Old 09-10-2008, 08:48 AM   #2401
STi_v4_Wagon
Member#: 120368
04 Forester XT
Originally Posted by mulva View Post
2002 WRX Wagon PSM
Stock 16"x6.5" Wheels
Bridgestone RE960 AS 205/55/16
Hotchkis F/R 25.4 mm Wagon Swaybars
Hotchkis Wagon Endlink & Rear Mount set
Tokico D-Spec Struts
STi "Group N" Strut Mounts
Swift Sport Mach Wagon Springs
Ingals Camber Bolts F/R
Camber is set to -1.5 f / -1.2 r
Tire pressure for DD is 37 psi f / 35 r
D-Specs adjusted to 4.5 turns FFS f / 4.25 turns FFS r
The setup makes for a great DD. The car feels planted and responsive and understeer is less noticeable than stock. The Swift's for 02/03 don't drop the front or rear much at all and there is definitely no saggy rear. I'll have to measure once I'm on a flatter surface, but I'm happy with the minimal drop and slightly stiffer spring rates.
Next up will be rolled rear fenders, 17" wheels, and Summer tires. Oh, and possibly those WL Steering Rack Bushings.
Pics please! Or at least get those ride height measurements up
STi_v4_Wagon is offline   Reply With Quote
Old 09-10-2008, 09:03 PM   #2402
go0sebumpz
Member#: 147521
03 WRX swaggonn
Hi to all you koni insert / rce spring owners , etc etc. I have a quick question , how would my car perform without the konis? I was wondering if it's not that bad to run without the insert. My car will be a DD and future some AX but that's later on. I would like to get wagon rce springs so i would like any info if anyone is running rce wagons with oem struts.
go0sebumpz is offline   Reply With Quote
Old 09-10-2008, 09:09 PM   #2403
makofoto
Member#: 25243
2006 Legacy Outback
In stock classes you are allowed to change shocks but not springs ... there is a reason for that. Shocks are much more important ... not that the oem shocks can't handle light weight rce's.
makofoto is offline   Reply With Quote
Old 09-10-2008, 09:10 PM   #2404
TurbojonLS
Member#: 38772
2 Cars, No Bling
Not that well. The spring is way too stiff for the stock dampers.
TurbojonLS is offline   Reply With Quote
Old 09-10-2008, 09:18 PM   #2405
BIGSKYWRX
Member#: 7958
09 GH B+
your dampers are set up for the oe springs- rates are 168/132, the RCE wagon springs are 278/259- a significant increase in rates, I think you would be severely underdamped w/ the oe struts
as makofoto has alluded to, your better off w/ new dampers and then add springs later
there are a few springs that can be used w/ the oe dampers, but if your looking into autox down the road then put your $ into dampers first and pass on those particular springs
Old 09-18-2008, 09:38 PM   #2406
jasonb
Member#: 1809
2006 WRX wagon, OBP
99 Jeep XJ
Few questions regarding suspension set up and winter driving:
1) Going to get some tweaks done on my alignment this weekend, and am tentatively shooting for -1.5 up front and -1.2 in the rear (per recomendations here). I am wondering if I should go for more. Pros/cons? But getting into winter, any downside to have more neg camber for snow and ice driving?
2) Anybody with tokicos soften them up a bit for winter? I would assume they work the same regardless of temp (no adjustments on regular shocks and never noticed a ride difference), but was just curious.
3) Running a 205/55/16 dedicated studless snow tire. How does that, if at all, change the equation to the upper two questions?
jasonb is offline   Reply With Quote
Old 09-19-2008, 09:36 AM   #2407
BIGSKYWRX
Member#: 7958
09 GH B+
that alignment is fine for winter- I wouldn't want any more neg camber up front for winter nor any less in the rear
I just got my "winter" alignment done went to -1.0 front, -1.5 rear 0 toe (my "summer" alignment was -3.0 up front
I run my dampers (Koni's) relatively soft on the street regardless (firm them up for weekends)
tire doesn't change things, winter you want your suspension a little softer and alignment less aggressive
Old 09-19-2008, 10:15 AM   #2408
TurbojonLS
Member#: 38772
2 Cars, No Bling
Living in Virginia, we get one or two 4" - 6" snowstorms a year, and that's about it. I've never had issues with my summer alignment in these snowstorms, and its not really worth the effort for those 2 times. I don't think you need to change your alignment unless you get real snow, which you 2 both do.
