old 04-05-2013, 11:55 AM   #5037
Zwilks14
Member#: 336694
2005 Wrx wagon
Gray
Thanks again brotha, i appreciate all the help and guidance ( im new to coils , i had 04 sti takeoffs on before ).
Old 04-07-2013, 11:08 PM   #5038
japstaboi
Member#: 350479
would you recommend using stock struts with swift springs or what strut would make the car look nicer? i would like to spend around $300 around there
japstaboi is offline   Reply With Quote
Old 04-09-2013, 11:45 AM   #5039
Zwilks14
Member#: 336694
2005 Wrx wagon
Gray
Figured it out guys!!! I have a rear diff cover, and my exhaust had shifted, and was rubbing the cover when i would take hard turns. Im puuuuumped I didn't have to drop a Ton of dough to fix it
Old 04-09-2013, 02:26 PM   #5040
kantthinkofasn77
Member#: 220808
2005 WRX Wagon
Excellent man.
Old 04-18-2013, 10:42 PM   #5041
wrXmon
Member#: 115454
My '02 WRX Wagon
is being freshened up.
Originally Posted by wrXmon View Post
My modest start:
(2004 WRX Wagon)
- OE 16" wheels
- 225/50/16 BFG KDWS tires
- Perrin rear swaybar
- Perrin endlinks
- StopTech front rotors
- Hawk HPS front pads
- OE rear rotors
- OE rear pads
- GT Spec rear Strut tower bar.
Update (2002 WRX Wagon)
- Enkei RPF-1 17x8 wheels
- 225/45/ 17 Goodyear Eagle GT tires
- Crucial Racing springs
- Group-n strut tops
- Cobb front swaybar
- Cobb rear swaybar
- Perrin stout mounts
- Kartboy Botox bolts
- Kartboy wagon front endlinks
- Kartboy rear endlinks
- Kartboy outrigger bushings (comfort)
- GT Spec ALK
- GT Spec subframe brace
- GT Spec t-brace
- GT Spec rear strut tower brace
- Cusco front strut tower brace
- Creative Werks cowl stays
- JDM GC8 aluminum control arms
- SuperPro steering rack bushings
- Eibach camber bolts
- Rolled rear fenders
- Stoptech slotted front rotors
- Stoptech pads
- Brembo slotted rear rotors
- Goodridge stainless steel lines
- ATE brake fluid
- Grimmspeed master cylinder brace
- H6 rear brake bracket
- Kartboy shifter bushings
- Group-n transmission mount
- SuperPro crossmember bushings
- Turn In Concepts rear diff mount bushings
wrXmon is offline   Reply With Quote
Old 04-22-2013, 03:49 PM   #5042
kirshnerd
Member#: 310645
02 obs
Fortune auto 500 coilovers
Fortune auto camber plates front and rear
Cobb 22-25mm adjustable rear sway
GroupA rear endlinks
GroupA front endlinks
XXR 522 17x9 +42
Nankang NS-20 225/44r17
Rear fenders rolled nearly flat
No front fender work
No pulling
Fronts rub a small bit, can still add camber and roll fenders to reduce rubbing.
kirshnerd is offline   Reply With Quote
Old 04-22-2013, 11:12 PM   #5043
Leftear
Member#: 285928
07 WRX Wagon
I love your car so much.
Leftear is offline   Reply With Quote
Old 04-23-2013, 09:27 AM   #5044
kirshnerd
Member#: 310645
I do too, funny thing. Lol.
Thanks
Old 04-23-2013, 04:28 PM   #5045
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Coilover question.
How would a set of coilovers with 8k fronts and 5k rears (or similar) behave on an 02-07 wagon?
Psychoreo is offline   Reply With Quote
Old 04-23-2013, 07:37 PM   #5046
kirshnerd
Member#: 310645
Originally Posted by Psychoreo View Post
Coilover question.
My guess is relatively unbalanced. You normally see a 2k difference front rear, if they're not even.
Old 04-23-2013, 08:15 PM   #5047
Zwilks14
Member#: 336694
2005 Wrx wagon
Gray
I actually have 8k front and rears on my 05. Josh @ import image racing explained to me when i ordered my bc's that with this set up, it compensates for the saggy butt wagons experience, and also makes the car feel like it is rwd in turns ie; the rear end feels like it wants to slide out, instead of feeling like its fwd. im quite happy with this set up so far. I hope that makes sense
Old 04-24-2013, 10:51 AM   #5048
kirshnerd
Member#: 310645
Haha
I'm also running 8k/8k on my fortune auto 500's... Noted above.
I was just explaining why you see mostly 2k differences, more often in sedans than wagons.
Saggy butt wouldn't really be effected too much by spring rates, but as theres more weight over the rear on a wagon it does sag a bit more. Thankfully with coils you can compensate with the ride height adjustment, but the balanced sprig rates front and rear helps eliminate the actual sag.
Old 04-24-2013, 04:17 PM   #5049
Zwilks14
Member#: 336694
2005 Wrx wagon
Gray
Yep, im glad i went that route indtead of 7/5 everyone gets on gd's
Old 04-24-2013, 09:11 PM   #5050
kirshnerd
Member#: 310645
Very same here.
I just saw a Saabaru running 10k/5k....
The HID FAQ Thread - Read before posting your questions dithergizzard Electrical & Lighting 671 09-15-2016 09:50 AM
What does your rim/tire combo weigh? Post your setup + weight Trevor723 Tire & Wheel 42 06-04-2010 10:40 PM
Post your setup... az ej20 fan South West Impreza Club Forum -- SWIC 20 02-10-2004 11:59 PM
Are these gauge readings correct? post yours too please! T33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-28-2003 01:35 PM
