Old 07-30-2013, 02:17 PM   #5126
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Originally Posted by wcu25rs View Post
Quick question....I ended up buying this setup, but my question is if I should get group n strut tops. Keep in mind that my wagon is my DD and will probably never see a track of any type. At 145 bucks from TiC they aren't that expensive, but I don't want to spend it if it isn't worthwhile. Opinions?
Group-N fronts are very much worth it.
Save your money in the rear and stick with stock.
Bikelok is online now   Reply With Quote
Old 07-30-2013, 02:44 PM   #5127
mmiller2002
Member#: 159286
2002 WRX Wagon,Com-C
RCE wgn sprngs/Konis/H6
Not necessary unless you (and your passengers) want to feel more road.
OTOH, yours are old and you already have to remove them...
PS: You should try a track day/driver's school.
mmiller2002 is offline   Reply With Quote
Old 07-30-2013, 03:10 PM   #5128
wcu25rs
Member#: 102632
Cool thanks....just considering the fronts only.
wcu25rs is offline   Reply With Quote
Old 07-30-2013, 03:12 PM   #5129
wcu25rs
Member#: 102632
I've thought about it but have no real desire. I usually go every year or every other year to a Speedtech school, but its for NASCAR, so I get my track fix there. I've tossed around the idea of trying autox for the last 8 or 9 years but the desire never got to a point where I just had to try it.
Old 07-30-2013, 09:19 PM   #5130
BIGSKYWRX
Member#: 7958
09 GH B+
tops are a wear item (front and rear), if they are getting long in the tooth- replace the front and the rear, I haven't priced oe tops, but they might not be much cheaper than Grp N ones- if true, that's an easy choice
Old 07-30-2013, 09:44 PM   #5131
wcu25rs
Member#: 102632
Ok thanks
Old 07-30-2013, 11:53 PM   #5132
wcu25rs
Member#: 102632
One last question: since AGXs are for sedans but will bolt on a wagon, is it necessary to get camber bolts for just even stock camber? From reading it sounds like it can limit negative camber on the wagons, but for a car that isn't tracked, does it really matter?
Old 07-31-2013, 12:12 AM   #5133
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Increasing negative camber up front makes a big improvement as far as performance goes.
For a plain DD street car, even if you match the front camber with the rear, you will see a great change.
Increasing negative camber in the front does a great deal to stop the understeer these cars are prone to.
A great street set up would be:
-2.0 front. Both sides EVEN!
Stock rear camber (about -1.5)
Toe set at zero all around.
You can use Whiteline Com-C tops to increase the fronts negative camber or slot the struts to do the same.
I'm not a fan of aftermarket camber bolts, but that's just me.
Old 07-31-2013, 12:51 AM   #5134
wcu25rs
Member#: 102632
So if I go with com cs I can negate the camber issue that come with sedan struts, instead of having to get camber bolts?
I'm an even bigger noob when it comes to alignment. Even though I've had lots of different cars, this will be my first with aftermarket struts/springs.
Thanks for the help! Any other tidbits of advice concerning the setup I've got would be appreciated.
Old 07-31-2013, 01:20 AM   #5135
Bikelok
Member#: 254851
2002 WRX wagon 5mt
No problem.
Do yourself a favor though. Read up on what these alignment numbers actually mean and do. I think it's very important to know what these changes actually do. The more you know the better.
Oh, and research where good places are near you that do GOOD ALIGNMENTS! More often than not, places like Sears, Firestone, etc. etc. do not take the time to do it right, or have techs who really don't know what they are doing.
Go to your local chapter on here on NASIOC and ask for good shops in your area.
I got tired of crappy shops, so I do my own alignments again now.
Good luck.
Old 07-31-2013, 01:41 AM   #5136
wcu25rs
Member#: 102632
No problem.
Good luck.
There's a good independent shop that does really good alignments near me.
About my question, is that true that I can get the camber I want with com c strut tops and not have to bother with camber bolts?
Old 07-31-2013, 02:13 AM   #5137
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Yes it's true.
Old 07-31-2013, 02:29 AM   #5138
wcu25rs
Member#: 102632
Awesome thanks!
Old 08-08-2013, 06:57 PM   #5139
Gatdula420
Member#: 300458
2002 Impreza WRX
Hey guys,
Currently driving a '02 wrx WAGON. It's about time to upgrade some of the suspension in my car. My main goal is to fix my old, outdated struts and achieve a performance upgrade as well as have a decent drop in ride height. I live in the city so my daily driving routs are shi*. I called TiC and had a quick conversation about which route I take; they were very helpful in guiding me the right way. Basically, I would like to know if my parts list was ok or lacking anything before I go ahead and do the thing:
-Koni Inserts
-Top hats
Front: Group N OR Whiteline Com C (still undecided?)
Rear: Group N ('04-'05)
-RCE Wagon springs OR Yellows (still undecided?)
-Scooby921 Strut Spacers
-Saggy Butt Shims (.375mm)
-Camber bolts for the rear
If I go with the Group N Fronts, I will need camber bolts as I understand?
If I go with the Whiteline Com C fronts, will I still need new camber bolts upfront?
Will there still be any thread on the strut bolts when using strut bars with spacer in rear?
