Old 02-16-2004, 11:57 AM   #101
amelnikov
Member#: 9827
2002 WRX Wgn 292whp
Alex Performance
You may need camber bolts for the rear. I'd recommend getting them anyway since you will probably want a performance alingnment afterwards. Otherwise they will bolt in just fine. The reason that you may need them is that because of the sedans wider track, the bolt holes are set just a bit different from the wagon. The fronts on our cars already have camber bolts, so you'll be fine there. It's the rear that may need adjustment.
Alex...
Alex Performance
amelnikov is offline   Reply With Quote
Old 02-16-2004, 09:52 PM   #102
Bort
Member#: 27075
09 WRX, 03 WRX,
98 OBS
Thanks for the info Alex.
When the time comes I'll likely be contacting you.
Bort is offline   Reply With Quote
Old 02-18-2004, 02:30 PM   #103
wntobp1
Member#: 24310
9804 2.5rs./04 wgn
rally blue/ java black
I was wondering if ther is any news about the prodrive wagon springs? Or if there is a setup that will work for fast roads or canyon runs on the wagon- STi, Cusco, DMS, whatever. I'm looking for ideas without spending a ton of money, thanks
wntobp1 is offline   Reply With Quote
Old 02-18-2004, 02:49 PM   #104
amelnikov
Member#: 9827
2002 WRX Wgn 292whp
Alex Performance
There are several companies that make wagon specific springs. Eibach for example. And the price is pretty good too. Way less the Prodrive.
Alex...
Alex Performance
Old 02-18-2004, 04:22 PM   #105
YinUCSD
Member#: 44945
06 LGT wag
so i think ive decided on koni inserts for my wagon (on prodrive springs), but where could i pick up a set of used wagon struts for cheap? i dont want to start the project with my current struts and then get stuck without a car if i f*** up and have to wait. plus i can just sell my current struts.
YinUCSD is offline   Reply With Quote
Old 02-18-2004, 04:59 PM   #106
WR xplosive
Member#: 33031
2008 4B11T
P26 MZ314000
ET48mm
A-Tech Final Speed 7.5
215/45/17 Yokohama AVS-ES100
TEIN SS Coil-over
no rubbing
WR xplosive is offline   Reply With Quote
Old 02-18-2004, 05:00 PM   #107
amelnikov
Member#: 9827
2002 WRX Wgn 292whp
Alex Performance
You can use the sedan struts as well, just have to get camber bolts for the rear and you'll probably be getting those anyway.
There's alway someone selling a set of stock stuts in the classifieds.
Alex...
Alex Performance
Old 02-18-2004, 06:23 PM   #108
YinUCSD
Member#: 44945
06 LGT wag
Alex...
Alex Performance
hey alex, thanks for the tip, thats a good idea, is there any performance difference in using the sedan struts over the wagon struts since there is a slight difference in geometry between the two types of struts?
Old 02-18-2004, 06:40 PM   #109
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
Alex...
Alex Performance
Won't you also end up with less negative camber in front than if you used the wagon struts?
driggity is offline   Reply With Quote
Old 02-18-2004, 07:25 PM   #110
amelnikov
Member#: 9827
2002 WRX Wgn 292whp
Alex Performance
The front has camber bolts from the factory. And if you put lowering springs on, you'll be in the negative territory already.
There is no performance difference between the sturts, as far as I know there only difference is the bolt holes.
Alex...
Alex Performance.
Old 02-23-2004, 05:38 PM   #111
wntobp1
Member#: 24310
9804 2.5rs./04 wgn
Anybody know when the prodrive '04 wagon springs are due, I'm sick of waiting for them
Old 02-23-2004, 07:25 PM   #112
gordon
Member#: 27665
'02 WRX wagon
WR blue
Talking Spring Nirvana
If you're just looking to reduce the wheel gap in front like I was, then I think I've got the answer - Eibachs springs in front and OEM springs in back. This setup made the wheel gap perfectly even on my '02 wagon (I measured), it rides great, doesn't rub with 225/45/r17 w/50mm offset, and I don't have to worry about speed bumps and driveways. I couldn't be happier with this setup.
check it out at Subydude:
http://subydude.com/gallery/_detail.php?pic=279
gordon is offline   Reply With Quote
Old 02-23-2004, 07:38 PM   #113
Bolster
Member#: 22290
2002 WRB WRX Wagon
My new setup:
-Koni inserts front/ KYB AGX Rear
-Ground Control coil overs (350 front, 325 rear)
-Whiteline 22mm non-adjustable rear swaybar
-Whiteline HD swaybar mounts
-Poltec Spherical Front endlinks
-Hairpin racing spherical endlinks
-Hairpin racing swaybar collars (to prevent swaybar "walk")
-STi Group-N front strut tops
-Factory rear strut tops
-17" 48et Rota Tarmacs with Bridgestone Potenza RE070
-Lowered 1" all around
-NO rubbing on 4 different suspension setups (I must just be lucky, so my fingers are staying crossed here)
-Replica of STi titanium front strut bar (aluminum and stainless, not Ti)
-Replica STi rear strut bar
-Whiteline steering rack bushings
Bolster is offline   Reply With Quote
Old 02-25-2004, 07:01 AM   #114
wrathfirex
Member#: 45909
2002 WRX Wagon
Red
Hey gordon!