I'm with BIGSKY on the damping - I leave it the same unless I'm autocrossing, but its relatively soft to begin with (Koni struts). If I really cranked it stiff during the summer, I'd probably take it softer during winter though.
Old 09-19-2008, 02:28 PM   #2409
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Update to my handling setup...
Bilstein Pss9 Coilovers
08 STI/Enkei Wheels and
Toyo Proxes 4 225/45/17
JDM STI wagon lower control arms
FHI 4-pot front calipers
FHI 2-pot Rear Brake Calipers
DBA 4000 slotted rear rotors
DBA 5000 slotted 2pc rotors
Goodridge SS Brake Lines
Hawk HP+ Brake Pads
Kartboy 2-pot RearBrake Bracket
Whiteline 22/24mm adj front swaybar
Whiteline 22/24/27mm adj rear swaybar
Whiteline front strut tower bar
Whiteline rear strut tower bar
Whiteline quick-release skewers
Whiteline camber plates
Whiteline Roll Center Kit
Noltec front endlinks
Perrin rear endlinks
Motul 600 Dot4 brake fluid
Energy Suspension Hyper-Flex kit
- front control arm bushings
- rear trailing arm bushings
- shifter bushings bushings
Alignment:
-2.25 deg front camber
-1.0 deg rear camber
chrisarella is offline   Reply With Quote
Old 09-19-2008, 02:58 PM   #2410
BIGSKYWRX
Member#: 7958
09 GH B+
you must have a six speed swap to be running 5x114's
what's the spring rates on the Bilsteins?
Old 09-19-2008, 03:07 PM   #2411
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Nope, they're 5x100. Check it out...
http://www.japanparts.com/db/partsli...aker=4&volkey=
^^^ 5th set down on the page.
And I don't remember what the rates are but I believe 400/500
Old 09-19-2008, 05:43 PM   #2412
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
I'm confused... Are your wheels off of an 08 STi or just the same design wheel? B/c I thought all 05+ STI's were 114.3x5.
Superorb is offline   Reply With Quote
Old 09-19-2008, 06:13 PM   #2413
OneManArmy
Member#: 36154
2004 WRX Wagon
questions....
I have a 2004 wrx wagon.
I'm currently running V7 spec C struts with wagon pink springs and stock top hats. I was running camber plates and sedan rear top hats and it worked fine minus the saggy but.
The current set up the max camber I can get is -.25 in the front. And the rear is clunking like crazy.
Instead of trying to fix the issues there I picked up some new struts. I got AGX struts with the front struts being the ones that CVR Motorsports recommended. I have camber bolts front and rear. This package... but I have the older adjust on top rear struts. http://www.cvrmotorsports.com/store/...product_id=212
Am I going to have issues hitting something like -1.8 or 2 up front to go with -1 in the back.
I also run Whiteline front and rear sway bars. 24/27. WL rear mounts. Perrin rear endlinks. Stock in the front but I hope to remedy that with some kartboy ones.
I'm also thinking of switching springs and I can't decide if the RCE wagon springs will be too stiff. I want a little stiffer than my current springs and a little lower.
OneManArmy is offline   Reply With Quote
Old 09-19-2008, 06:25 PM   #2414
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
OK, if with sedan struts you're currently only getting -0.25, you could reasonably expect to max out at -1.7 to -1.8 if you add an aftermarket camber bolt to the lower strut hole in the front. However, if you go to the AGX wagon struts, you should be hitting something like -1.0 in the front with only the stock camber bolt. Adding an aftermarket bolt to the lower hole should send you up into the -2.3 to -2.5 range.
If you want to go lower and stiffer than your Wagon Pinks, your options pretty much are only the RCE Wagon Blacks or the JDM Pinks with a Paranoid Fabrications Saggy Butt Shim in the rear. However, I wouldn't be really excited about either of those with the AGXes. If you think it's likely you're going to upgrade springs again, you might talk to CVR and see if they'll let you change your order from AGXes to D-Specs.
Old 09-19-2008, 06:37 PM   #2415
OneManArmy
Member#: 36154
2004 WRX Wagon
The struts are already here.
I had a feeling I'd be oversprung. Right now I'm overdamped...haaaa.
crap. Well the wagon pinks should be fine with the agx and the giant sway bars will be alright.
What about Swift and Crucial. Only two other springs I'd think about beyond RCE.
Turn In seemed to think the AGX could handle the RCE springs. I'll be running on full stiff or close to it most of the time. Even when I hit the snow.
If I had the dough I'd go koni struts but I am trading my old stuff for 2 agx. I already had 2.