Will I need to use D_Rex Koni extenders?
*my current suspension upgrades only consist of f/r strut bars, f/r sway bars with endlinks.
Thanks..hoping to hear some insightful information.
-Austin
Gatdula420 is offline   Reply With Quote
Old 08-08-2013, 09:46 PM   #5140
BIGSKYWRX
Member#: 7958
09 GH B+
if you want more than oe camber, then yes you'll want something that increases camber-if that's the case then I'd go w/ the Com C's (no bolts needed); if -1.0-ish is enough then I'd go w/ the Group N fronts (and no camber bolts)
camber bolts in the rear if you need to adjust camber, if the cross camber is OK- I don't see much of a need for camber bolts in the rear (unless you're trying to dial out neg camber)
the strut spacers you'll need as you're going w/ a "new" style spring
the shims will be needed w/ yellows (they are a sedan spring), shouldn't be needed w/ the wagon springs
you may be a little tight w/ threads for a rear strut bar, the upgrade in springs clearly outweighs any benefit of a strut bar, so I wouldn't sweat that too much
I don't think you'd "need" the extenders w/ either of those springs, they do give you a little more bump stroke
Old 08-09-2013, 02:23 PM   #5141
fastwrx25
Member#: 126441
03 bugeye
do the drex extenders. The extra travel is worth it. Its a hassle to do it after the fact.
fastwrx25 is offline   Reply With Quote
Old 08-09-2013, 03:51 PM   #5142
mmiller2002
Member#: 159286
Originally Posted by Gatdula420 View Post
Hey guys,
-Koni Inserts
-Top hats
-Austin
I really like my setup. It handles very well, street and track, and it's practical for urban life without too much lowering. No need for rear spacers.
http://www.clubwrx.net/forums/suspen...ml#post3033958
Old 08-09-2013, 10:50 PM   #5143
BlueWagon02
Member#: 207315
2015 WRX
Crystal White Pearl
Hey mmiller, I like the look of your setup. What size wheel/tire are you rolling?
BlueWagon02 is offline   Reply With Quote
Old 08-11-2013, 12:20 PM   #5144
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
Hey guys,
-Koni Inserts
-Top hats
-Austin
I wish I would have done the d rex extenders I have:
com C I cant imaging going with them set to max camber/max caster position
Koni
RCE yelows
and I think 3/8" saggy butt spacers.
labcoat is offline   Reply With Quote
Old 08-12-2013, 06:57 AM   #5145
fastwrx25
Member#: 126441
03 bugeye
I put in the drex extenders after a few thousand miles.....it was a pain in the ass but totally worth it. Which is why I recommend doing it the first time around. The extra travel makes a world of difference in ride quality, the Konis soak everything up nicely even at speed.
Old 08-13-2013, 02:45 PM   #5146
mmiller2002
Member#: 159286
Thanks!
Inexpensive "Sport Edition" from TireRack 17x7.5 ET 48
225/45-17 Kumho XS
Old 08-20-2013, 11:13 PM   #5147
harlen
Member#: 296124
02 wrx wagon
Can you guys clarify this for me? Are the sedan rsb the same length as the wagons (2002). I just got the hotchkis competition swaybar set for a sedan and the rear bar looks a little short. I had to pry the endlinks towards the center of the car quite a bit to get the rsb on there. The endlinks don't look right tilted inwards.
I bought the sedan set because I have front sti control arms, and the front bar fits perfect.
harlen is offline   Reply With Quote
Old 08-20-2013, 11:40 PM   #5148
Bikelok
Member#: 254851
2002 WRX wagon 5mt
They are the same in the rear.
Did you get a STI bar? The STI is different than the WRX.
Old 08-20-2013, 11:44 PM   #5149
yosemitemtb
Member#: 23437
'02 WRX Wagon
Original owner blue pearl
I had the same issue years ago with Hotchkis. After going around and around with them about the bar being too short, they finally sent me a set of their adjustable lateral links (unfortunately I don't think they make them anymore) because the end link mounts on them were adjustable. I'll try and find my photos, but like I said it was years ago, September of 2004. They took care of me, and years later when I snapped my front bar, they took care of me again replacing the bar for the cost of shipping, even though it had over 100k miles on it! Get in touch with Hotchkis, their customer service is top notch in my experience.
showing the angle with stock endlinks
Whiteline endlinks rubbed on the bar.
Compared to a stock bar, the with the stock bar, the endlinks go on the outside, with the hotchkis bar they go on the inside. I had the other end of both bars bolted to another link.
yosemitemtb is offline   Reply With Quote
Old 08-21-2013, 12:09 AM   #5150
Bikelok
Member#: 254851
2002 WRX wagon 5mt
I also have Hotchkis bars. No issues, mine fit perfectly.
The HID FAQ Thread - Read before posting your questions dithergizzard Electrical & Lighting 673 10-11-2016 09:16 PM
What does your rim/tire combo weigh? Post your setup + weight Trevor723 Tire & Wheel 42 06-04-2010 11:40 PM
Post your setup... az ej20 fan South West Impreza Club Forum -- SWIC 20 02-11-2004 12:59 AM
Are these gauge readings correct? post yours too please! T33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-28-2003 02:35 PM