Oem springs at the back??? How is the ride? Comfy?
Anyways a while back I mentioned that I got my HKS coilovers at 5F 4R Spring rates. Pretty good but damn they were bouncy up front. Then a tuner/friend told me the rear were too stiff and this caused the bouncy front end so I'm waiting for HKS' 3R springs.
Maybe this will be like using after market springs up front with OEM springs at the back
wrathfirex is offline   Reply With Quote
Old 02-25-2004, 02:18 PM   #115
OneManArmy
Member#: 36154
2004 WRX Wagon
I talked with prodrive earlier in the month and they said later this month on their springs.....not wagon specific I don't think. So I'd venture to guess they are available now or in the next week or so.
Call em up....or email for info.
But you should be able to get them very very soon if not now.
I'm waiting til April. If they don't have wagon specific I'll just get the sedan. They wagons only 70 pounds heavier in the back anyways. and the previous prodrive stuff seemed to work extremely well on both?
OneManArmy is offline   Reply With Quote
Old 02-25-2004, 05:19 PM   #116
gordon
Member#: 27665
'02 WRX wagon
WR blue
Rides awesome. The Eibachs are only slightly stiffer than stock (~5%, I think), so you can barely tell the difference. For reference, going for 16" to 17" wheels made a much bigger difference in ride. And it didn't noticeably increase oversteer either - tire pressure has at least as much effect.
Eibachs in front & EOM in back - it's the bomb!
Old 03-01-2004, 03:13 PM   #117
SMiLEY
Member#: 35641
$555 shipped for Koni's! After quite a bit of shopping around the next lowest price I can find is $608. Alex, how in the world are you doing that? That price is almost too good to be true.
-Jeff Hunt
SMiLEY is offline   Reply With Quote
Old 03-01-2004, 03:32 PM   #118
amelnikov
Member#: 9827
2002 WRX Wgn 292whp
Alex Performance
lol, I opened the business for fellow racers like me.
Practically no profit there but satisfaction that I helped guys that enjoy the cars as much as I do.
Alex...
Alex Performance
Old 03-01-2004, 05:21 PM   #119
YinUCSD
Member#: 44945
06 LGT wag
Alex...
Alex Performance
alex you are one cool dude. i am gonna get these from you just for that reason. other than the fact that you cant find em cheper anywhere else.
Old 03-01-2004, 05:30 PM   #120
Mark Avery
Member#: 10313
2002 WRX wagon
Prodrive didn't do wagon specific springs for the 02-03, so I doubt there'll be an version for the 04. The only aftermarket company to do a wagon specific spring is Eibach. They did a 02-03 spring, an 04 version is coming soon or may already be available.
Mark Avery is offline   Reply With Quote
Old 03-01-2004, 06:06 PM   #121
YinUCSD
Member#: 44945
06 LGT wag
tein makes a wagon specific s-tech.
Old 03-01-2004, 07:13 PM   #122
blubaru
Member#: 13001
Originally posted by Vector92
I have H&R springs on my 2002 Wagon, still with the stock struts.
How do you like the drop on the wagon with the H&Rs? You need to get the Konis and let us know how well they work. This combo is under serious consideration for my next setup.
blubaru is offline   Reply With Quote
Old 03-01-2004, 09:27 PM   #123
Mark Avery
Member#: 10313
2002 WRX wagon
Nope. Check they're web site. Their wagon and sedan springs are the same - same part #, same spring rates.
Old 03-02-2004, 12:13 AM   #124
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Sorry Mark, TEIN did make a Wagon specific S-Tech spring. I've got a set sitting in my garage and the box says GGB, which is a wagon. This was 02-03.
Part # SKS30-S1B00
WRX Sedan 02-03 Part # SKS34-AUB00
They're for sale if anyone wants them.
Arnie is offline   Reply With Quote
Old 03-02-2004, 01:26 PM   #125
YinUCSD
Member#: 44945
06 LGT wag
Part # SKS30-S1B00
tein maDe a wagon specific s-tech.
The HID FAQ Thread - Read before posting your questions dithergizzard Electrical & Lighting 669 04-26-2016 08:06 AM
What does your rim/tire combo weigh? Post your setup + weight Trevor723 Tire & Wheel 42 06-04-2010 10:40 PM
Post your setup... az ej20 fan South West Impreza Club Forum -- SWIC 20 02-10-2004 11:59 PM
Are these gauge readings correct? post yours too please! T33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-28-2003 01:35 PM