Old 09-19-2008, 06:43 PM   #2416
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Oh, the AGXes definitely can handle the Blacks or the JDM Pinks in the sense of controlling them properly for good handling. However, the D-Specs ride significantly better than the AGXes. That difference is only going to become more pronounced as you have to stiffen up the dampers for stiffer springs.
Old 09-19-2008, 07:41 PM   #2417
BIGSKYWRX
Member#: 7958
09 GH B+
-0.25 is the max camber you could get w/ camber plates????
even w/o camber plates AND sedan struts you should be in the -0.7 range just w/ the oe eccentric bolts, MANY alignment shops don't know how to adjust the camber up front- they loosen the top nut and start twisting away- both nuts (top and bottom) have to FULLY loosened before adjusting
there are a few additional tricks to get even more camber out of the oe setup
Old 09-19-2008, 07:57 PM   #2418
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I took it to mean he no longer has the camber plates on there. Remember, on the unbent side of my car, the most I could get out of it with sedan struts was -0.4 (the bent side maxed out positive).
Old 09-19-2008, 08:04 PM   #2419
BIGSKYWRX
Member#: 7958
09 GH B+
^ that could be a RS vs WRX strut difference possibly? I don't think anyone has compared the orientation of the holes side by side (RS to WRX) that I'm aware of- different part #'s (could be just valving???)
-0.25 still sounds like a tech not loosening the lower bolt to me, that's well below the "norm" wagon folks are seeing w/ sedan struts
Old 09-19-2008, 09:42 PM   #2420
OneManArmy
Member#: 36154
2004 WRX Wagon
I sold the camber plates... oops.
No it's spec C struts with wagon springs and top hats.
I was with the tech when he did the camber and I made him loosen everything because I thought he was nuts. He kept saying that he thought I was crazy asking for max negative camber in the front. He said most subaru guys go with -.3 or 4 up front and -1 to -1.3 in the rear (stock spec) and like it. I told him they don't know what they're talking about. So I wouldn't be surprised if it was tech error but I thought the guy was an idiot so I got under there and made sure he loosened everything.
-.25 was the best we could get. So I've been running -.25 up front and -1.3 in the rear. It's like driving a civic but worse. my civic handled WAY better.
I was happy with -1.8 and -1.3. I'd like to get somewhere close to that again.
Old 09-19-2008, 09:47 PM   #2421
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Yeah, I drove around like that for about 6 months. Taught me how to drive the car damned well though.
Old 09-19-2008, 09:50 PM   #2422
OneManArmy
Member#: 36154
2004 WRX Wagon
Only time its fun is when its wet out. My tires are done for so it's instant drift mobile. Pretty friggin sketchy though.
Looking to do the suspension this weekend. Get new tires in the next week and then go in for an alignment.
Old 09-19-2008, 09:55 PM   #2423
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
They're designed by STI, branded STI, and built by Enkei. Sold in Japan, and made available on the USDM FXT. Follow the link in my post above and read the "more info" link to see the specs.
I hope that clears things up.
Old 09-21-2008, 09:35 PM   #2424
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Well, here it is for now. Just got the take-offs on this weekend.
04' STI take-offs (springs and struts)
N-Hats F/R.
Paranoid Fad 3/8" shims, rear
WL solid links F/R
WL solid rear sway (22/24/27mm adj)
Hotk. hollow front (non-adjust, I think it is 25.4 so 22mm equiv.)
Cusco rear strut tower brace
WL ALK ("sport")
WL steering rack bushings
GT-Spec 4-Point Ladder Bar
ST BBK 328, 4 pot front (stock rear save for the lines and track pads when needed)
Rota SDRs with 225/45R17 Falken AZENIS RT-615
A couple more days of driving and I will get an alignment. Was running -1.5 in the rear before. Would like to duplicate that. I am going to run a double camber bolt front until I can afford RCE non-lowering plates.
tazswing is offline   Reply With Quote
Old 09-21-2008, 09:43 PM   #2425
BIGSKYWRX
Member#: 7958
09 GH B+
post up your ride heights
The HID FAQ Thread - Read before posting your questions dithergizzard Electrical & Lighting 669 04-26-2016 08:06 AM
What does your rim/tire combo weigh? Post your setup + weight Trevor723 Tire & Wheel 42 06-04-2010 10:40 PM
Post your setup... az ej20 fan South West Impreza Club Forum -- SWIC 20 02-10-2004 11:59 PM
Are these gauge readings correct? post yours too please! T33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-28-2003 01:35 PM
